    MMM-AssistantMk2 / MMM-Hotword Issue
    28 Posts 3 Posters 13.6k Views 3 Watching
      JonoGee
      I wonder if there is someone who can help me with this issue. I have been working with eouia to trying and get these modules working together. Unfortunately without any success. I am led to believe that the Snowboy module is not compatible with my system. The Mirror opens and then crashes immediately with the following error messages…
      [HOTWORD] Detector starts listening.
      /home/pi/MagicMirror/node_modules/electron/dist/electron js/electron.js: symbol lookup error: /home/pi/MagicMirror/modules/MMM-Hotword/snowboy/lib/node/binding/Release/electron-v3.0-linux-arm/snowboy.node: undefined symbol: cblas_sdot
      npm ERR! file sh
      npm ERR! code ELIFECYCLE
      npm ERR! errno ENOENT
      npm ERR! syscall spawn
      npm ERR! magicmirror@2.7.1 start: `sh run-start.sh`
      npm ERR! spawn ENOENT
      npm ERR!
      npm ERR! Failed at the magicmirror@2.7.1 start script.
      npm ERR!     /home/pi/.npm/_logs/2019-06-26T15_09_51_093Z-debug.log
      I really hope someone can help me with this.
      Regards
      Jonathan
        @JonoGee said in MMM-AssistantMk2 / MMM-Hotword Issue:
        cblas_
        u are missing the cblas library
        google search ‘cblas install’
          JonoGee @sdetweil
          @sdetweil Is it the LAPACK I need to install then?
            sdetweil @JonoGee
            @JonoGee I don’t know… looking at the snowboy error itself and issues reported
            https://github.com/Kitt-AI/snowboy/issues/54
            the suggested fix is
            sudo apt-get install libatlas-base-dev libatlas3gf-base
              JonoGee @sdetweil
              @sdetweil I get this error message…
              pi@raspberrypi:~/MagicMirror $ sudo apt-get install libatlas-base-dev libatlas3gf-base
              Reading package lists... 0%
              Reading package lists... Done
              Building dependency tree
              E: Unable to locate package libatlas3gf-base
                sdetweil @JonoGee
                @JonoGee have u tried starting MM now?
                  JonoGee @sdetweil
                  @sdetweil Just. Still crashing with the same error message
                  J S 2 Replies Last reply Reply Quote 0
                    JonoGee @JonoGee
                    @JonoGee There is discussion about this here…
                    https://github.com/Kitt-AI/snowboy/issues/126
                    But i don’t understand what commands I need to run. It doesn’t read very clear to my only being an absolute amateur and all. Does it make sense to you?
                      sdetweil @JonoGee
                      @JonoGee is this a pi zero?
                      didn’t install libatlas-base-dev.
                      may have to install openblas
                      I had to on my odroid
                        JonoGee @sdetweil
                        @sdetweil No. its a Pi3 B+
                        How do i install openblas then?
                          sdetweil @JonoGee
                          @JonoGee Google search. What is r u running raspian, ubuntu?
                            JonoGee @sdetweil
                            @sdetweil Hi good morning. I am running Raspian.
                              JonoGee @JonoGee
                              @JonoGee
                              Error message I am getting now in console is as so…
                              MMM-GoogleTasks received a module notification: HOTWORD_SLEEPING from sender: MMM-Hotword
                              module.js:154 MMM-WatchDog received a module notification: HOTWORD_SLEEPING from sender: MMM-Hotword
                              module.js:154 MMM-Cursor received a module notification: HOTWORD_SLEEPING from sender: MMM-Hotword
                              null:1 GET http://0.0.0.0:8080/modules/MMM-Hotword/null 404 (Not Found)
                              module.js:154 MMM-Tools received a module notification: CALENDAR_EVENTS from sender: calendar
                              module.js:154 clock received a module notification: CALENDAR_EVENTS from sender: calendar
                              I have managed to get AssistantMk2 talking to me now in mirror but Hotword/Mic is still not functioning
                                sdetweil @JonoGee
                                @JonoGee hm… used to be that you needed MMM-Hotword to hear the Alexa or OK Google (or whatever special ‘Hot’ word), that signaled MMM_AssistantMk2 to listen for search words or commands…
                                each used the mic separately, Hotword first, then Assistant.
                                I know Sean has released new versions, which I haven’t tested yet
                                  JonoGee @sdetweil
                                  @sdetweil As far as I am aware, I have used the latest released versions of each. I guess I’ll just have to wait and see if someone updates it or fixes problem or something. Thanks anyway for your time and help. I have made a bit of progress though. It just seems to be Snowboy now.
                                    BJ Duncan
                                    Have you test your microphone to see if it working in general?
                                    From home directory:
                                    arecord test.wav
                                    and talk for about 5 seconds into your microphone.
                                    Then cancel that by Ctrl+C
                                    Once you have cancelled the test check your directory to ensure that the ‘test.wav’ file is there:
                                    dir
                                    if your file shows up then you can test that file to ensure it recorded your voice from the microphone:
                                    aplay test.wav
                                    You should be able to hear back what you just recorded.
                                    If you can, that means it is a configuration setting that just needs to be tweaked. If not, then there is something wrong with either the microphone settings or audio settings within the pi itself.
                                    I will keep monitoring and let me know how you go.
                                    Regards,
                                    BJ Duncan
                                      JonoGee
                                      Just tested. Recording & playing back fine with arecord and aplay. No problems and no error messages. Thanks for taking the time for getting in touch anyway. I’d almost given up on this.
                                        BJ Duncan
                                        No dramas at all.
                                        Now you need to double check that you are pointing to the correct device number for your audio with the Assistant module.
                                        In a terminal at the root directory (pi@raspberrypi:~ ) Check the device list for audio input:
                                        arecord -l
                                        This should provide you a list of CAPTURE Hardware Devices. The numbers you want to write down is the Card number, and device number.
                                        As an example on my device I have it as Card: 2 Device: 0
                                        Now within the config.js of the MagicMirror ensure that the device number is the same. Here is what it looks like within my config.js:
                                        		  module: "MMM-AssistantMk2",
                                        		  position: "bottom_bar",
                                        		    record: {
                                        		      recordProgram : "arecord",
                                        		      device        : "plughw:2",
                                        		    notifications: {
                                        		      ASSISTANT_ACTIVATED: "HOTWORD_PAUSE",
                                        		      ASSISTANT_DEACTIVATED: "HOTWORD_RESUME",
                                        		  module: "MMM-Hotword",
                                        		    chimeOnFinish:null,
                                        		    mic: {
                                        		    models: [
                                        		        hotwords    : "smart_mirror",
                                        		        file        : "smart_mirror.umdl",
                                        		        sensitivity : "0.5",
                                        		    defaultCommand: {
                                        		      notificationExec: {
                                        		        notification: "ASSISTANT_ACTIVATE",
                                        		        payload: (detected, afterRecord) => {
                                        		          return {profile:"default"}
                                        		      afterRecordLimit:0,
                                        		      restart:false,
                                        Notice within both my modules because my card number is ‘2’, that the
                                        So make sure your number corresponds with your Card number.
                                        Give that a test and we will go from there.
                                        Regards,
                                        BJ Duncan
                                          JonoGee @BJ Duncan
                                          @BJ-Duncan said in MMM-AssistantMk2 / MMM-Hotword Issue:
                                          arecord -l
                                          I get this…
                                          pi@raspberrypi:~ $ arecord -l
                                          **** List of CAPTURE Hardware Devices ****
                                          card 0: sndrpigooglevoi [snd_rpi_googlevoicehat_soundcar], device 0: Google voiceHAT SoundCard HiFi voicehat-codec-0 []
                                            Subdevices: 1/1
                                            Subdevice #0: subdevice #0
                                          pi@raspberrypi:~ $
                                            JonoGee @JonoGee
                                            @JonoGee I recognised both devices as 0 so I changed accordingly. Now i get this error message. Mirror opens but closes immediately…
                                            [MMM-PushBulletNotifications][Info] 13:58:15.164 - PushBullet connected
                                            [HOTWORD] begins.
                                            npm ERR! file sh
                                            npm ERR!
                                            npm ERR!     /home/pi/.npm/_logs/2019-07-01T12_58_15_977Z-debug.log
