    MMM-GroveGestures
    51 Posts 8 Posters 26.3k Views 12 Watching
      bolish
      @Benjaminh86
      Not really…
      “MONITORON” is already an action which is managed by MMM-REMOTECONTROL so you don’t need MMM-Notificationtrigger for that.
      You just need MMM-GroveGesture to send it :
      		        				"UP": {
      						        notificationExec: {
      						          notification: "REMOTE_ACTION",
      							    payload: {
      							  	action: "MONITORON",
      								     },	 // you don't need to refer to a module name for the MONITORONN action (only necessary for HIDE and SHOW)
      But you need to make sure that MMM-REMOTEControl is configured in the right way so that when it receives “MONITORON” it sends the right command (depending if you use HDMI, CEC, etc…)
      Regards
        Benjaminh86 @bolish
        @bolish
        thank you
        when you say: “But you need to make sure that MMM-REMOTEControl is configured in the right way”, when I send the request http://192.168.xxx.xxx:8080…MONITOROFF, it works.
        is that enough, or do I have to add something to the MMM-Remote-Control script?
          bolish
          No, if it’s works by sending the request, it should work with Gesture also!
            Benjaminh86 @bolish
            @bolish
            Great!
            I will try tonight the adaptation I made of your script.
            I put the action “MONITOROFF” in the “Default_Mode” part of Grove Gestures, that’s it?
              Benjaminh86 @bolish
              Hello @bolish,
              thanks to you! everything is working!
              however, I thought Grove Gestures would activate automatically, but I have to make the command line for the sensor to be active:
              cd ~ / MagicMirror / modules / MMM-GroveGestures / py
              cp grove_gesture_sensor.py.RPI grove_gesture_sensor.py
              Is this normal?
              Another question about MMM-Pages; I would like to display the Google Calendar calendar on page 1 and the holiday calendar on page 2, but I do not know how to differentiate and name them on MMM-Pages …
              Do you have an idea?
                A Former User @Benjaminh86
                @Benjaminh86 said in MMM-GroveGestures:
                It is described on instruction for installation. And that command is not for activation. I provide 2 scripts for each of Raspberry Pi and Asus TinkerBoard. you need to select one for your device. You don’t need to do that job again after once you did.
                The real activation would be performed in the module itself on every running of MM.
                  bolish
                  @Benjaminh86
                  You have to search a bit on the forum.
                  One idea could be to create 2 calendars instances.
                  See below post extract :
                  well… I believe it’s far from being perfect…but at least it seems to do the job…
                  I created a “new” module which does exactly same / has the same code as the one I want to use, but has a different name (folder named “MMM-Calendar2” -> file named “MMM-Calendar2.js” -> within the line Module.register(‘MMM_Calendar2’)).
                  Not in the default module folder but into the 3rd party module folder…
                  And put instance 1 on page 1 and isntance 2 on page 2.
                    Benjaminh86 @Guest
                    Hello @Sean,
                    I will look at this in more detail in the module.
                    Thank you again for your work.
                      Benjaminh86 @bolish
                      @bolish
                      I will explore this track.
                      Thanks to you ; you already helped me a lot!
                        Benjaminh86 @Guest
                        @Sean
                        it’s weird; the sensor is not active if I do not order:
                        would not it come from “chmod + x * .sh” where I hurt something? …
                        • 3 / 6
