    MMM-GroveGestures
    51 Posts 8 Posters 32.6k Views 12 Watching
      A Former User @Benjaminh86
      @Benjaminh86 said in MMM-GroveGestures:
      cd ~ / MagicMirror / modules / MMM-GroveGestures / py
      cp grove_gesture_sensor.py.RPI grove_gesture_sensor.py
      It is described on instruction for installation. And that command is not for activation. I provide 2 scripts for each of Raspberry Pi and Asus TinkerBoard. you need to select one for your device. You don’t need to do that job again after once you did.
      The real activation would be performed in the module itself on every running of MM.
      B 2 Replies Last reply
        bolish
        @Benjaminh86
        You have to search a bit on the forum.
        One idea could be to create 2 calendars instances.
        See below post extract :
        well… I believe it’s far from being perfect…but at least it seems to do the job…
        I created a “new” module which does exactly same / has the same code as the one I want to use, but has a different name (folder named “MMM-Calendar2” -> file named “MMM-Calendar2.js” -> within the line Module.register(‘MMM_Calendar2’)).
        Not in the default module folder but into the 3rd party module folder…
        And put instance 1 on page 1 and isntance 2 on page 2.
          Benjaminh86 @Guest
          Hello @Sean,
          I will look at this in more detail in the module.
          Thank you again for your work.
            Benjaminh86 @bolish
            @bolish
            I will explore this track.
            Thanks to you ; you already helped me a lot!
              Benjaminh86 @Guest
              @Sean
              it’s weird; the sensor is not active if I do not order:
              would not it come from “chmod + x * .sh” where I hurt something? …
              ? 1 Reply Last reply
                Benjaminh86 @bolish
                @bolish
                it works!
                thanks for your help
                  @Benjaminh86
                  Can’t understand.
                  Do you need to do that shell command per every execution of MM? Have you reinstalled it?
                  That commands just need to be done once when you install this module.
                  And that command isn’t related with chmod + x .sh at all.
                  Check this.
                  ls ~/MagicMirror/modules/MMM-GroveGestures/py
                  There should be grove_gesture_sensor.py besides grove_gesture_sensor.py.RPI and grove_gesture_sensor.py.ATB.
                  Are those files there?
                    Benjaminh86 @Guest
                    @Sean
                    I have to make this command every start of the pi, knowing that I do not start the MM automatically (pmm2) time to set everything (npm start).
                    I’ll be watching tonight with
                    ls ~ / MagicMirror / modules / MMM-GroveGestures / py
                      Benjaminh86 @Guest
                      @Sean
                      That’s what happens :
                      pi@raspberrypi:~ $ ls ~/MagicMirror/modules/MMM-GroveGestures/py
                      gesture_print.py grove_gesture_sensor.pyc
                      grove_gesture_sensor.py grove_gesture_sensor.py.RPI
                        @Benjaminh86
                        If you have those files, you don’t need to execute any manual commands o n MM running
                          MisterT
                          Hi everybody,@Sean and @Benjaminh86
                          I use this module just for change pages with MMM-Pages and MMM-Pages indicator but after a while, my sensor is unknown.
                          when i just want to test the sensor with “python gesture_print.py”, i have:
                          Error with sensor
                          Paj7620 initialize register finished.
                          my matrix is good i think:
                          sudo i2cdetect -y 1
                          0 1 2 3 4 5 6 7 8 9 a b c d e f
                          00: 03 04 05 06 07 08 09 0a 0b 0c 0d 0e 0f
                          10: 10 11 12 13 14 15 16 17 18 19 1a 1b 1c 1d 1e 1f
                          20: 20 21 22 23 24 25 26 27 28 29 2a 2b 2c 2d 2e 2f
                          30: 30 31 32 33 34 35 36 37 38 39 3a 3b 3c 3d 3e 3f
                          40: 40 41 42 43 44 45 46 47 48 49 4a 4b 4c 4d 4e 4f
                          50: 50 51 52 53 54 55 56 57 58 59 5a 5b 5c 5d 5e 5f
                          60: 60 61 62 63 64 65 66 67 68 69 6a 6b 6c 6d 6e 6f
                          70: 70 71 72 73 74 75 76 77
                          and i have 5 file in /home/pi/MagicMirror/modules/MMM-GroveGestures/py
                          I restart Raspberry but the result is the same
                          Can aybody help me please ?
                            A Former User @MisterT
                            @MisterT
                            If you get one similar with this (All address are shown), It would be something wrong.
                            Only 73 should be shown. There might be dead pin or H/W failure.
                            M 1 Reply Last reply
                              MisterT @Guest
                              @Sean thanks for your answer it was a H/W failure I2C was not activate and i don’t know why ? I enabled I2c with raspi-config and shutdown the pi. I pluged my sensor again and it works
                                jim.dw
                                @Sean Hi mate, just dipping my toe in to the whole Magic Mirror world and loving it. Was just wondering if there’s any way to control MMM-Carousel and MMM-CECControl using the output from MMM-GroveGestures?
                                I’m thinking
                                • Clockwise for next slide
                                • Anti clockwise for previous slide
                                • UP to send the wake up signal on HDMI
                                • Down to send the sleep signal on HDMI
                                  A Former User @jim.dw
                                  @jim-dw
                                  Well, I’m not the author of those modules, so Ask these to the creator of MMM-Carousel / MMM-CECControl ;(Or need to check by yourself)
                                  • Are there notifications for that purpose?
                                  • Or Are there method of module class for that purpose?
                                  • Or controllable by external shell script or HTTP API?
                                  At least one of them possible, it could.
                                    jim.dw
                                    @Sean lol. Good point.
                                    I guess what confused me is this code below. I understand ‘clock’ or ‘newsfeed’ can be swapped out for ‘mmm-ceccontrol’ or ‘mmm-carousel’ it’s just figuring out how I send the command.
                                    Is it “module.hide()” that needs to be replaced?
                                    Sorry for this. Still learning
                                    moduleExec: {
                                    module: [“clock”, “newsfeed”], // [] will be all modules.
                                    exec: (module, gestures) => {
                                    module.hide()
                                      @jim-dw
                                      right. “.hide()” is a common method of every module should have. Usually, module developer need to implement that method by his own or just leave it as inheritance from parent class. So, every module will have that “hide()” method definitely.
                                      Now, let’s see your needs.
                                      For example;
                                      If MMM-Carousel has specific method like “changePage(pageNo)”(IDK whether really it exists o not), you can call that method with “moduleExec”
                                      However I’m not the author of MMM-Carousel, so don’t know it supports or not. Ask to the author.
                                      S J 2 Replies Last reply
                                        sdetweil @Guest
                                        @Sean hide() technically turns into a suspend function call in the module
                                        show() turns into resume()
                                          jim.dw @Guest
                                          @Sean You know what, I think I understood that mate. Thank you. I guess I’m gonna have to learn a little bit of python. Thank you
                                            banbutcher
                                            in the readme file it says it doesnt work behind spy glass, does that include regular glass with a reflective film?
                                            im guessing that it wont work but hoping that it will! :)
                                            thanks
                                            • 2 / 3
