    MagicMirror screen goes black
    27 Posts 8 Posters 13.2k Views 7 Watching
      sdetweil @motdog
      @motdog always make sure u have an alternative way into the system. Like ssh from your PC.
      M 1 Reply Last reply
        motdog @sdetweil
        @sdetweil I use VNC viewer pretty much all of the time to access this and nothing happens. I do see the green light occasionally flash on the pi when I try with the keyboard hooked up to it & my tv.
        • Cr4z33C
          Cr4z33 @DavyC
            motdog
            So I am still getting this about every 3-5 days. I have now playing on spotify and am wondering if that is the issue. Dark Sky is my weather app but the issue I had with the number of requests is not an issue any more. Curious as to why this happens. At the same time I can see the screen via my remote module
              sdetweil @motdog
              @motdog if you can, ctrl-shift-i to open the developers window and select the console tab…scroll around to see errors…
              M 2 Replies Last reply
                motdog @sdetweil
                @sdetweil thanks, I will next time. I just hit control c and then reclicked on the MM tab on the desktop and it starts running again
                  motdog @sdetweil
                  @sdetweil got a message that dev tools was disconnected, once page is reloaded dev tools will automatically reconnect
                    sdetweil @motdog
                    @motdog so, some module crashed… the old updateNotofication module might still be the cause… is that enabled in config?
                      motdog @sdetweil
                      @sdetweil yes. I will delete it and see what happens. Typically its been every 3-5 days. I haven’t updated this version to the new software, should I or should I leave it alone?
                        sdetweil @motdog
                        @motdog wait
                          motdog @sdetweil
                          @sdetweil thanks, that’s what I thought. I am starting a second mirror for me that when I installed MM was the new version automatically it seems.
