    Wish i never updated to 2.7.1 Black Screen!
    19 Posts 2 Posters 8.5k Views 2 Watching
      hue-lights doesn’t have a package.json, so no npm install there
      npm WARN MMM-pages No repository field.
      npm WARN MMM-pages No license field.
      package.json doesn’t have some typically useful fields… no problems
      so, one thing to try also is
      npm start &
      which will start MM AND give u back the terminal window…
      I get lots of messages as things start up there…
      D 1 Reply Last reply
        dazza120 @sdetweil
        @sdetweil this is what i get
        npm start &
        [1] 1352
        pi@raspberrypi:~ $ npm ERR! path /home/pi/package.json
        npm ERR! code ENOENT
        npm ERR! errno -2
        npm ERR! syscall open
        npm ERR! enoent ENOENT: no such file or directory, open '/home/pi/package.json'
        npm ERR! enoent This is related to npm not being able to find a file.
        npm ERR! enoent
        npm ERR!     /home/pi/.npm/_logs/2019-04-02T22_38_46_083Z-debug.log
          @dazza120 said in Wish i never updated to 2.7.1 Black Screen!:
          pi@raspberrypi
          but u have to start in MagicMirror folder
          npm start &
            dazza120 @sdetweil
            @sdetweil right thanks here it is
            pi@raspberrypi:~/MagicMirror $ npm start &
            [1] 1486
            > magicmirror@2.6.0 start /home/pi/MagicMirror
            > sh run-start.sh
            Starting MagicMirror: v2.6.0
            Loading config ...
            Loading module helpers ...
            No helper found for module: MMM-pages.
            No helper found for module: MMM-page-indicator.
            Module helper loaded: MMM-Remote-Control-Repository
            WARNING! Could not load config file. Starting with default configuration. Error found: Error: Cannot find module 'lmtool'
            App threw an error during load
                at Module._resolveFilename (internal/modules/cjs/loader.js:602:15)
                at Function.Module._resolveFilename (/home/pi/MagicMirror/node_modules/electron/dist/resources/electron.asar/common/reset-search-paths.js:35:12)
                at Function.Module._load (internal/modules/cjs/loader.js:528:25)
                at Module.require (internal/modules/cjs/loader.js:658:17)
                at require (internal/modules/cjs/helpers.js:20:18)
                at Object.<anonymous> (/home/pi/MagicMirror/modules/MMM-voice/node_helper.js:32:16)
                at Object.<anonymous> (/home/pi/MagicMirror/modules/MMM-voice/node_helper.js:373:3)
                at Module._compile (internal/modules/cjs/loader.js:711:30)
                at Object.Module._extensions..js (internal/modules/cjs/loader.js:722:10)
                at Module.load (internal/modules/cjs/loader.js:620:32)
            { Error: Cannot find module 'lmtool'
                at Module.load (internal/modules/cjs/loader.js:620:32) code: 'MODULE_NOT_FOUND' }
            Launching application.
              sdetweil @dazza120
              @dazza120 ok, just want to check again…
              after doing the git pull in the MM folder
              you then
              did npm install while in the MM folder, right? you must
              as you have MMM-voice installed
              u need to do npm install there too
                dazza120 @sdetweil
                @sdetweil Hi yes i done that but for some reason its stayed on 2.6.0 and said that was the latest version is there anyway to push it to install the latest version i have done git hard rest but dont know where to go form there.
                  sdetweil @dazza120
                  @dazza120 git reset hard blows you back to the last time u did a git pull
                  then u do a git pull to get the latest
                  then npm install
                  then npm install in any module folder that has a package.json file
                  snowboy (MMM-voice and MMM-Hotword) is a pain in the rear…
                  usually requires a special command (electron-rebuild) to rebuild some part at the new electron level…
                  see instructions in MMM-Hotword
                    dazza120 @sdetweil
                    @sdetweil Yeah it isn’t installing the new MM it says its on the latest version 2.6.0 not 2.7.1 I get to this HEAD is now at b508a62 Merge pull request #1632 from MichMich/fix-2.7.1 and then when i do git pull it says its already on the latest :(
                      sdetweil @dazza120
                      @dazza120 edit the MM/package.json
                      what version is there?? should say 2.8-develop
                      also show me the results of git remote -v
                      is your git copy of a fork you might have made?
                        dazza120 @sdetweil
                        @sdetweil thanks for your help I’m sorted now apart from Calendar not coming up with dates, I saved the config so it was just a case of re downloading everything again :(
                        S 2 Replies Last reply
                          sdetweil @dazza120
                          @dazza120 glad u r working ok
                            sdetweil @dazza120
                            @dazza120 could u mark your issues solved… thx
