    npm install error
    11 Posts 3 Posters 7.0k Views 3 Watching
    • E
      emrhssla
      I am working with my friend on a project. When I downloaded what my friend had been working on with my raspberry pie and installed npm start, I got the error:
      0_1555310776532_d9fb8868-2613-4b33-a10d-a0d7000d7d14-image.png 0_15
      Friend’s environment is Mac, and I downloaded it to the raspberry pie.
      My freiend’s repository is https://github.com/ENTITYSmartMirror/BeautyMirrorTEST
      Friend installed and used python-shell module on April 15.
      /home/pi/Desktop/BeautyMirrorTEST/node_modules/electron/dist/Electron.app/Contents/MacOS/Electron: 1: /home/pi/Desktop/BeautyMirrorTEST/node_modules/electron/dist/Electron.app/Contents/MacOS/Electron: ���� � 0: not found
      /home/pi/Desktop/BeautyMirrorTEST/node_modules/electron/dist/Electron.app/Contents/MacOS/Electron: 4: /home/pi/Desktop/BeautyMirrorTEST/node_modules/electron/dist/Electron.app/Contents/MacOS/Electron: Syntax error: word unexpected (expecting “)”)
      npm ERR! code ELIFECYCLE
      npm ERR! errno 2
      npm ERR! magicmirror@2.6.0 start: sh run-start.sh
      npm ERR! Exit status 2
      npm ERR!
      npm ERR! Failed at the magicmirror@2.6.0 start script.
      npm ERR! /home/pi/.npm/_logs/2019-04-15T06_36_00_871Z-debug.log
      • G
        ganget
        I’m not really sure what your question is, or if you even have a question?
        I’m making the assumption that your question is: why do you get the errors? That is probably because mac and RPI have 2 totally diferrent operatings systems.
        The errors are a result of that, This bold part of the error is telling that the ellection.app is installed on MacOS: "Electron.app/Contents/MacOS/Electron: 1: " But you are running it on a RPI.
        To solve this you can do a clean install of MagicMirror on the RPI and install the modules as well. Then copy the changed config files, probably being config.js and custom.css
        E 1 Reply Last reply
          sdetweil @emrhssla
          @emrhssla ok, so you are installing a clone of MM… its ok, do that all the time.
          after the git clone, then u do npm install, right?
          he has copied the node_modules folder into his repo… u don’t want that…
          so, go to the folder
          and do
          rm -rf node_modules
          npm install
          then try the
          npm start dev &
          and have him remove the node_modules folder from his git repo
          and from all the modules which have a node_modules folder…
          and the vendor folder too
          the platforms are different, you cannot copy the binary runtimes
          G E 2 Replies Last reply
            • G
              ganget @sdetweil
              @sdetweil Same problem identification, way better solution!
              • E
                emrhssla @sdetweil
                pi@raspberrypi:~/Desktop/Chanyoung/BeautyMirrorTEST $ rm -rf node_modules
                pi@raspberrypi:~/Desktop/Chanyoung/BeautyMirrorTEST $ npm install
                npm WARN deprecated time-grunt@2.0.0: Deprecated because Grunt is practically unmaintained. Move on to something better. This package will continue to work with Grunt v1, but it will not receive any updates.
                npm ERR! code ENOLOCAL
                npm ERR! Could not install from "node_modules/danger/vm2@github:patriksimek/vm2#7e82f90ac705fc44fad044147cb0df09b4c79a57" as it does not contain a package.json file.
                npm ERR!     /home/pi/.npm/_logs/2019-04-15T12_43_25_301Z-debug.log
                  sdetweil @emrhssla
                  @emrhssla AND delete node_modules from all locations, right? vendor and all modules
                  from the MM folder do
                  WATCH OUT, THIS WILL ERASE ALL THE node_modules IN THE EMBEDED MagicMirror
                  find . | grep node_modules$ | xargs rm -rf
                  and
                  find . | grep package-lock.json | xargs rm
                  this erases all the mac based stuff that should not have been added to the repo
                  then
                  npm install
                    @emrhssla also delete the package-lock.json files in the few folders
                    • E
                      emrhssla @ganget
                      @ganget
                      I think cleaning is the answer too…
                      • E
                        emrhssla @sdetweil
                        pi@pi:~/newTest $ npm start
                        > magicmirror@2.6.0 start /home/pi/newTest
                        > sh run-start.sh
                        Starting MagicMirror: v2.6.0
                        Loading config ...
                        Loading module helpers ...
                        No helper found for module: MMM-iFrame.
                        No helper found for module: MMM-EmbedYoutube1.
                        No helper found for module: MMM-Modulebar1.
                        No helper found for module: MMM-Modulebar.
                        No helper found for module: MMM-Dynamic-Modules.
                        WARNING! Could not load config file. Starting with default configuration. Error found: Error: Cannot find module 'node_helper'
                        App threw an error during load
                            at Module._resolveFilename (module.js:543:15)
                            at Function.Module._resolveFilename (/home/pi/newTest/node_modules/electron/dist/resources/electron.asar/common/reset-search-paths.js:35:12)
                            at Function.Module._load (module.js:473:25)
                            at Module.require (module.js:586:17)
                            at require (internal/module.js:11:18)
                            at Object.<anonymous> (/home/pi/newTest/modules/default/updatenotification/node_helper.js:6:18)
                            at Object.<anonymous> (/home/pi/newTest/modules/default/updatenotification/node_helper.js:92:3)
                            at Module._compile (module.js:642:30)
                            at Object.Module._extensions..js (module.js:653:10)
                            at Module.load (module.js:561:32)
                        { Error: Cannot find module 'node_helper'
                            at Module.load (module.js:561:32) code: 'MODULE_NOT_FOUND' }
                        Launching application.
                          sdetweil @emrhssla
                          @emrhssla yeh, my fault… i had u erase too much, there is a supplied node_helper module in the modules folder…
                          you can copy it from the /pi/MagicMirror installation
                          cp -r ~/MagicMirror/modules/node_modules/node_helper ~/newTest/modules/node_modules
