    2 Calendar modules do not line up
    5 Posts 2 Posters 1.8k Views 2 Watching
      mlcampbe
      Any idea why these 2 calendar modules do not properly line up on the left? Note that the top one is a combination of 2 gmail and 1 work calendar and the bottom one is a iCloud calendar. But I do not see how that could possible matter. For some reason the 2nd calendar data is pushed to the left about 10px.
        mlcampbe
        Seems this has taken care of itself. I suspect that the overall length of something was causing the issue but not sure what it was.
          mlcampbe
          Actually no this has not fixed itself. It keeps coming back. I think it has to do with the time element on the righthand side.
          Note that this is 2 different calendar modules running 1 - for myself and 1 for my wife. What I believe is happening is that when the time contains the string “Tomorrow at xx” or “Saturday at xx” in 1 of the calendars but not the other then the DIV and SPAN elements get pushed around causing the indention to get messed up.
          If I put all of the calendar info into a single module then there are no problems.
          Has anyone else seen this and if so how do you fix it?
            Mr.Fliffer
            Hey mlcampbe,
            i have the same issue at my MM, but no idea how to fix this. I set up different time formats for different urls. But how can this effect the allignment of the left side?.
              mlcampbe @Mr.Fliffer
              @mr-fliffer
              I never resolved the problem either. I went ahead and just used a single module for my purposes.
