    MMM-MyGarbage
    62 Posts 28 Posters 54.1k Views 30 Watching
    • htilburgsH Offline
      htilburgs
      @pugsly
      This is possible, follow the next steps.
      Go to the MagicMirror CSS directory
      cd ~\MagicMirror\css\
      Edit (or create) the custom.css file
      sudo nano custom.css
      Add the next section at the bottom of the custom.css file
      /* MMM-MyGarbage CSS Modification */
      .MMM-MyGarbage .garbage-container .garbage-icon-container .garbage-icon.greenbin {
        fill: #00A651;
      .MMM-MyGarbage .garbage-container .garbage-icon-container .garbage-icon.garbagebin {
        fill: #787878;
      .MMM-MyGarbage .garbage-container .garbage-icon-container .garbage-icon.paperbin {
        fill: #0059ff;
      /* End MMM-MyGarbage */
      Now you can modify the colors for your Garbage Bins. In your case, you would like the grey bin to be yellow. The code should be:
        fill: #fffa00;
      Save and quit the nano editor and restart your MagicMirror.
      Now you should have a yellow trashbin instead of a grey trashbin.
      Succes!
      (still trying to learn JS, but not afraid to ask and AI is my best friend) ☺
      • Z Offline
        Zwirbel
        Do you know if it is also possible to change the icon with CSS? E.g. using a “paper” icon from FontAwesome?
          htilburgs
          Currently this is not possible, because the icons are embedded in file ‘garbage_icons.svg’. You can create you’re own garbage_icons.svg file. Keep in mind that the icons are 24x24 pixels.
            Chris62
            @htilburgs
            I would really like to use this module. However, despite following the install instructions, and without changing any of the defaults other than the header (we usually say rubbish in the UK, rather than garbage), I get two instances of the module loading. Also, when I open the default csv file in Excel for instance, the dates do not all seem to be the same. Some are formatted left and some are formatted right in the cell. Surely they should all be the same. I have not altered this file at all but when the module loads in MM2, (twice as mentioned) I just get an entry for ‘Today’ and a grey bin icon.
            Chris
            htilburgsH 1 Reply Last reply Reply Quote 0
              htilburgs @Chris62
              @Chris62 can you post a picture and the config.js?
              • W Offline
                werffje
                I have done everything as described but the module keeps on indicating Loading Loading, what am I doing wrong?
                Regards, Marius
                  htilburgs @werffje
                  @werffje I’m sorry to hear that, but if it’a keep saying loading, than there is a configuration error. Can you post your config. js.
                  Further take a look at the java console in you browser if you can see an error.
                    htilburgs
                    On my TEST System, I just did a fresh install of MM2 and after that a fresh install of MMM-MyGarbage. Copy and Paste the configuration as in the README.md into the config.js and no errors. MMM-MyGarbage displays 2 entries with the garbage_schedule.csv that is installed with the git clone…
                    @Chris62, @werffje, if you still expirience problems, than:
                    • add config.js into reply
                    • look at the javascript console if you see any errors in the Console tab
                    Open Javascript Console:
                    Press Command+Option+J (Mac) or Control+Shift+J (Windows, Linux, Chrome OS) to open the Console
                    • any other information that maybe relevant
                    I’ll look at it and try to reproduce and/or correct the issue.
                      Chris62
                      Thanks for your reply. I have fixed it now. I loaded the csv file into excel to alter the dates but something was wrong with the formatting and I just couldn’t get it to work. Anyway, I loaded up MM into a Ubuntu virtual machine and changed the dates in notepad. I sorted out the config issue (I moved the position within the config file to make it easier to read but accidentally did copy rather than cut and paste so I had two loading), fired it up and it worked like a charm. I have now copied everything to my Pi and it now works there too.
                      Just a quick question, I only have two bins, blue and green, is it possible to remove the column for the other one without mucking it up, or should I just set all the values to zero?
                      Chris
                        htilburgs @Chris62
                        @Chris62 Good to hear it’s fixed.
                        You can do both
                        • Remove the unused column entirly
                        • Fill the unused column with zero’s
                        As of version v1.2.0 you can also use you’re own column names, as long as they are color names. The garbage bin is showed in the color of the name of the column.
                        example
                        WeekStarting,Green,Brown
                        04/15/19,1,1
                        • W Offline
                          werffje
                          OMG I’m such a noob forgive me, I forgot the alert: 4 line in my config.js
                          It works great now, thanks !!
                            htilburgs @werffje
                            @werffje :thumbs_up_light_skin_tone:
                              rvanuden
                              best module ever :-)
                                htilburgs @rvanuden
                                @rvanuden :hugging_face: :thumbs_up_light_skin_tone:
                                  RdP
                                  We have 4 garbage bins. (Green,Black, Bleu and Yellow), is it possible to use 4 types instead of 3?
                                    htilburgs @RdP
                                    @RdP
                                    You can use this module by creating your own Garbage Schedule file with the name garbage_schedule.csv An example file garbage_schedule.csv is added.
                                    Create a CSV based on the following template:
                                    WeekStarting,green,gray,blue
                                    03/07/18,1,0,1
                                    03/14/18,1,1,1
                                    03/21/18,1,0,1
                                    03/28/18,1,1,1
                                    Default there are 3 bins defined (green, gray and blue) If you need more garbage bins, simply add an extra column in the garbage_schedule.csv file. The name is the color you like the bin to have. In you case ‘yellow’.
                                    Add lines for each garbage pickup date as needed. The date format needs to be specified as MM/DD/YY (e.g.: 05/28/18 for 28-May-2018)
                                    Succes!
                                      RdP @htilburgs
                                      @htilburgs
                                      Yes works like a charm…
                                      Thank you
                                        htilburgs @RdP
                                        @RdP, great it worked out for you!
                                        • twosquirrelsT Offline
                                          twosquirrels
                                          This is great! It’s since replaced MMM-MyWastePickup as that no longer works .
                                            mistered
                                            Hi guys i know this is an old topic but maybe i can get an answer anayway
                                            i want 4 bins but just adding a color and and a 1 or 0 in the csv file does not work
                                            • 1 / 4
