Solved Help with Update to 2.7.0
Thanks for the help @sdetweil and @CyruS1337. The latest suggestion gave me the same "Updating … " response.
I just renamed my MagicMirror folder and did a clean install. Everything is working great again. THANKS!
@CyruS1337 said in Help with Update to 2.7.0:
Run the following command in the MagicMirror folder
rm package-lock.json rm vendor/package-lock.json
Then execute in the folder the usual command for the upload
git pull && npm install
Now it should work
@CyruS1337 this solved the firt install command but…
ownloading tmp-2822-0-electron-v3.0.13-linux-armv7l.zip Error: read ECONNRESET /home/pi/MagicMirror/node_modules/electron/install.js:49 throw err ^ Error: read ECONNRESET at TLSWrap.onStreamRead (internal/stream_base_commons.js:111:27) npm WARN acorn-jsx@5.0.1 requires a peer of acorn@^6.0.0 but none is installed. You must install peer dependencies yourself. npm WARN grunt-stylelint@0.10.1 requires a peer of stylelint@^9.0.0 but none is installed. You must install peer dependencies yourself. npm ERR! code ELIFECYCLE npm ERR! errno 1 npm ERR! electron@3.0.13 postinstall: `node install.js` npm ERR! Exit status 1 npm ERR! npm ERR! Failed at the electron@3.0.13 postinstall script. npm ERR! This is probably not a problem with npm. There is likely additional logging output above. npm ERR! A complete log of this run can be found in: npm ERR! /home/pi/.npm/_logs/2019-04-05T19_09_38_688Z-debug.log pi@raspberrypi:~/MagicMirror $ pi@raspberrypi:~/MagicMirror $ npm start > magicmirror@2.7.1 start /home/pi/MagicMirror > sh run-start.sh run-start.sh: 4: run-start.sh: electron: not found npm ERR! file sh npm ERR! code ELIFECYCLE npm ERR! errno ENOENT npm ERR! syscall spawn npm ERR! magicmirror@2.7.1 start: `sh run-start.sh` npm ERR! spawn ENOENT npm ERR! npm ERR! Failed at the magicmirror@2.7.1 start script. npm ERR! This is probably not a problem with npm. There is likely additional logging output above.
if an idea
thanks
Jean-Philippe -
pi@raspberrypi:~ $ cd MagicMirror pi@raspberrypi:~/MagicMirror $ git remote -v origin https://github.com/MichMich/MagicMirror.git (fetch) origin https://github.com/MichMich/MagicMirror.git (push) pi@raspberrypi:~/MagicMirror $ pi@raspberrypi:~/MagicMirror $ rm package-lock.json pi@raspberrypi:~/MagicMirror $ rm vendor/package-lock.json pi@raspberrypi:~/MagicMirror $ git pull && npm install Updating de57daa..b508a62 pi@raspberrypi:~/MagicMirror $
Still have the same issue and can’t update…any help would be appreciated.
@swvalenti said in Help with Update to 2.7.0:
ok, lets try this
git stash git pull
if ok, then npm install
pi@raspberrypi:~ $ cd MagicMirror pi@raspberrypi:~/MagicMirror $ git stash fatal: Unable to create '/home/pi/MagicMirror/.git/index.lock': File exists. Another git process seems to be running in this repository, e.g. an editor opened by 'git commit'. Please make sure all processes are terminated then try again. If it still fails, a git process may have crashed in this repository earlier: remove the file manually to continue. Cannot save the current index state pi@raspberrypi:~/MagicMirror $ git pull Updating de57daa..b508a62 pi@raspberrypi:~/MagicMirror $ npm install > magicmirror@2.6.0 install /home/pi/MagicMirror > cd vendor && npm install npm notice created a lockfile as package-lock.json. You should commit this file. npm WARN optional SKIPPING OPTIONAL DEPENDENCY: fsevents@1.2.7 (node_modules/fsevents): npm WARN notsup SKIPPING OPTIONAL DEPENDENCY: Unsupported platform for fsevents@1.2.7: wanted {"os":"darwin","arch":"any"} (current: {"os":"linux","arch":"arm"}) audited 220 packages in 11.323s found 4 low severity vulnerabilities run `npm audit fix` to fix them, or `npm audit` for details > magicmirror@2.6.0 postinstall /home/pi/MagicMirror > sh installers/postinstall/postinstall.sh && npm run install-fonts MagicMirror installation successful! > magicmirror@2.6.0 install-fonts /home/pi/MagicMirror > cd fonts && npm install audited 1 package in 2.065s found 0 vulnerabilities npm notice created a lockfile as package-lock.json. You should commit this file. npm WARN grunt-stylelint@0.10.1 requires a peer of stylelint@^9.0.0 but none is installed. You must install peer dependencies yourself. audited 2427 packages in 54.343s found 12 vulnerabilities (6 low, 6 moderate) run `npm audit fix` to fix them, or `npm audit` for details pi@raspberrypi:~/MagicMirror $
still not working…
ok, erase that file, or rename it out of the way
then
git pull -
Thanks @sdetweil had to remove all the .json/locks and the .git after I had to enable show hidden files as I couldn’t find same. You da man Sam.
