Solved force_s3tc_enable overridden by environment.
i get warning but my MM doesn’t start i have tried so many solutions. but still no effect. do you have any idea where should i look for those HTML or chromium files ?
Sorry, no idea.
You could disable all modules (disabled: true,
) and then enable them one by one (disabled: false,
) until the issue appears.But also run
cd ~/MagicMirror; npm run config:check
to be sure you do not have a config issue.
Perhaps the ATTENTION is not related to the config. -
Thanks i will try that and if solves that i will post it here :)
there is one more issue npm lodash.update vulnerability. i don’t think so that those are connected to each other.
Are u using chrome as the browser?
This error has been reported there frequently.Search force_s3tc_enable in google
Chromium. yeah i have seen many reports on google about this chrome/chromium :(
I think must be issue with the GPU or else the syntax . i am looking into it but cant find anything :(
This post is deleted! -
@siddhartha so, what does 'does not start ’ mean?
npm start
in the Magic Mirror folder gets the command prompt back? or not
screen goes black, or nothave you done
export DISPLAY=:0 npm start
on my mm I also have to
npm --enable-transparent-visuals --disable-gpu start
After upgrading OS. i faced problem with display.
i fixed some problem with
npm audit fix --force.Then i shifted to VNC
used DISPLAY=:1 and then the magicmirror started.
but now there ware two process running at time.MagicMirror with DISPLAY=:0
MM with DISPLAY=:1so using pm2 i deleted MagicMirror and gave reboot.
everything worked perfectly. so i changed back DISPLAY=:0 in MM.and gave reboot again…
and problem solved. no black screen no error :)
Cool. Thx for the feedback
No problem. Thank you :)
