    MMM-TelegramBot : Control MM on Telegram
    47 Posts 20 Posters 28.2k Views 21 Watching
    • michael5rM
      michael5r Module Developer
      This is a great module - I’m adding Telegram support to all my modules shortly :thumbs_up:
      • lolobyteL
        lolobyte
        can somebody help me with this module?
        here is my config.js entry including the MMM-Tools. Tools are running very well.
                                module: 'MMM-Tools',
                                position: 'bottom_right',
                                        device : "RPI", // "RPI" is also available
                                        refresh_interval_ms : 10000,
                                        warning_interval_ms : 1000 * 60 * 5,
                                        enable_warning : true,
                                        warning : {
                                                CPU_TEMPERATURE : 65,
                                                GPU_TEMPERATURE : 65,
                                                CPU_USAGE : 75,
                                                STORAGE_USED_PERCENT : 80,
                                                MEMORY_USED_PERCENT : 80
                                        warning_text: {
                                                CPU_TEMPERATURE : "The temperature of CPU is over %VAL%",
                                                GPU_TEMPERATURE : "The temperature of GPU is over %VAL%",
                                                CPU_USAGE : "The usage of CPU is over %VAL%",
                                                STORAGE_USED_PERCENT : "The storage is used over %VAL% percent",
                                                MEMORY_USED_PERCENT : "The memory is used over %VAL% percent",
                                module: 'MMM-TelegramBot',
                                        telegramAPIKey : 'xxxxxxxxxxxxxxxmy_API_keyxxxxxxxxxxxxxxxxxxxx',
                                        allowedUser : ['my_Telegram_username without @'], // This is NOT the username of bot.
        The logs of MM2!
        0|mm  | [TELBOT] Error: ETELEGRAM
        0|mm  | { ok: false,
        0|mm  |   error_code: 400,
        0|mm  |   description: 'Bad Request: chat_id is empty' }
        0|mm  | ERR_RESPONSE { type: 'TEXT',
        0|mm  |   chat_id: undefined,
        0|mm  |   text: 'Ein Fehler ist aufgetreten. Bitte den Admin kontaktieren.' }
        0|mm  | { ok: false,
        0|mm  | { ok: false,
        0|mm  |   text: '`ERROR`\n```\nBad Request: chat_id is empty\n```\nat\n```\n{"type":"TEXT","text":"`ERROR`\\n```\\nBad Request: chat_id is empty\\n```\\nat\\n```\\n{\\"type\\":\\"TEXT\\",\\"chat_id\\":null,\\"text\\":\\"Ein Fehler ist aufgetreten. Bitte den Admin kontaktieren.\\"}\\n```","option":{"disable_notification":false,"parse_mode":"Markdown","chat_id":"","text":"`ERROR`\\n```\\nBad Request: chat_id is empty\\n```\\nat\\n```\\n{\\"type\\":\\"TEXT\\",\\"chat_id\\":null,\\"text\\":\\"Ein Fehler ist aufgetreten. Bitte den Admin kontaktieren.\\"}\\n```"}}\n```',
        0|mm  |   option:
        0|mm  |    { disable_notification: false,
        0|mm  |      parse_mode: 'Markdown',
        0|mm  |      chat_id: '',
        0|mm  |      text: '`ERROR`\n```\nBad Request: chat_id is empty\n```\nat\n```\n{"type":"TEXT","text":"`ERROR`\\n```\\nBad Request: chat_id is empty\\n```\\nat\\n```\\n{\\"type\\":\\"TEXT\\",\\"chat_id\\":null,\\"text\\":\\"Ein Fehler ist aufgetreten. Bitte den Admin kontaktieren.\\"}\\n```","option":{"disable_notification":false,"parse_mode":"Markdown","chat_id":"","text":"`ERROR`\\n```\\nBad Request: chat_id is empty\\n```\\nat\\n```\\n{\\"type\\":\\"TEXT\\",\\"chat_id\\":null,\\"text\\":\\"Ein Fehler ist aufgetreten. Bitte den Admin kontaktieren.\\"}\\n```"}}\n```' } }
        0|mm  | { ok: false,
        0|mm  | { ok: false,
        0|mm  |   text: '`ERROR`\n```\nBad Request: chat_id is empty\n```\nat\n```\n{"type":"TEXT","chat_id":null,"text":"Ein Fehler ist aufgetreten. Bitte den Admin kontaktieren."}\n```',
        0|mm  |   option:
        0|mm  |      chat_id: '',
        0|mm  |      text: '`ERROR`\n```\nBad Request: chat_id is empty\n```\nat\n```\n{"type":"TEXT","chat_id":null,"text":"Ein Fehler ist aufgetreten. Bitte den Admin kontaktieren."}\n```' } }
        0|mm  | { ok: false,
        0|mm  | { ok: false,
        0|mm  |   text: '`ERROR`\n```\nBad Request: chat_id is empty\n```\nat\n```\n{"type":"TEXT","text":"`ERROR`\\n```\\nBad Request: chat_id is empty\\n```\\nat\\n```\\n{\\"type\\":\\"TEXT\\",\\"text\\":\\"`ERROR`\\\\n```\\\\nBad Request: chat_id is empty\\\\n```\\\\nat\\\\n```\\\\n{\\\\\\"type\\\\\\":\\\\\\"TEXT\\\\\\",\\\\\\"chat_id\\\\\\":null,\\\\\\"text\\\\\\":\\\\\\"Ein Fehler ist aufgetreten. Bitte den Admin kontaktieren.\\\\\\"}\\\\n```\\",\\"option\\":{\\"disable_notification\\":false,\\"parse_mode\\":\\"Markdown\\",\\"chat_id\\":\\"\\",\\"text\\":\\"`ERROR`\\\\n```\\\\nBad Request: chat_id is empty\\\\n```\\\\nat\\\\n```\\\\n{\\\\\\"type\\\\\\":\\\\\\"TEXT\\\\\\",\\\\\\"chat_id\\\\\\":null,\\\\\\"text\\\\\\":\\\\\\"Ein Fehler ist aufgetreten. Bitte den Admin kontaktieren.\\\\\\"}\\\\n```\\"}}\\n```","option":{"disable_notification":false,"parse_mode":"Markdown","chat_id":"","text":"`ERROR`\\n```\\nBad Request: chat_id is empty\\n```\\nat\\n```\\n{\\"type\\":\\"TEXT\\",\\"text\\":\\"`ERROR`\\\\n```\\\\nBad Request: chat_id is empty\\\\n```\\\\nat\\\\n```\\\\n{\\\\\\"type\\\\\\":\\\\\\"TEXT\\\\\\",\\\\\\"chat_id\\\\\\":null,\\\\\\"text\\\\\\":\\\\\\"Ein Fehler ist aufgetreten. Bitte den Admin kontaktieren.\\\\\\"}\\\\n```\\",\\"option\\":{\\"disable_notification\\":false,\\"parse_mode\\":\\"Markdown\\",\\"chat_id\\":\\"\\",\\"text\\":\\"`ERROR`\\\\n```\\\\nBad Request: chat_id is empty\\\\n```\\\\nat\\\\n```\\\\n{\\\\\\"type\\\\\\":\\\\\\"TEXT\\\\\\",\\\\\\"chat_id\\\\\\":null,\\\\\\"text\\\\\\":\\\\\\"Ein Fehler ist aufgetreten. Bitte den Admin kontaktieren.\\\\\\"}\\\\n```\\"}}\\n```"}}\n```',
        0|mm  |   option:
        0|mm  |      chat_id: '',
        0|mm  |      text: '`ERROR`\n```\nBad Request: chat_id is empty\n```\nat\n```\n{"type":"TEXT","text":"`ERROR`\\n```\\nBad Request: chat_id is empty\\n```\\nat\\n```\\n{\\"type\\":\\"TEXT\\",\\"text\\":\\"`ERROR`\\\\n```\\\\nBad Request: chat_id is empty\\\\n```\\\\nat\\\\n```\\\\n{\\\\\\"type\\\\\\":\\\\\\"TEXT\\\\\\",\\\\\\"chat_id\\\\\\":null,\\\\\\"text\\\\\\":\\\\\\"Ein Fehler ist aufgetreten. Bitte den Admin kontaktieren.\\\\\\"}\\\\n```\\",\\"option\\":{\\"disable_notification\\":false,\\"parse_mode\\":\\"Markdown\\",\\"chat_id\\":\\"\\",\\"text\\":\\"`ERROR`\\\\n```\\\\nBad Request: chat_id is empty\\\\n```\\\\nat\\\\n```\\\\n{\\\\\\"type\\\\\\":\\\\\\"TEXT\\\\\\",\\\\\\"chat_id\\\\\\":null,\\\\\\"text\\\\\\":\\\\\\"Ein Fehler ist aufgetreten. Bitte den Admin kontaktieren.\\\\\\"}\\\\n```\\"}}\\n```","option":{"disable_notification":false,"parse_mode":"Markdown","chat_id":"","text":"`ERROR`\\n```\\nBad Request: chat_id is empty\\n```\\nat\\n```\\n{\\"type\\":\\"TEXT\\",\\"text\\":\\"`ERROR`\\\\n```\\\\nBad Request: chat_id is empty\\\\n```\\\\nat\\\\n```\\\\n{\\\\\\"type\\\\\\":\\\\\\"TEXT\\\\\\",\\\\\\"chat_id\\\\\\":null,\\\\\\"text\\\\\\":\\\\\\"Ein Fehler ist aufgetreten. Bitte den Admin kontaktieren.\\\\\\"}\\\\n```\\",\\"option\\":{\\"disable_notification\\":false,\\"parse_mode\\":\\"Markdown\\",\\"chat_id\\":\\"\\",\\"text\\":\\"`ERROR`\\\\n```\\\\nBad Request: chat_id is empty\\\\n```\\\\nat\\\\n```\\\\n{\\\\\\"type\\\\\\":\\\\\\"TEXT\\\\\\",\\\\\\"chat_id\\\\\\":null,\\\\\\"text\\\\\\":\\\\\\"Ein Fehler ist aufgetreten. Bitte den Admin kontaktieren.\\\\\\"}\\\\n```\\"}}\\n```"}}\n```' } }
        0|mm  | { ok: false,
        0|mm  |   text: '`ERROR`\n```\nBad Request: chat_id is empty\n```\nat\n```\n{"type":"TEXT","text":"Ein Fehler ist aufgetreten. Bitte den Admin kontaktieren."}\n```',
        0|mm  |   option:
        0|mm  |      chat_id: '',
        0|mm  |      text: '`ERROR`\n```\nBad Request: chat_id is empty\n```\nat\n```\n{"type":"TEXT","text":"Ein Fehler ist aufgetreten. Bitte den Admin kontaktieren."}\n```' } }
        0|mm  | { ok: false,
        0|mm  | { ok: false,
        0|mm  |   option:
        0|mm  |      chat_id: '',
        0|mm  | { ok: false,
        ^C
        and it’s never ending.
        What is wrong?
        ? 1 Reply Last reply
          A Former User @lolobyte
          @lolobyte
          Your telegrambot config is not completed. Read instructions of module on github
          • lolobyteL
            lolobyte
            Hi, i know.
            But ongoing with step 4 is not possible because Telegranm don’t know the /commands or the /mychatid command!
            This is the reson why i don’t have actually the adminChatId.
              @lolobyte
              To make things simple, Disable other modules except MMM-TelegramBot.
              Then execute MM again. Show me which logs are displayed.
              • lolobyteL
                lolobyte
                OK, here the new config .js only with telegram module.
                        units: "metric",
                //                      module: 'MMM-Tools',
                //                      position: 'top_right',
                //                      config: {
                //                              device : "RPI", // "RPI" is also available
                //                              refresh_interval_ms : 10000,
                //                              warning_interval_ms : 1000 * 60 * 5,
                //                              enable_warning : true,
                //                              warning : {
                //                                      CPU_TEMPERATURE : 65,
                //                                      GPU_TEMPERATURE : 65,
                //                                      CPU_USAGE : 75,
                //                                      STORAGE_USED_PERCENT : 80,
                //                                      MEMORY_USED_PERCENT : 80
                //                              warning_text: {
                //                                      CPU_TEMPERATURE : "The temperature of CPU is over %VAL%",
                //                                      GPU_TEMPERATURE : "The temperature of GPU is over %VAL%",
                //                                      CPU_USAGE : "The usage of CPU is over %VAL%",
                //                                      STORAGE_USED_PERCENT : "The storage is used over %VAL% percent",
                //                                      MEMORY_USED_PERCENT : "The memory is used over %VAL% percent",
                and here the log data.
                pi@raspi-MM2:~ $ pm2 logs mm
                [TAILING] Tailing last 15 lines for [mm] process (change the value with --lines option)
                0|mm       |     at Request.emit (events.js:214:7)
                0|mm       |     at Request.<anonymous> (/home/pi/MagicMirror/modules/MMM-iCloud-Client/node_modules/request/request.js:1161:10          )
                0|mm       |     at emitOne (events.js:116:13)
                0|mm       |     at Request.emit (events.js:211:7)
                0|mm       |     at IncomingMessage.<anonymous> (/home/pi/MagicMirror/modules/MMM-iCloud-Client/node_modules/request/request.js          :1083:12)
                0|mm       |     at Object.onceWrapper (events.js:313:30)
                0|mm       | TypeError: PythonShell is not a constructor
                0|mm       |     at Class.loadDataFromAPI (/home/pi/MagicMirror/modules/MMM-FRITZ-Box-Callmonitor/node_helper.js:216:17)
                0|mm       |     at Class.socketNotificationReceived (/home/pi/MagicMirror/modules/MMM-FRITZ-Box-Callmonitor/node_helper.js:69:          9)
                0|mm       |     at Socket.<anonymous> (/home/pi/MagicMirror/modules/node_modules/node_helper/index.js:113:11)
                0|mm       |     at emitTwo (events.js:126:13)
                0|mm       |     at Socket.emit (events.js:214:7)
                0|mm       |     at /home/pi/MagicMirror/node_modules/socket.io/lib/socket.js:528:12
                0|mm       |     at _combinedTickCallback (internal/process/next_tick.js:131:7)
                0|mm       |     at process._tickCallback (internal/process/next_tick.js:180:9)
                0|mm       | starting network connection testing
                0|mm       | Serving iCal
                0|mm       | Serving iCal
                0|mm       |
                0|mm       | > magicmirror@2.6.0 start /home/pi/MagicMirror
                0|mm       | > sh run-start.sh
                0|mm       |
                0|mm  | Starting MagicMirror: v2.6.0
                0|mm  | Loading config ...
                0|mm  | Loading module helpers ...
                0|mm  | Initializing new module helper ...
                0|mm  | Module helper loaded: MMM-TelegramBot
                0|mm  | All module helpers loaded.
                0|mm  | Starting server on port 8080 ...
                0|mm  | Server started ...
                0|mm  | Connecting socket for: MMM-TelegramBot
                0|mm  | Sockets connected & modules started ...
                0|mm  | Launching application.
                the /commands or the /mychatid command doesn’t work.
                second time restartin MM2
                0|mm       |         _started: true,
                0|mm       |         href: 'https://api.telegram.org/bot%3C718051157:AAFqI9VPBUE5W0FTYeZi770CWaq9mLYEBEQ%3E/getUpdates',
                0|mm       |         req: [Object],
                0|mm       |         ntick: true,
                0|mm       |         response: [Circular],
                0|mm       |         originalHost: 'api.telegram.org',
                0|mm       |         originalHostHeaderName: 'host',
                0|mm       |         responseContent: [Circular],
                0|mm       |         _destdata: true,
                0|mm       |         _ended: true,
                0|mm       |         _callbackCalled: true },
                0|mm       |      toJSON: [Function: responseToJSON],
                0|mm       |      caseless: Caseless { dict: [Object] },
                0|mm       |      read: [Function],
                0|mm       |      body: { ok: false, error_code: 404, description: 'Not Found' } } }
                  @lolobyte More error logs are needed. your mm-error.log is showing just last 15 lines.
                  If your file is too long, send me via email : eouia0819@gmail.com.
                  And If you don’t mind, send me your TelegramAPIKey also. (You can make new thing after my researching)
                  • lolobyteL
                    lolobyte
                    I searche’d the log files and has found this 2:
                    mm-error.log is empty
                    mm-out.log
                    > sh run-start.sh
                    Loading config ...
                    Server started ...
                    Shutting down server...
                    Stopping module helper: MMM-TelegramBot
                    > sh run-start.sh
                    Loading config ...
                    Server started ...
                      @lolobyte
                      Well,
                      mm-out.log
                      It means there’s no error in module on installation phase or running phase.
                      So I have to represent your issue but it might be related your account specific. So I need your TelegramBotAPI Key to represent your issue. Without it, I can help you only limitedly.
                      • T
                        teitlebot
                        @Sean
                        Is it possible to use this module to display on my mirror every time a specific telegram person posts a message? not me. another account.
                          A Former User @teitlebot
                          @teitlebot
                          no, it’s just a bot for interacting in a soecific chat room. not telegram monitor.
                            A Former User
                            New Update
                            [1.0.1] : 2019-09-10
                            • Added: useWelcomeMessage and verbose
                              A Former User
                              New Updates
                              [1.1.0] 2020-02-27
                              • added: new commands
                                • /recent : load telegram keyboard for recent used commands
                                • /favor : load telegram keyboard for favorite commands
                                • /shell : execute shell script or shell command (e.g: /shell echo hello world)
                                • /notification : emit MagicMirror notification (e.g: /notification SHOW_ALERT {"title":"test", "timer":1000})
                                • /screenshot : take a screenshot of MagicMirror
                                I will remove screenshot feature from MMM-Tools on next updates at near future, so use this instead.
                              • added: new features
                                • custom command by user available.
                                • abbreviation of command available (e.g: You can use just /noti or /n instead of full /notification)
                                • detail option of telegramBot constructor(API) available. (e.g: proxy setting) - experimental
                              • changed: kinder logging message.
                              • changed: parse_mode:"MarkdownV2" is supported.(natively by API)
                              • Some translate files are not completed. Please PR for others.
                              B 1 Reply Last reply
                              Reply Quote 2
                                A Former User
                                New Updates
                                [1.2.0] 2020-03-13
                                • Added: Telecast. Now you can telecast your chat or message on MagicMirror screen. (Read the wiki)
                                • Changed: position is needed for telecast (You need to re-configure)
                                  polzy
                                  really good !
                                  Works great. But, just a question, I have a Telegram’s group with another bot and the messages in this bot are not in my MM.
                                  it’s normal ?
                                  Best regards.
                                    A Former User @polzy
                                    @polzy
                                    normal. bots in telegram cannot converse with each other. It cannot be caught.
                                      Mrtrol2013
                                      I can not get my chat id
                                      thymonT 1 Reply Last reply
                                      • thymonT
                                        thymon @Mrtrol2013
                                          DinoDog
                                          hi
                                          When i use /alert, i see the message on my MM, but /telecast don’t show any on my MM
                                          How can i found, whats the error?
                                          The IDs are all correct
                                          B R 2 Replies Last reply
                                          • K
                                            kontranik
                                            can a bot send a notification to other module when a message recived?
