    MMM-MyGarbage
    62 Posts 28 Posters 54.1k Views 30 Watching
    • htilburgsH Offline
      htilburgs
      On my TEST System, I just did a fresh install of MM2 and after that a fresh install of MMM-MyGarbage. Copy and Paste the configuration as in the README.md into the config.js and no errors. MMM-MyGarbage displays 2 entries with the garbage_schedule.csv that is installed with the git clone…
      @Chris62, @werffje, if you still expirience problems, than:
      • add config.js into reply
      • look at the javascript console if you see any errors in the Console tab
      Open Javascript Console:
      Press Command+Option+J (Mac) or Control+Shift+J (Windows, Linux, Chrome OS) to open the Console
      • any other information that maybe relevant
      I’ll look at it and try to reproduce and/or correct the issue.
      (still trying to learn JS, but not afraid to ask and AI is my best friend) ☺
        Chris62
        Thanks for your reply. I have fixed it now. I loaded the csv file into excel to alter the dates but something was wrong with the formatting and I just couldn’t get it to work. Anyway, I loaded up MM into a Ubuntu virtual machine and changed the dates in notepad. I sorted out the config issue (I moved the position within the config file to make it easier to read but accidentally did copy rather than cut and paste so I had two loading), fired it up and it worked like a charm. I have now copied everything to my Pi and it now works there too.
        Just a quick question, I only have two bins, blue and green, is it possible to remove the column for the other one without mucking it up, or should I just set all the values to zero?
        Chris
        htilburgsH 1 Reply Last reply Reply Quote 0
          htilburgs @Chris62
          @Chris62 Good to hear it’s fixed.
          You can do both
          • Remove the unused column entirly
          • Fill the unused column with zero’s
          As of version v1.2.0 you can also use you’re own column names, as long as they are color names. The garbage bin is showed in the color of the name of the column.
          example
          WeekStarting,Green,Brown
          04/15/19,1,1
          • W Offline
            werffje
            OMG I’m such a noob forgive me, I forgot the alert: 4 line in my config.js
            It works great now, thanks !!
              htilburgs @werffje
              @werffje :thumbs_up_light_skin_tone:
                rvanuden
                best module ever :-)
                  htilburgs @rvanuden
                  @rvanuden :hugging_face: :thumbs_up_light_skin_tone:
                    RdP
                    We have 4 garbage bins. (Green,Black, Bleu and Yellow), is it possible to use 4 types instead of 3?
                      htilburgs @RdP
                      @RdP
                      You can use this module by creating your own Garbage Schedule file with the name garbage_schedule.csv An example file garbage_schedule.csv is added.
                      Create a CSV based on the following template:
                      WeekStarting,green,gray,blue
                      03/07/18,1,0,1
                      03/14/18,1,1,1
                      03/21/18,1,0,1
                      03/28/18,1,1,1
                      Default there are 3 bins defined (green, gray and blue) If you need more garbage bins, simply add an extra column in the garbage_schedule.csv file. The name is the color you like the bin to have. In you case ‘yellow’.
                      Add lines for each garbage pickup date as needed. The date format needs to be specified as MM/DD/YY (e.g.: 05/28/18 for 28-May-2018)
                      Succes!
                        RdP @htilburgs
                        @htilburgs
                        Yes works like a charm…
                        Thank you
                          htilburgs @RdP
                          @RdP, great it worked out for you!
                          • twosquirrelsT Offline
                            twosquirrels
                            This is great! It’s since replaced MMM-MyWastePickup as that no longer works .
                              mistered
                              Hi guys i know this is an old topic but maybe i can get an answer anayway
                              i want 4 bins but just adding a color and and a 1 or 0 in the csv file does not work
                                mistered
                                ok got it to work now
                                • K Offline
                                  kalin
                                  Hello guys!
                                  could anyone help and check what is wrong with my configuration of this module? Under the title I have only message: loading
                                  My configuration looks like:
                                  module: ‘MMM-MyGarbage’,
                                  position: ‘bottom_left’,
                                  header: ‘My Garbage Calendar’,
                                  alert: 3,
                                  weeksToDisplay: 2,
                                  limitTo: 99,
                                  fade: true,
                                  dateFormat: “dddd”,
                                  fadePoint: 0.25
                                    ReD1470
                                    Hey there,
                                    Great work on this module. But you say you are not an experienced programmer? well, compared to me…
                                    not to sound lazy, but any change you could convert from csv to json query like thingy?
                                    as seen on the home automation sites, people query http://json.mijnafvalwijzer.nl/?method=postcodecheck&postcode=&street=&huisnummer=&toevoeging=&platform=phone&langs=nl&
                                    and get the results needed
                                    (https://community.home-assistant.io/t/garbage-pickup-date-mijnafvalwijzer-nl-custom-component/34631/12)
                                    please be honest, no is also an answer and I would completely understand.
                                    … but i thought you might like a challenge ;-)
                                    • L Offline
                                      lodam @htilburgs
                                      @htilburgs : thanks a lot for this module !
                                      this is super useful and well done.
                                      I would like to change color for bins, i did the custom.css file and restarted MM2 but that does not change.
                                      Do i have to do something else ?
                                      thanks a lot for your help.
                                      Here you can file a translation for French if this could help :
                                      “GARBAGEENTRIESLEFT”: “Il reste {entriesLeft} dates dans le calendrier des ordures”,
                                      “REMEMBERADDINGPICKUPS”: “Veuillez ajouter de nouvelles dates pour l’utiliser”
                                      REBR 1 Reply Last reply Reply Quote 0
                                      • REBR Offline
                                        REB @lodam
                                        @lodam said in MMM-MyGarbage:
                                        You can change the colour of the bin icons in the garbage_schedule.csv file like so. The top row defines the colour of the icons. In my case below they are green, dark grey and light blue.
                                        WeekStarting,#00FF00,#D3D3D3,#87CEEB
                                        03/31/20,0,0,1
                                        04/07/20,0,1,0
                                        04/14/20,0,0,1
                                        04/21/20,0,1,0
                                        04/28/20,0,0,1
                                        05/05/20,0,1,0
                                        • L Offline
                                          lodam
                                          thanks for your help @REB but in my case, i have
                                          "WeekStarting,GreenBin, GarbageBin, Paperbin,
                                          So i guess i have to change that somewhere else ;)
                                          • L Offline
                                            lodam
                                            oups so sorry, i misunderstood…
                                            You are 100% right, i just changed and did the same as you did.
                                            thanks a lot !
                                            • 1 / 4
