    npm install error
    11 Posts 3 Posters 6.8k Views 3 Watching
    • G Offline
      ganget
      I’m not really sure what your question is, or if you even have a question?
      I’m making the assumption that your question is: why do you get the errors? That is probably because mac and RPI have 2 totally diferrent operatings systems.
      The errors are a result of that, This bold part of the error is telling that the ellection.app is installed on MacOS: "Electron.app/Contents/MacOS/Electron: 1: " But you are running it on a RPI.
      To solve this you can do a clean install of MagicMirror on the RPI and install the modules as well. Then copy the changed config files, probably being config.js and custom.css
        sdetweil @emrhssla
        @emrhssla ok, so you are installing a clone of MM… its ok, do that all the time.
        after the git clone, then u do npm install, right?
        he has copied the node_modules folder into his repo… u don’t want that…
        so, go to the folder
        /home/pi/Desktop/BeautyMirrorTEST
        and do
        rm -rf node_modules
        npm install
        then try the
        npm start dev &
        and have him remove the node_modules folder from his git repo
        and from all the modules which have a node_modules folder…
        and the vendor folder too
        the platforms are different, you cannot copy the binary runtimes
        G E 2 Replies Last reply Reply Quote 0
          • G Offline
            ganget @sdetweil
            @sdetweil Same problem identification, way better solution!
            • E Offline
              emrhssla @sdetweil
              pi@raspberrypi:~/Desktop/Chanyoung/BeautyMirrorTEST $ rm -rf node_modules
              pi@raspberrypi:~/Desktop/Chanyoung/BeautyMirrorTEST $ npm install
              npm WARN deprecated time-grunt@2.0.0: Deprecated because Grunt is practically unmaintained. Move on to something better. This package will continue to work with Grunt v1, but it will not receive any updates.
              npm ERR! code ENOLOCAL
              npm ERR! Could not install from "node_modules/danger/vm2@github:patriksimek/vm2#7e82f90ac705fc44fad044147cb0df09b4c79a57" as it does not contain a package.json file.
              npm ERR!     /home/pi/.npm/_logs/2019-04-15T12_43_25_301Z-debug.log
                sdetweil @emrhssla
                @emrhssla AND delete node_modules from all locations, right? vendor and all modules
                from the MM folder do
                WATCH OUT, THIS WILL ERASE ALL THE node_modules IN THE EMBEDED MagicMirror
                find . | grep node_modules$ | xargs rm -rf
                and
                find . | grep package-lock.json | xargs rm
                this erases all the mac based stuff that should not have been added to the repo
                then
                npm install
                  @emrhssla also delete the package-lock.json files in the few folders
                  • E Offline
                    emrhssla @ganget
                    @ganget
                    I think cleaning is the answer too…
                    • E Offline
                      emrhssla @sdetweil
                      pi@pi:~/newTest $ npm start
                      > magicmirror@2.6.0 start /home/pi/newTest
                      > sh run-start.sh
                      Starting MagicMirror: v2.6.0
                      Loading config ...
                      Loading module helpers ...
                      No helper found for module: MMM-iFrame.
                      No helper found for module: MMM-EmbedYoutube1.
                      No helper found for module: MMM-Modulebar1.
                      No helper found for module: MMM-Modulebar.
                      No helper found for module: MMM-Dynamic-Modules.
                      WARNING! Could not load config file. Starting with default configuration. Error found: Error: Cannot find module 'node_helper'
                      App threw an error during load
                          at Module._resolveFilename (module.js:543:15)
                          at Function.Module._resolveFilename (/home/pi/newTest/node_modules/electron/dist/resources/electron.asar/common/reset-search-paths.js:35:12)
                          at Function.Module._load (module.js:473:25)
                          at Module.require (module.js:586:17)
                          at require (internal/module.js:11:18)
                          at Object.<anonymous> (/home/pi/newTest/modules/default/updatenotification/node_helper.js:6:18)
                          at Object.<anonymous> (/home/pi/newTest/modules/default/updatenotification/node_helper.js:92:3)
                          at Module._compile (module.js:642:30)
                          at Object.Module._extensions..js (module.js:653:10)
                          at Module.load (module.js:561:32)
                      { Error: Cannot find module 'node_helper'
                          at Module.load (module.js:561:32) code: 'MODULE_NOT_FOUND' }
                      Launching application.
                        sdetweil @emrhssla
                        @emrhssla yeh, my fault… i had u erase too much, there is a supplied node_helper module in the modules folder…
                        you can copy it from the /pi/MagicMirror installation
                        cp -r ~/MagicMirror/modules/node_modules/node_helper ~/newTest/modules/node_modules
