    ELIFECYCLE error after fresh install
    elifecycle
    17 Posts 4 Posters 8.2k Views 3 Watching
      sdetweil @MrKnight230
      @MrKnight230 can u show the output of npm -v
        sdetweil @Zwirbel
        @Zwirbel if you go the MagicMirror folder and do a pm2 stop, then npm start what happens?
          MrKnight230 @sdetweil
          @sdetweil The Version is 6.4.1
            @MrKnight230 thx… are u doing this over vnc? also the MM has to be running in graphical mode, unless u are running server only… (DISPLAY 0 will not exist if in VNC or text mode)
              The RasPi is connected via HDMI to a Display and I’m using VNC to configure it. I had a previous install where everything worked with pm2 and manually using the command “npm start”.
                @MrKnight230 sorry, do not know… there were lots of code changes by modules MM uses and have no control over.
                I cannot recreate this over ssh…
                my npm is version 6.9.0
                you might try
                npm install -g npm
                  @sdetweil Thanks for the suggestion, it successfully installed version 6.9.0 but sadly didn’t solve or even change anything about the problem.
                    @MrKnight230 ok, i can only think that the vnc start is not working now…
                      @sdetweil Well I deactivated VNC, restarted and plugged my keyboard in the RasPi and this too didn’t change anything sadly.
                        @MrKnight230 ok, and u did the DISPLAY=:0
