    Would this cause a conflict with MMM-RemoteControl
    8 Posts 2 Posters 2.5k Views 2 Watching
      motdog @sdetweil
      @sdetweil it was the same IP address that I used before installing VNC cloud. Even if I’m not accessing the mirror through VNC the error occurs. I did go into VNC on the mirror, went to settings and disabled accept cloud connections. Still no luck.
      I was wanting to make it easier to shut down for moving the mirror but me having remote access is more important so I can troubleshoot.
        motdog
        I can access it via cloud service now that it’s on their wifi but they can’t get remote to get past the get error.
          sdetweil @motdog
          @motdog everything I see says the vnc connection requires a vnc client… local or remote
          (and once u establish the vnc server, that connection requires the client, no direct connections anymore)…
          https://www.realvnc.com/en/connect/docs/raspberry-pi.html#raspberry-pi-connect-direct
          realvnc is the product for pi…
          https://www.realvnc.com/en/raspberrypi/
            motdog @sdetweil
            @sdetweil the thing is before I set it up for a cloud connection for me to access it remotely, I could access it via MMM-Remote-Control as it was in my home. When I established the cloud connection with VNC, remote quit working. Get the get error
              sdetweil @motdog
              @motdog right… the vnc connection take over ALL communications from the outside in…
              you should be able to use a vnc client on the local lan to connect to the pi… called direct connect
              but apps (like request TO remote-control) cannot go IN to the system except over vnc…(as I understand it)
                motdog
                @sdetweil ok got it. Was just trying to figure out how to adjust screen brightness like I would with the app. makes sense
