    VoiceControl module
    79 Posts 27 Posters 126.3k Views 29 Watching
    • T
      tyho
      @alexyak i can’t get it to work. it tested:
      It sends sockets notifications from notifications.js to node_helper.js. But not from node_helper.js back to notifications.js.
      Even if i put it in the start function of the node_helper.js:
      start: function() {
        this.sendSocketNotification("autosleep", {});
      it won’t get received it my notification.js:
      socketNotificationReceived: function(notification) {
         if (notification === "autosleep") {
      	  alert("autosleep received");
      		awake = 0;
      any idea? is it even possible to use it backwards?
      • A
        alexyak
        Try to put a call in your start method of the module (notification.js) to establish the connection with node_helper. Something like that:
        this.sendSocketNotification(“CONNECT”, {});
        • A
          alexyak
          I’ve updated the VoiceControl module to display a list of commands on the mirror:
          [ card : alexyak/voicecontrol ]
          • A
            alexyak
            [card:alexyak/voicecontrol]
              brumoeller
              This is a really cool module. Does anyone know a good microphone that will work for the whole room? The mic I have only works when you are close.
              • G
                gismo2006
                @alexyak sorry, but i have a little Problem. Maybe you can help me.
                You write on Github in your Readme file, I have to put the code (notificationReceived: function(notification, payload, sender)…) into the module to use it. I like to controll the module Simple music player by @EoF so i clone your github files copy the code into the config.js File train and download a pmdl file. But where should i paste the code notificationReceived: function(notification, payload, sender)… In the config.js File or in the mmm-music-player.js file in folder modules simple music Player?
                Sorry i’m new in the coding world, and now a little bit confused :-D
                Greets gismo2006
                J 1 Reply Last reply
                  Jopyth Moderator @gismo2006
                  @gismo2006 This part has to go into mm-music-player.js. This is where you receive the notification. Then instead of this.media.play() you have to do access the play and stop functions of the mm-music-player (which unfortunately is seems a little bit complicated, since they are only elements on the web page).
                  Edit: Maybe the easiest is to give the Play and Stop button an id and then ‘fake’ a click event on the the buttons.
                  var playButton = document.getElementById('play-button');
                  playButton.click();
                  • G
                    gismo2006
                    Hi @Jopyth thank you for your helping.
                    But I think i’m to stupid… :-(
                    I have copy your first code line into the mm-music-player.js file. But now the module isn’t shown at the mirror. But the mirror shows all other module i installed at the same time… (I use pavrios Facial-Recogination module) If I cut out your line the mirrors behaviour is like it should be. On searching my misstake i found a line called: var playButton = document.createElement(“div”);. I cut this line and put in your line but nothing.
                    greets gismo
                      @gismo2006 Have you put this into the notificationReceived function, e.g. in line 26?
                              if (notification === "PLAY_MUSIC"){
                                      playButton.click();
                              if (notification === "STOP_MUSIC"){
                                      var stopButton = document.getElementById('stop-button');
                                      stopButton.click();
                      Also add the id somewhere here, e.g. with
                      playButton.id = 'play-button'
                      Same for the stop button.
                      • G
                        gismo2006
                        Hey, thank you for your help!
                        I really like to say many many thank that you spend your time to help me.
                        I will try it today evening again, because now my little son likes to play whit me. :-)
                        greets gismo
                        • T
                          tyho
                          @Pierre @simonsays
                          First of all sorry for the long waiting…
                          I guess u already have run the voice control module with the speech files (pmdl) from snopwboy and put this in your root.
                          Here is my config part for the VoiceControl module:
                                      module: 'voicecontrol',
                                          models: [
                                                  keyword: "gotosleep",   // keyword
                                                  file: "gotosleep.pmdl", // trained model file name
                                                  message: "go_to_sleep"   // notification message that's broadcast in the MagicMirror app
                                                  keyword: "wake up",   // keyword
                                                  file: "Wake_up.pmdl", // trained model file name
                                                  message: "wake_up"   // notification message that's broadcast in the MagicMirror app
                                  	module: 'notification',
                                  	position: 'bottom_right',    // This can be any of the regions.
                          Because the voicecontrol module send a notafication to all other modules i wrote a separate module to show text messages for what is happening:
                          notification.js
                          /* global Module */
                          /* Magic Mirror
                           * Module: notification
                          var awake = 1;
                          Module.register("notification",{
                          	// Default module config.
                          	defaults: {
                          		text: "",
                          		animationSpeed: 500,
                          	start: function() {
                                  this.sendSocketNotification("CONNECT", {});
                          	notificationReceived: function(notification, callback) {
                          		var self = this;
                          				if (notification === "go_to_sleep" && awake === 1){
                                      		this.config.text = "going to sleep...";
                          					this.updateDom(this.config.animationSpeed);
                          					setTimeout(function(){
                          						self.sendSocketNotification('go_to_sleep', {});
                          						self.config.text = "";
                          						self.updateDom(self.config.animationSpeed);
                          					}, 1000);
                          					awake = 0;
                          					callback(awake);
                          				if (notification === "wake_up" && awake === 0){
                          					this.sendSocketNotification('wake_up', {});
                                      		this.config.text = "waking up...";
                          					}, 5000);
                          					awake = 1;
                          					callback(awake);
                          					awake = 0;
                          	// Override dom generator.
                          	getDom: function() {
                          		wrapper.innerHTML = this.config.text;
                          		return wrapper;
                          In my node helper i put the exec code to turn on and off my monitor.
                          node_helper.js
                          'use strict';
                          const NodeHelper = require('node_helper');
                          const exec = require('child_process').exec;
                          var timer;
                          //function initialize() {
                          //(function(){
                          //	initialize();
                          //			autosleep();
                            start: function() {
                          		this.started = false;
                          	if (notification === "CONNECT") {
                          			clearTimeout(timer);
                          			this.autosleep();
                              if (notification === 'go_to_sleep') {
                                      exec("/opt/vc/bin/tvservice -o", null);
                          	if (notification === 'wake_up') {
                                      exec("/opt/vc/bin/tvservice -p", null);
                          			exec("/bin/fbset -depth 8 && /bin/fbset -depth 16 ", null);
                                		exec("/usr/bin/xrefresh",null);
                          			this.autosleep();
                            autosleep: function(){
                          	  var self = this;
                          	  timer=setTimeout(function(){
                          			    self.sendSocketNotification("autosleep", {});
                          			},  10*60*1000);
                          I also put conditions in it so it can only wake up when it’s asleep. There is also a autosleep function thats now on 10 minutes.
                          • G
                            gismo2006
                            @Jopyth
                            Thank you everything workes fine. A big thank you!!!
                            greets gismo
                            • G
                              gismo2006
                              @Jopyth
                              Maybe you can help me again?
                              If I put only one comand like Play everything ist fine. But if I put more than one comand, like Play and Stop the Player is completly confused. Then only a handclap or a any other word is need to start a track or to beginn from beginning again…
                              greets gismo
                                simonsays
                                  simonsays
                                  @alexyak @tyho I was able to get my sleep and wake up function to work using tyho’s code as well as able to find a way to turn the LED on. However, I cannot seem to turn it off once on. I am driving the switch with a gpio pin and transistor. It seems that after the pi executes the action, it wont listen for anything else. Example is if I tell it to turn the LED on, it does so. Then i say go to sleep, and it won’t. I go for the reboot and try again and start with the sleep command first. Then I try to turn the LED on and it won’t do that. Is there a way to have the function in tyho’s node_helper.js loop back again to the beginning? I feel like it get’s stuck once it executes a function. I also have an issue with the screen being yellow and zoomed in when i wake up the mirror after sleep. Don’t think it is a hardware issue, but I haven’t swapped HDMI cables yet.
                                  For reference:
                                  Code for modified node_helper.js:
                                  if (notification === “CONNECT”) {
                                  this.autosleep();
                                  if (notification === ‘go_to_sleep’) {
                                  exec(“/opt/vc/bin/tvservice -o”, null);
                                  if (notification === ‘wake_up’) {
                                  exec(“/opt/vc/bin/tvservice -p”, null);
                                  exec(“/bin/fbset -depth 8 && /bin/fbset -depth 16 “, null);
                                  exec(”/usr/bin/xrefresh”,null);
                                  this.autosleep();
                                  if (notification === ‘lights_on’) {
                                  exec(“echo ‘18’ > /sys/class/gpio/export”, null);
                                  exec(“echo ‘out’ > /sys/class/gpio/gpio18/direction”, null);
                                  gpio.setup(‘sys’);
                                  gpio.digitalWrite(18,1);
                                  if (notification === ‘lights_off’) {
                                  gpio.setup(‘sys’);
                                  gpio.digitalWrite(18,0);
                                  var self = this;
                                  self.sendSocketNotification(“autosleep”, {});
                                  }, 10601000);
                                  Any help is greatly appreciated.
                                  • G
                                    gismo2006
                                    maybe someone can help me… :-)
                                    So far the musiccontroll works fine. Now I spent my time for a new project. I Copy the code from @tyho and save it as notification.js and node_helper.js. The I copy the code into my config file like he posted. Th two files I coppied into an new folder called notification, that I took under Modules. Then I train two Hotword for wake up and go sleeping an copy and paste the two pmdl files correctly. The Mirror stats fine and everything is working But the two Hotwords didn’t take their job.
                                    Greets gismo
                                    • tglT
                                      tgl
                                      Hello :-)
                                      At first - great job!
                                      And the second - my English is not the best :-/
                                      But I hope of Help.
                                      I´ve allready installt the module.
                                      Then I become the Error of Alsa.
                                      Can anybody help me please?
                                      Here my log:
                                      [0_1476519121142_mm-error-0.log](Uploading 100%)
                                      Thank you for help
                                      • MichMichM
                                        MichMich
                                        It would be nice if you can extend the module with hide/show options:
                                            keyword: "simpleMode",   // keyword
                                            description: "Say 'Simple Mode' to switch to the simple UI.",
                                            file: "simpleMode.pmdl", // trained model file name
                                            message: false,   // Unused in this command. Can be omitted.
                                            show: "simple foo bar",  // Show these modules.
                                            hide: "advanced" // Hide these modules.
                                        When activating this command, it shows all modules with de classes defined in the show variable. And it hides all modules defined in the hide variable.
                                        When implementing this, make sure you use the Visibility Locking mechanism that will be introduced in version 2.1.0: https://forum.magicmirror.builders/topic/241/2-1-0-api-revising-the-show-hide-mechanism/9
                                        • tglT
                                          tgl
                                          Hello again,
                                          is it possible to post my log here?
                                          • G
                                            gismo2006
                                            Good evenning, morning,
                                            I have now spent many hours to create @tyho notification module. And now it works.
                                            Maybe the following can help someone, to…
                                            If I say wake up the monito wake up but the the monitor picture was terrible and i had to reboot.
                                            Now I have edit one line in the node_helper.js and everthing works fine. Here my changes:
                                            exec(“sudo /bin/chvt 6 && sudo /bin/chvt 7”, null);
                                            this.autosleep();
                                            greets gismo
                                            • 2 / 4
