    Wish i never updated to 2.7.1 Black Screen!
    19 Posts 2 Posters 8.5k Views 2 Watching
      @dazza120 said in Wish i never updated to 2.7.1 Black Screen!:
      pi@raspberrypi
      but u have to start in MagicMirror folder
      npm start &
      D 1 Reply Last reply
        dazza120 @sdetweil
        @sdetweil right thanks here it is
        pi@raspberrypi:~/MagicMirror $ npm start &
        [1] 1486
        > magicmirror@2.6.0 start /home/pi/MagicMirror
        > sh run-start.sh
        Starting MagicMirror: v2.6.0
        Loading config ...
        Loading module helpers ...
        No helper found for module: MMM-pages.
        No helper found for module: MMM-page-indicator.
        Module helper loaded: MMM-Remote-Control-Repository
        WARNING! Could not load config file. Starting with default configuration. Error found: Error: Cannot find module 'lmtool'
        App threw an error during load
            at Module._resolveFilename (internal/modules/cjs/loader.js:602:15)
            at Function.Module._resolveFilename (/home/pi/MagicMirror/node_modules/electron/dist/resources/electron.asar/common/reset-search-paths.js:35:12)
            at Function.Module._load (internal/modules/cjs/loader.js:528:25)
            at Module.require (internal/modules/cjs/loader.js:658:17)
            at require (internal/modules/cjs/helpers.js:20:18)
            at Object.<anonymous> (/home/pi/MagicMirror/modules/MMM-voice/node_helper.js:32:16)
            at Object.<anonymous> (/home/pi/MagicMirror/modules/MMM-voice/node_helper.js:373:3)
            at Module._compile (internal/modules/cjs/loader.js:711:30)
            at Object.Module._extensions..js (internal/modules/cjs/loader.js:722:10)
            at Module.load (internal/modules/cjs/loader.js:620:32)
        { Error: Cannot find module 'lmtool'
            at Module.load (internal/modules/cjs/loader.js:620:32) code: 'MODULE_NOT_FOUND' }
        Launching application.
          sdetweil @dazza120
          @dazza120 ok, just want to check again…
          after doing the git pull in the MM folder
          you then
          did npm install while in the MM folder, right? you must
          as you have MMM-voice installed
          u need to do npm install there too
            dazza120 @sdetweil
            @sdetweil Hi yes i done that but for some reason its stayed on 2.6.0 and said that was the latest version is there anyway to push it to install the latest version i have done git hard rest but dont know where to go form there.
              sdetweil @dazza120
              @dazza120 git reset hard blows you back to the last time u did a git pull
              then u do a git pull to get the latest
              then npm install
              then npm install in any module folder that has a package.json file
              snowboy (MMM-voice and MMM-Hotword) is a pain in the rear…
              usually requires a special command (electron-rebuild) to rebuild some part at the new electron level…
              see instructions in MMM-Hotword
                dazza120 @sdetweil
                @sdetweil Yeah it isn’t installing the new MM it says its on the latest version 2.6.0 not 2.7.1 I get to this HEAD is now at b508a62 Merge pull request #1632 from MichMich/fix-2.7.1 and then when i do git pull it says its already on the latest :(
                  sdetweil @dazza120
                  @dazza120 edit the MM/package.json
                  what version is there?? should say 2.8-develop
                  also show me the results of git remote -v
                  is your git copy of a fork you might have made?
                    dazza120 @sdetweil
                    @sdetweil thanks for your help I’m sorted now apart from Calendar not coming up with dates, I saved the config so it was just a case of re downloading everything again :(
                    S 2 Replies Last reply
                      sdetweil @dazza120
                      @dazza120 glad u r working ok
                        sdetweil @dazza120
                        @dazza120 could u mark your issues solved… thx
