    MMM-Facial-Recognition-OCV3 error at tools.train.py
    facial error
    22 Posts 3 Posters 15.0k Views 3 Watching
    • A
      alfi153
      Hello
      I use the version OCV3 of face recognition.
      My problem is when I try again my face to increase the hit rate, I get the error message when typing “python tools.train.py”:
      Remember to set the name list environment variable FACE_USERS
      Reading training images…
      Assign label 1 to Alfred
      OpenCV Error: Assertion failed (ssize.width > 0 && ssize.height > 0) in resize, file /home/pi/opencv/modules/imgproc/src/imgwarp.cpp, line 3483
      File “tools.train.py”, line 14, in
      ToolsTrain().train()
      File “/home/pi/MagicMirror/modules/MMM-Facial-Recognition-OCV3/lib/tools/train.py”, line 53, in train
      faces.append(self.prepareImage(filename))
      File “/home/pi/MagicMirror/modules/MMM-Facial-Recognition-OCV3/lib/tools/train.py”, line 29, in prepareImage
      return self.face.resize(cv2.imread(filename, cv2.IMREAD_GRAYSCALE),ToolsConfig.FACE_WIDTH, ToolsConfig.FACE_HEIGHT)
      File “/home/pi/MagicMirror/modules/MMM-Facial-Recognition-OCV3/lib/common/face.py”, line 113, in resize
      return cv2.resize(image, (face_width, face_height), interpolation=cv2.INTER_LANCZOS4)
      cv2.error: /home/pi/opencv/modules/imgproc/src/imgwarp.cpp:3483: error: (-215) ssize.width > 0 && ssize.height > 0 in function resize
      please help
      S nischiN 2 Replies Last reply Reply Quote 0
        SdeGeata @alfi153
        Bump! Same error message.
        @alfi153 said in MMM-Facial-Recognition-OCV3 error at tools.train.py:
        Hello
        please help
          SdeGeata @SdeGeata
          @SdeGeata Anyone got an answer to this one? I’m still stuck on this.
          • nischiN
            nischi @alfi153
            @alfi153
            Do you tried what are in the docu?
            Test your trained model
            Make sure your training.xml from running train.py is in this directory
            Specify your user labels in the environment with
            export FACE_USERS=name1,name2,name3
            Run python tools.facerecognition.py to test your trained model.
              SdeGeata @nischi
              @nischi
              Hello Nischi;
              Only got as far as “python tools.train.py”. That is what generates the error and it doesn’t generate the XML file that it should, so I can’t verify my training.
              Everything up until then is fine, and there are two named folders in the specified folder (training_data/) with pics of myself and my girlfriend. These photos were already processed by the previous function; “python tools.capture.py”. I don’t know why its bugging.
              nischiN 1 Reply Last reply Reply Quote 0
              • nischiN
                nischi @SdeGeata
                @SdeGeata
                It seems he can’t resize the image for some reason. Have you checked all your pictures that nothing is corrupt and have you checked that your python has access to the files as well?
                  SdeGeata @nischi
                  @nischi
                  Yeah, all the photos load fine in preview app and they were all found, formatted and placed in the folder by the previous step. I don’t know why it is having a problem.
                    SdeGeata @SdeGeata
                    @SdeGeata
                    I have gone ahead and started the process over again, just in case i missed something. I uninstalled everything and did a fresh install. It won’t even capture anymore, never-mind training with the images i already have.
                    I just want to get this thing going.
                    • nischiN
                      nischi @SdeGeata
                      @SdeGeata
                      Do you working with a mac? Maybe you have some issues with the permissioning, have you tried (only for testing) to give all folders full access? i had some issue also if i used sudo for some stuff where i shoudn’t.
                      • nischiN
                        nischi @SdeGeata
                        @SdeGeata
                        I am currently working on a new version of face recognition with another method and the new ocv 4 version. Current tests works much better than this old module. i only need to finish the module soon. i think this or next week i should have a first version which works.
                          SdeGeata @nischi
                          @nischi
                          Sorry, i just saw your replies…
                          I am working on a Mac via VNC viewer and Terminal, all the software is installed on the Rpi 3 b+ directly though. I followed the installation steps on the page thoroughly, so I don’t know what could have gone wrong.
                          I did since then install MotionEye for another aspect I want to add to the mirror and I notice that it adds “boxes” around detected movement - I don’t think it does this normally, but rather is related to the OCV install; only the recognition wouldn’t work anyhow due to the fact its not been “trained” who’s who.
                          Please let me know how your new version goes. I am desperate to get this facial recognition finally working on my mirror.
                            SdeGeata @SdeGeata
                            @SdeGeata
                            Hey @Nischi! I got it going!!!
                            Two things fixed it. The first was a directory error that was preventing capture. Fixed with:
                            in capture.py:
                            from config import ToolsConfig -> from .config import ToolsConfig
                            the second was an outdated PIP that wasn’t getting updated without SUDO that was giving me the error on Training.
                            sudo pip install future --upgrade
                            Both are fixed now and XML is generated. Next on to configuration. Thanks to all for your help.
                            • nischiN
                              nischi @SdeGeata
                              @SdeGeata
                              Cool that it works. I’m nearly done with my new module now. Will inform you if you can try out. And the good thing. The classes config from your old module will be compatible.
                                SdeGeata @nischi
                                @nischi
                                Cool. Lemme know.
                                • nischiN
                                  nischi @SdeGeata
                                  @SdeGeata
                                  Now it’s finally done and tested on my own Magic Mirror with the PiCamera. Let me know if you have any issues and need some help.
                                    SdeGeata
                                    That’s great news! I’m gonna install it today and give it a whirl. I’ve spent too much time swearing about the other one not working like it should. I’ll let you know how it goes.
                                      SdeGeata
                                      Well, since my post yesterday, I’ve not got past building Open CV 4. Hangs at 20%, or 73%, or 100% and eventually freezes. it never finishes the compilation.
                                      I completely wiped my SD card and did a fresh install of Rasbian - just to see if that would make a difference. So far, no go. I’m losing patience with this thing. It’s been well over a week that i’ve been fiddling around with various face recognition modules that kinda half work. i am anxious to try yours - i just can’t get past the Open CV bugs on install.
                                      What should I do???
                                      • nischiN
                                        nischi @SdeGeata
                                        @SdeGeata
                                        Sorry to hear that you have some issue to install OpenCV. Which Hardware do you have? On my Raspi 3+ it works fine, first run and all compiled.
                                        Whats really important is that you extend your Swap, otherwise you will have some issues like you described.
                                        Did you go through this documentation? https://www.pyimagesearch.com/2018/09/26/install-opencv-4-on-your-raspberry-pi/
                                        sudo nano /etc/dphys-swapfile
                                        # set size to absolute value, leaving empty (default) then uses computed value
                                        #   you most likely don't want this, unless you have an special disk situation
                                        # CONF_SWAPSIZE=100
                                        CONF_SWAPSIZE=2048
                                        sudo /etc/init.d/dphys-swapfile stop
                                        sudo /etc/init.d/dphys-swapfile start
                                        Note: Increasing swap size is a great way to burn out your Raspberry Pi microSD card. Flash-based storage have limited number of writes you can perform until the card is essentially unable to hold the 1’s and 0’s anymore. We’ll only be enabling large swap for a short period of time, so it’s not a big deal.
                                          SdeGeata @nischi
                                          @nischi
                                          Hello again;
                                          I finally got Open CV 4 installed successfully, I am re-installing my mirror modules now.
                                          I did extend the swap to 2048, and that failed making -j4 and -j1. Finally I boosted the swap to 5000, it still failed on -j1, but it finally worked on -j2… go figure.
                                          I was pretty tired of f**cking around trying to get that to install, it was pretty discouraging.
                                          Thanks for your help and I will let you know how it goes once I get your new module installed.
                                          • nischiN
                                            nischi @SdeGeata
                                            @SdeGeata
                                            Sorry to hear that you had such problems to install OpenCV. Hope it works now and let me know how it works.
