    MagicMirror screen goes black
    27 Posts 8 Posters 12.9k Views 7 Watching
      motdog @sdetweil
      @sdetweil I use VNC viewer pretty much all of the time to access this and nothing happens. I do see the green light occasionally flash on the pi when I try with the keyboard hooked up to it & my tv.
      • Cr4z33C Offline
        Cr4z33 @DavyC
          motdog
          So I am still getting this about every 3-5 days. I have now playing on spotify and am wondering if that is the issue. Dark Sky is my weather app but the issue I had with the number of requests is not an issue any more. Curious as to why this happens. At the same time I can see the screen via my remote module
            sdetweil @motdog
            @motdog if you can, ctrl-shift-i to open the developers window and select the console tab…scroll around to see errors…
              motdog @sdetweil
              @sdetweil thanks, I will next time. I just hit control c and then reclicked on the MM tab on the desktop and it starts running again
                motdog @sdetweil
                @sdetweil got a message that dev tools was disconnected, once page is reloaded dev tools will automatically reconnect
                  sdetweil @motdog
                  @motdog so, some module crashed… the old updateNotofication module might still be the cause… is that enabled in config?
                    motdog @sdetweil
                    @sdetweil yes. I will delete it and see what happens. Typically its been every 3-5 days. I haven’t updated this version to the new software, should I or should I leave it alone?
                      sdetweil @motdog
                      @motdog wait
                        motdog @sdetweil
                        @sdetweil thanks, that’s what I thought. I am starting a second mirror for me that when I installed MM was the new version automatically it seems.
