Solved ELIFECYCLE error after fresh install
@MrKnight230 sorry, do not know… there were lots of code changes by modules MM uses and have no control over.
I cannot recreate this over ssh…
my npm is version 6.9.0
you might try
npm install -g npm
@sdetweil Thanks for the suggestion, it successfully installed version 6.9.0 but sadly didn’t solve or even change anything about the problem.
@MrKnight230 ok, i can only think that the vnc start is not working now…
@sdetweil Well I deactivated VNC, restarted and plugged my keyboard in the RasPi and this too didn’t change anything sadly.
@MrKnight230 ok, and u did the DISPLAY=:0
@sdetweil I actually didn’t but the result stays the same with “DISPLAY=:0”
@MrKnight230 and after u did the git pull of the new version, you did npm install in the MM folder and all modules with a package.json file, right?
@sdetweil I did run npm install again now and the output looks like this:
pi@raspberrypi:~/MagicMirror $ npm install > magicmirror@2.7.1 install /home/pi/MagicMirror > cd vendor && npm install npm WARN optional SKIPPING OPTIONAL DEPENDENCY: fsevents@1.2.4 (node_modules/fsevents): npm WARN notsup SKIPPING OPTIONAL DEPENDENCY: Unsupported platform for fsevents@1.2.4: wanted {"os":"darwin","arch":"any"} (current: {"os":"linux","arch":"arm"}) audited 219 packages in 10.29s found 5 vulnerabilities (4 low, 1 high) run `npm audit fix` to fix them, or `npm audit` for details > magicmirror@2.7.1 postinstall /home/pi/MagicMirror > sh installers/postinstall/postinstall.sh && npm run install-fonts MagicMirror installation successful! > magicmirror@2.7.1 install-fonts /home/pi/MagicMirror > cd fonts && npm install audited 1 package in 1.092s found 0 vulnerabilities npm WARN acorn-jsx@5.0.1 requires a peer of acorn@^6.0.0 but none is installed. You must install peer dependencies yourself. npm WARN grunt-stylelint@0.10.1 requires a peer of stylelint@^9.0.0 but none is installed. You must install peer dependencies yourself. added 7 packages from 10 contributors, updated 6 packages and audited 3468 packages in 63.499s found 0 vulnerabilities
But it again didn’t change anything.
@MrKnight230 - The good news is that the
npm install
completed successfully. Hmm.Have you tried running Magic Mirror in server only mode and then hitting your mirror with a web browser?
IMHO, I think the “fix vulnerabilities” feature of npm is causing more trouble than it is worth.
Hi guys, I just wanted to say thank you to @bhepler and @sdetweil for trying to help me with this problem.
In the end I just used a very old backup at first and updated it, which worked fine at first and yesterday I tried setting my RPi up from scratch again and it worked perfectly!
I’m sorry for anybody who encounters the same error and tries finding answers here, sadly there doesn’t seem to be a perfect solution for this.
MrKnight230
