    MMM-MyGarbage
    60 Posts 28 Posters 40.8k Views 28 Watching
    • htilburgsH Offline
      htilburgs
      MMM-MyGarbage
      This a module for MagicMirror².
      This displays the schedule for your Garbage pickup. It supports multiple types of garbage bins.
      You can show the schedule using a CSV file (garbage_schedule.csv) of by using an ical URL.
      SCR-20260308-ppuu
      Installation
      Clone this repository in your modules folder, and install dependencies:
      cd ~/MagicMirror/modules
      git clone https://github.com/htilburgs/MMM-MyGarbage.git
      cd MMM-MyGarbage
      npm install
      Update
      When you need to update this module:
      cd ~/MagicMirror/modules/MMM-MyGarbage
      git pull
      npm install
      Configuration
      Go to the MagicMirror/config directory and edit the config.js file.
      Add the module to your modules array in your config.js.
              module: 'MMM-MyGarbage',
              position: 'top_right',
              header: "My Garbage Calendar",
              disabled: false,
                      weeksToDisplay: 4,
                      limitTo: 99,
                      dateFormat: "dddd LL",
                      alert: true,
                      alertThreshold: 5,
                      fade:true,
                      fadePoint: 0.25,
                      dataSource: "csv",                          // csv (schedule_garbage.csv | ical (put URL in icalUrl)
                      icalUrl: "PLACE_HERE_PUBLIC_ICAL_URL",      // only used if dataSource is "ical"
                      debug: false,                               // Only set on true for debugging
                      binColors: {                                // Define custom Bin Colors and match with the Bin Names
                                  "GreenBin" : "#00A651",
                                  "PaperBin" : "#0059FF",
                                  "GarbageBin" : "#787878",
                                  "PMDBin" : "#FFFF00",
                                  "OtherBin" : "#B87333"
      Module configuration
      Here is the documentation of options for the modules configuration:
      Option Description
      weeksToDisplay How many weeks into the future to show collection dates.
      Number
      Default: 2
      limitTo Limit the display to the spcified number of pickups
      Number
      Default: 99
      dateFormat Format to use for the date of events
      Default: dddd D MMMM (e.g. January 18)
      Possible values: See https://momentjs.com/
      alert Show alert, if remaining entries in CSV file fall under threshold
      Default: false
      Possible values: true or false
      alertThreshold (optional) Threshold entries left in CSV file
      Number
      Default: 5
      fade Fade the future events to black. (Gradient).
      Default: true
      <Possible values: true or false
      fadePoint Where to start fade
      Default: 0.25
      Posibble values: Between 0 (top of the list) and 1 (bottom of list)
      dataSource Select the datasource you’re using
      Default: csv
      Possible values: csv or ical
      icalUrl Fill in your (public) ical URL
      Only use in combination with dataSource: ical
      debug For debugging the module when failure or testing
      Default: false
      Possible values: false or true
      binColors Define your own Bin Colors - Bin names have to match you’re names from CSV.
      When using ical match also icalBinMap
      Creating and using your Garbage Schedule for use with dataSource CSV
      You can use this module by creating your own Garbage Schedule file with the name garbage_schedule.csv
      An example file garbage_schedule.csv is added.
      Create a CSV based on the following template:
      WeekStarting,GreenBin,GarbageBin,PaperBin,PMDBin,OtherBin
      03/07/18,1,0,1,0,0
      03/14/18,1,1,1,0,0
      03/21/18,1,0,1,0,1
      03/28/18,1,1,1,1,0
      Default there are 5 bins defined. If you need more garbage bins, simply add an extra column in the garbage_schedule.csv file, with the name of the extra bin. If you only need 3, then simply remove them. When the module is started, it reads the names and will try them to match to the binColors.
      As of v3.0.0 of the module you can add custom names in the CSV of rename current names. As long as you change your binColors in config.js with the correspending names, you will see the information with the correct collors.
      Remark
      Any Bin name that is not or not correct matched with the name in binColors, will be shown in the color PURPLE
      Add lines for each garbage pickup date as needed.
      The date format needs to be specified as MM/DD/YY (e.g.: 05/28/18 for 28-May-2018)
      Colors can be defined in the config.js file:
      • Legacy Values:
        • GreenBin (defaults to #00A651)
        • GarbageBin (defaults to #787878)
        • PaperBin (defaults to #0059ff)
        • PMDBin (defaults to #ffff00)
        • OtherBin (defaults to #F542CE)
      • Any CSS color string (red, chocolate, cornflowerblue, etc…)
      • Any HEX-Color (#FF0000, #8c8c8c, etc)
      • Any rgb, rgba or hsl value if in double quotes (“rgb(128,65,98)”, “rgba(134,56,32,0.5)”, “hsl(0, 100%, 50%)”, etc.)
      The following is VERY important:
      • The CSV file must be delimited using commas
      • The date format must to be specified as MM/DD/YY (e.g.: 05/28/18 for 28-May-2018)
      • The remaining fields of each line specify whether the particular waste product is scheduled to be picked up on the given date. A value of 0 means no pick up. A value of ANYTHING ELSE means the product will be picked up. Using the first pick up date entry in the template above, 1,0,1,0,0 means that green and blue will be picked up on that date, while the others will not be picked up.
      Save the file as garbage_schedule.csv in the MMM-MyGarbage directory and restart Magic Mirror²
      License
      The MIT License (MIT)
      Copyright © 2019-2026 Harm Tilburgs
      Permission is hereby granted, free of charge, to any person obtaining a copy of this software and associated documentation files (the “Software”), to deal in the Software without restriction, including without limitation the rights to use, copy, modify, merge, publish, distribute, sublicense, and/or sell copies of the Software, and to permit persons to whom the Software is furnished to do so, subject to the following conditions:
      The above copyright notice and this permission notice shall be included in all copies or substantial portions of the Software.
      The software is provided “as is”, without warranty of any kind, express or implied, including but not limited to the warranties of merchantability, fitness for a particular purpose and noninfringement. In no event shall the authors or copyright holders be liable for any claim, damages or other liability, whether in an action of contract, tort or otherwise, arising from, out of or in connection with the software or the use or other dealings in the software.
      Note
      The original script is from Jeff Clarke MMM-MyWastePickup and only for the Toronto area.
      Now it has become a general script, to use in all areas all over the world.
      Versions
      v3.0.0 (07-03-2026)
      • Add support for flexible numbers of Bins
      • Bin names are automaticly detected
      • Match bin colors to bin names for csv and ical
      • Error message instead of “Loading…” when the CSV or ICAL is in wrong format
      • Better debug information in console and in module
      • Clean up code
      v2.1.2 (02-03-2026)
      • Update for rare AxiosError [AggregateError] when loading iCal
      v2.1.1 (17-02-2026)
      • Bugfix for the alertTreshold
      v2.1.0 (16-02-2026)
      • Update for CSV file and alertThreshold (add to config.js!)
      v2.0.1 (2025)
      • Update for Streamline date parsing and allow for recurring events in ical (thx to @thepagan)
      v2.0.0 (2025)
      • Changed for use with CSV or with iCal Calendar
      v1.0.0 (Initial Release 2019)
      (still trying to learn JS, but not afraid to ask and AI is my best friend) ☺
      pugslyP 1 Reply Last reply Reply Quote 3
      • pugslyP Offline
        pugsly @htilburgs
        @htilburgs
        Is there a way to change the can colors? Ours here are Blue, Green, and Yellow.
          htilburgs
          @pugsly
          This is possible, follow the next steps.
          Go to the MagicMirror CSS directory
          cd ~\MagicMirror\css\
          Edit (or create) the custom.css file
          sudo nano custom.css
          Add the next section at the bottom of the custom.css file
          /* MMM-MyGarbage CSS Modification */
          .MMM-MyGarbage .garbage-container .garbage-icon-container .garbage-icon.greenbin {
            fill: #00A651;
          .MMM-MyGarbage .garbage-container .garbage-icon-container .garbage-icon.garbagebin {
            fill: #787878;
          .MMM-MyGarbage .garbage-container .garbage-icon-container .garbage-icon.paperbin {
            fill: #0059ff;
          /* End MMM-MyGarbage */
          Now you can modify the colors for your Garbage Bins. In your case, you would like the grey bin to be yellow. The code should be:
            fill: #fffa00;
          Save and quit the nano editor and restart your MagicMirror.
          Now you should have a yellow trashbin instead of a grey trashbin.
          Succes!
          • Z Offline
            Zwirbel
            Do you know if it is also possible to change the icon with CSS? E.g. using a “paper” icon from FontAwesome?
              htilburgs
              Currently this is not possible, because the icons are embedded in file ‘garbage_icons.svg’. You can create you’re own garbage_icons.svg file. Keep in mind that the icons are 24x24 pixels.
                Chris62
                @htilburgs
                I would really like to use this module. However, despite following the install instructions, and without changing any of the defaults other than the header (we usually say rubbish in the UK, rather than garbage), I get two instances of the module loading. Also, when I open the default csv file in Excel for instance, the dates do not all seem to be the same. Some are formatted left and some are formatted right in the cell. Surely they should all be the same. I have not altered this file at all but when the module loads in MM2, (twice as mentioned) I just get an entry for ‘Today’ and a grey bin icon.
                Chris
                htilburgsH 1 Reply Last reply Reply Quote 0
                  htilburgs @Chris62
                  @Chris62 can you post a picture and the config.js?
                  • W Offline
                    werffje
                    I have done everything as described but the module keeps on indicating Loading Loading, what am I doing wrong?
                    Regards, Marius
                      htilburgs @werffje
                      @werffje I’m sorry to hear that, but if it’a keep saying loading, than there is a configuration error. Can you post your config. js.
                      Further take a look at the java console in you browser if you can see an error.
                        htilburgs
                        On my TEST System, I just did a fresh install of MM2 and after that a fresh install of MMM-MyGarbage. Copy and Paste the configuration as in the README.md into the config.js and no errors. MMM-MyGarbage displays 2 entries with the garbage_schedule.csv that is installed with the git clone…
                        @Chris62, @werffje, if you still expirience problems, than:
                        • add config.js into reply
                        • look at the javascript console if you see any errors in the Console tab
                        Open Javascript Console:
                        Press Command+Option+J (Mac) or Control+Shift+J (Windows, Linux, Chrome OS) to open the Console
                        • any other information that maybe relevant
                        I’ll look at it and try to reproduce and/or correct the issue.
                          Chris62
                          Thanks for your reply. I have fixed it now. I loaded the csv file into excel to alter the dates but something was wrong with the formatting and I just couldn’t get it to work. Anyway, I loaded up MM into a Ubuntu virtual machine and changed the dates in notepad. I sorted out the config issue (I moved the position within the config file to make it easier to read but accidentally did copy rather than cut and paste so I had two loading), fired it up and it worked like a charm. I have now copied everything to my Pi and it now works there too.
                          Just a quick question, I only have two bins, blue and green, is it possible to remove the column for the other one without mucking it up, or should I just set all the values to zero?
                          Chris
                            htilburgs @Chris62
                            @Chris62 Good to hear it’s fixed.
                            You can do both
                            • Remove the unused column entirly
                            • Fill the unused column with zero’s
                            As of version v1.2.0 you can also use you’re own column names, as long as they are color names. The garbage bin is showed in the color of the name of the column.
                            example
                            WeekStarting,Green,Brown
                            04/15/19,1,1
                            • W Offline
                              werffje
                              OMG I’m such a noob forgive me, I forgot the alert: 4 line in my config.js
                              It works great now, thanks !!
                                htilburgs @werffje
                                @werffje :thumbs_up_light_skin_tone:
                                  rvanuden
                                  best module ever :-)
                                    htilburgs @rvanuden
                                    @rvanuden :hugging_face: :thumbs_up_light_skin_tone:
                                      RdP
                                      We have 4 garbage bins. (Green,Black, Bleu and Yellow), is it possible to use 4 types instead of 3?
                                        htilburgs @RdP
                                        @RdP
                                        You can use this module by creating your own Garbage Schedule file with the name garbage_schedule.csv An example file garbage_schedule.csv is added.
                                        WeekStarting,green,gray,blue
                                        03/07/18,1,0,1
                                        03/14/18,1,1,1
                                        03/21/18,1,0,1
                                        03/28/18,1,1,1
                                        Default there are 3 bins defined (green, gray and blue) If you need more garbage bins, simply add an extra column in the garbage_schedule.csv file. The name is the color you like the bin to have. In you case ‘yellow’.
                                        Add lines for each garbage pickup date as needed. The date format needs to be specified as MM/DD/YY (e.g.: 05/28/18 for 28-May-2018)
                                        Succes!
                                          RdP @htilburgs
                                          @htilburgs
                                          Yes works like a charm…
                                          Thank you
                                            htilburgs @RdP
                                            @RdP, great it worked out for you!
