    MMM-MyGarbage
    62 Posts 28 Posters 54.5k Views 30 Watching
      Chris62
      Thanks for your reply. I have fixed it now. I loaded the csv file into excel to alter the dates but something was wrong with the formatting and I just couldn’t get it to work. Anyway, I loaded up MM into a Ubuntu virtual machine and changed the dates in notepad. I sorted out the config issue (I moved the position within the config file to make it easier to read but accidentally did copy rather than cut and paste so I had two loading), fired it up and it worked like a charm. I have now copied everything to my Pi and it now works there too.
      Just a quick question, I only have two bins, blue and green, is it possible to remove the column for the other one without mucking it up, or should I just set all the values to zero?
      Chris
      htilburgsH 1 Reply Last reply Reply Quote 0
      • htilburgsH
        htilburgs @Chris62
        @Chris62 Good to hear it’s fixed.
        You can do both
        • Remove the unused column entirly
        • Fill the unused column with zero’s
        As of version v1.2.0 you can also use you’re own column names, as long as they are color names. The garbage bin is showed in the color of the name of the column.
        example
        WeekStarting,Green,Brown
        04/15/19,1,1
        (still trying to learn JS, but not afraid to ask and AI is my best friend) ☺
        • W
          werffje
          OMG I’m such a noob forgive me, I forgot the alert: 4 line in my config.js
          It works great now, thanks !!
          • htilburgsH
            htilburgs @werffje
            @werffje :thumbs_up_light_skin_tone:
              rvanuden
              best module ever :-)
              • htilburgsH
                htilburgs @rvanuden
                @rvanuden :hugging_face: :thumbs_up_light_skin_tone:
                  RdP
                  We have 4 garbage bins. (Green,Black, Bleu and Yellow), is it possible to use 4 types instead of 3?
                  • htilburgsH
                    htilburgs @RdP
                    @RdP
                    You can use this module by creating your own Garbage Schedule file with the name garbage_schedule.csv An example file garbage_schedule.csv is added.
                    Create a CSV based on the following template:
                    WeekStarting,green,gray,blue
                    03/07/18,1,0,1
                    03/14/18,1,1,1
                    03/21/18,1,0,1
                    03/28/18,1,1,1
                    Default there are 3 bins defined (green, gray and blue) If you need more garbage bins, simply add an extra column in the garbage_schedule.csv file. The name is the color you like the bin to have. In you case ‘yellow’.
                    Add lines for each garbage pickup date as needed. The date format needs to be specified as MM/DD/YY (e.g.: 05/28/18 for 28-May-2018)
                    Succes!
                      RdP @htilburgs
                      @htilburgs
                      Yes works like a charm…
                      Thank you
                      • htilburgsH
                        htilburgs @RdP
                        @RdP, great it worked out for you!
                        • twosquirrelsT
                          twosquirrels
                          This is great! It’s since replaced MMM-MyWastePickup as that no longer works .
                            mistered
                            Hi guys i know this is an old topic but maybe i can get an answer anayway
                            i want 4 bins but just adding a color and and a 1 or 0 in the csv file does not work
                              mistered
                              ok got it to work now
                              • K
                                kalin
                                Hello guys!
                                could anyone help and check what is wrong with my configuration of this module? Under the title I have only message: loading
                                My configuration looks like:
                                module: ‘MMM-MyGarbage’,
                                position: ‘bottom_left’,
                                header: ‘My Garbage Calendar’,
                                alert: 3,
                                weeksToDisplay: 2,
                                limitTo: 99,
                                fade: true,
                                dateFormat: “dddd”,
                                fadePoint: 0.25
                                  ReD1470
                                  Hey there,
                                  Great work on this module. But you say you are not an experienced programmer? well, compared to me…
                                  not to sound lazy, but any change you could convert from csv to json query like thingy?
                                  as seen on the home automation sites, people query http://json.mijnafvalwijzer.nl/?method=postcodecheck&postcode=&street=&huisnummer=&toevoeging=&platform=phone&langs=nl&
                                  and get the results needed
                                  (https://community.home-assistant.io/t/garbage-pickup-date-mijnafvalwijzer-nl-custom-component/34631/12)
                                  please be honest, no is also an answer and I would completely understand.
                                  … but i thought you might like a challenge ;-)
                                  • L
                                    lodam @htilburgs
                                    @htilburgs : thanks a lot for this module !
                                    this is super useful and well done.
                                    I would like to change color for bins, i did the custom.css file and restarted MM2 but that does not change.
                                    Do i have to do something else ?
                                    thanks a lot for your help.
                                    Here you can file a translation for French if this could help :
                                    “GARBAGEENTRIESLEFT”: “Il reste {entriesLeft} dates dans le calendrier des ordures”,
                                    “REMEMBERADDINGPICKUPS”: “Veuillez ajouter de nouvelles dates pour l’utiliser”
                                    REBR 1 Reply Last reply Reply Quote 0
                                    • REBR
                                      REB @lodam
                                      @lodam said in MMM-MyGarbage:
                                      You can change the colour of the bin icons in the garbage_schedule.csv file like so. The top row defines the colour of the icons. In my case below they are green, dark grey and light blue.
                                      WeekStarting,#00FF00,#D3D3D3,#87CEEB
                                      03/31/20,0,0,1
                                      04/07/20,0,1,0
                                      04/14/20,0,0,1
                                      04/21/20,0,1,0
                                      04/28/20,0,0,1
                                      05/05/20,0,1,0
                                      • L
                                        lodam
                                        thanks for your help @REB but in my case, i have
                                        "WeekStarting,GreenBin, GarbageBin, Paperbin,
                                        So i guess i have to change that somewhere else ;)
                                        • L
                                          lodam
                                          oups so sorry, i misunderstood…
                                          You are 100% right, i just changed and did the same as you did.
                                          thanks a lot !
                                            Sezer84
                                            Hallo leute ,ich weiss das ist ziemlich alt das thema aber ich habe es jetzt erst endeckt.
                                            ich habe dieses modul installiert wie es beschrieben wurde aber es zeigte erst nur eine tonne und heute zeigt er zwei. und die farbe gelb ,orange, blau und braun brächte ich für deutschland.wie kriege ich es hin vier tonnen in den gewünschten farben hinzukriegen.
                                            bedanke mich im vorraus.
                                            Feedy88F 1 Reply Last reply Reply Quote 0
                                            • 1 / 4
