    MM not loading on startup or manually
    4 Posts 2 Posters 1.9k Views 2 Watching
      awephuk
      I followed the Jessie Lite Installation Guide, however when I reboot MM doesn’t start and when I try to start it (by running the mm script) I get errors. My mm.sh script looks like this:
      cd /home/pi/MagicMirror
      DISPLAY=:0 npm start
      These are the errors that I get:
      pi@PI:~ $ ./mm.sh
      > magicmirror@2.3.1 start /home/pi/MagicMirror
      > sh run-start.sh
      npm ERR! code ELIFECYCLE
      npm ERR! errno 1
      npm ERR! magicmirror@2.3.1 start: `sh run-start.sh`
      npm ERR! Exit status 1
      npm ERR!
      npm ERR! Failed at the magicmirror@2.3.1 start script.
      npm ERR!     /home/pi/.npm/_logs/2018-05-17T13_44_49_830Z-debug.log
      and here is the debug log:
      1 verbose cli [ '/usr/bin/node', '/usr/bin/npm', 'start' ]
      2 info using npm@5.6.0
      3 info using node@v9.11.1
      5 info lifecycle magicmirror@2.3.1~prestart: magicmirror@2.3.1
      6 info lifecycle magicmirror@2.3.1~start: magicmirror@2.3.1
      7 verbose lifecycle magicmirror@2.3.1~start: unsafe-perm in lifecycle true
      8 verbose lifecycle magicmirror@2.3.1~start: PATH: /usr/lib/node_modules/npm/node_modules/npm-lifecycle/node-gyp-bin:/home/pi/MagicMirror/node_modules/.bin:/usr/local/sbin:/usr/local/bin:/usr/sbin:/usr/bin:/sbin:/bin:/usr/local/games:/usr/games
      9 verbose lifecycle magicmirror@2.3.1~start: CWD: /home/pi/MagicMirror
      10 silly lifecycle magicmirror@2.3.1~start: Args: [ '-c', 'sh run-start.sh' ]
      11 silly lifecycle magicmirror@2.3.1~start: Returned: code: 1  signal: null
      12 info lifecycle magicmirror@2.3.1~start: Failed to exec start script
      13 verbose stack Error: magicmirror@2.3.1 start: `sh run-start.sh`
      13 verbose stack Exit status 1
      13 verbose stack     at EventEmitter. (/usr/lib/node_modules/npm/node_modules/npm-lifecycle/index.js:285:16)
      13 verbose stack     at EventEmitter.emit (events.js:180:13)
      13 verbose stack     at ChildProcess. (/usr/lib/node_modules/npm/node_modules/npm-lifecycle/lib/spawn.js:55:14)
      13 verbose stack     at ChildProcess.emit (events.js:180:13)
      13 verbose stack     at maybeClose (internal/child_process.js:936:16)
      13 verbose stack     at Process.ChildProcess._handle.onexit (internal/child_process.js:220:5)
      14 verbose pkgid magicmirror@2.3.1
      15 verbose cwd /home/pi/MagicMirror
      16 verbose Linux 4.9.35-v7+
      17 verbose argv "/usr/bin/node" "/usr/bin/npm" "start"
      18 verbose node v9.11.1
      19 verbose npm  v5.6.0
      20 error code ELIFECYCLE
      21 error errno 1
      22 error magicmirror@2.3.1 start: `sh run-start.sh`
      22 error Exit status 1
      23 error Failed at the magicmirror@2.3.1 start script.
      23 error This is probably not a problem with npm. There is likely additional logging output above.
      24 verbose exit [ 1, true ]
      I know Linux pretty well, but unfortunately I can’t say the same about Node.js. I appreciate any help.
      justjim1220J 1 Reply Last reply Reply Quote 0
      • justjim1220J Offline
        justjim1220 Module Developer @awephuk
        @awephuk said in MM not loading on startup or manually:
        try this
        cd MagicMirror
        DISPLAY=: npm start
        Jim Hallock - 1995
          awephuk
          @justjim1220 said in MM not loading on startup or manually:
          DISPLAY=: npm start
          Thanks for the reply. I tried it and I received the error below:
          pi@PI:~/MagicMirror $ DISPLAY=: npm start
          > sh run-start.sh
          npm ERR! errno 1
          npm ERR!
          npm ERR!     /home/pi/.npm/_logs/2018-05-19T05_58_17_110Z-debug.log
          What’s weird is when I try to look at the debug log referenced in the error (/home/pi/.npm/_logs/2018-05-19T05_58_17_110Z-debug.log), there isn’t a filename called 2018-05-19T05_58_17_110Z-debug.log under the _logs directory. I just turned it on for the first time today when I tried running the command you suggested and all of the log files had today’s date on them so I copied them all below. Could it be a permission problem? The error is just telling me that it failed to start the run-start.sh script, which doesn’t help me too much. Hopefully I’m overlooking something.
          pi@PI:~/.npm/_logs $ cat *
          21 error errno 1
          21 error errno 1
          21 error errno 1
          21 error errno 1
          21 error errno 1
          21 error errno 1
          21 error errno 1
          21 error errno 1
          21 error errno 1
            @awephuk
            I think you might be able to rebuild MM…
            cd MagicMirror
            npm rebuild
            it takes a few minutes, but that is one thing that has helped me in the past fix several different errors.
            Also, you can re-install the MM and your modules, especially the last one you added prior to getting this error…
            Start with the last module… cd modules/[last-module-name] >>> npm install
            Then run the npm install with MM. Or, the npm rebuild
            then restart MM
            Also, try rebooting the Pi by shutting it off, then turn it back on.
            (works better to help fix errors than using restart)
            Jim Hallock - 1995
