    MMM-AQI
    Scheduled Pinned Locked Moved Health
    61 Posts 14 Posters 75.7k Views 15 Watching
      ryck Module Developer @E3V3A
      @E3V3A Yep, but you can use the same token you are using for the module, ie:
      https://api.waqi.info/search/?token=TOKEN&keyword=croydon
      (you can just type that URL in your browser)
      • F Offline
        Fonfon
        Sorry but geoloc “here” is so bad !
        name of city don’t work
        and don’t understand how find @id …
          ryck Module Developer @Fonfon
          @Fonfon I added more info in the README, but is basically enter the URL above in your browser (using your token and your city, of course) an then just look for your city in the response and write down the “uid” value, that’s the id you are looking for.
          F 1 Reply Last reply Reply Quote 1
          • F Offline
            Fonfon @ryck
            @ryck ahh ok i understand…Thanks a lot ;)
            • E Offline
              E3V3A
              Would you be willing to have/make an option to make the items horizontal instead of vertical? So to save space, since they are only numbers?
              “Everything I do (here) is for free – altruism is the way!”
                @E3V3A Yes, that’s a good idea, I’ll try to implement it as soon as I have some spare time!
                  maydaymiao
                  Hi, nice module. One question, is it possible to filter some of the pollutants that I want to see? Right now, it just displays all of them.
                    rvanuden
                    i am a late comer, just starting to learn about the magicmirror
                    i do have a question about this nice module
                    is there a way to display tresholds?
                    for most people numbers say nothing, or you work with colors or display tresholds, how else can you know which pollutant is good or bad?
                      Smotx
                      Thx, very good, but why the ‘header’ is not visible ?
                        Mykle1 Project Sponsor Module Developer @Smotx
                        @Smotx said in MMM-AQI:
                        Post your config entry for this module in a code block
                          Smotx @Mykle1
                          @Mykle1
                          			module: 'MMM-AQI',
                          			position: 'top_left',
                          			header: 'Polution',
                          				token: "99860xxxxxxx",
                          				city: "@8xxx",
                          				iaqi: false,
                          				updateInterval: 30 * 60 * 1000, // Every half hour.
                          				initialLoadDelay: 0,
                          				animationSpeed: 1000,
                          				debug: false
                            @Smotx
                            Hmm, odd. Your config looks good. Header SHOULD be showing. I just installed and ran it and my header appears as expected. Not sure why yours isn’t. My config:
                                    module: 'MMM-AQI',
                                    position: 'top center',
                                    header: 'This header is working',
                                      token: "exxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxx3",
                                      city: "here",
                                      iaqi: true,
                                      debug: false
                            Try using my config with your apiToken as a test.
                              Smotx @Mykle1
                              @Mykle1
                              The same, it’s stange, on others module, header are ok on screen…
                                did something else push the header off the screen…
                                can u try with just the AQI module
                                  @Smotx
                                  Have you made any changes to the MMM-AQI.css file or additions to your custom.css file referencing the module?
                                    Smotx @Mykle1
                                    @Mykle1
                                    nothing in MMM-AQI.CSS
                                    and on custom.css
                                    .aqi.good {
                                    	color: #009966;
                                    	font-size: 35px;
                                    .aqi.moderate {
                                    	color: #ffde33;
                                    	font-size: 35px;
                                    .aqi.unhealthy-sensitive {
                                    	color: #ff9933;
                                    	font-size: 35px;
                                    .aqi.unhealthy {
                                    	color: #cc0033;
                                    	font-size: 35px;
                                    .aqi.very-unhealthy {
                                    	color: #660099;
                                    	font-size: 35px;
                                    .aqi.hazardous {
                                    	color: #7e0023;
                                    	font-size: 35px;
                                    But without, it’s the same.
                                      @Smotx
                                      And have you done as @sdetweil has suggested in his last post?
                                        Smotx
                                        Good, after Update header’s OK on screen, thx
                                        • LordyL Offline
                                          Lordy
                                          I need your help, because I can not find the “token” for Berlin?
                                            chassain 0 @Lordy
                                            @Lordy
                                            same problem. The page can not be found for data-platform token
                                            LordyL 1 Reply Last reply Reply Quote 0
                                            • 1 / 4
