    MMM-AssistantMk2 / MMM-Hotword Issue
    28 Posts 3 Posters 12.6k Views 3 Watching
      @JonoGee said in MMM-AssistantMk2 / MMM-Hotword Issue:
      cblas_
      u are missing the cblas library
      google search ‘cblas install’
        JonoGee @sdetweil
        @sdetweil Is it the LAPACK I need to install then?
          sdetweil @JonoGee
          @JonoGee I don’t know… looking at the snowboy error itself and issues reported
          https://github.com/Kitt-AI/snowboy/issues/54
          the suggested fix is
          sudo apt-get install libatlas-base-dev libatlas3gf-base
            JonoGee @sdetweil
            @sdetweil I get this error message…
            pi@raspberrypi:~/MagicMirror $ sudo apt-get install libatlas-base-dev libatlas3gf-base
            Reading package lists... 0%
            Reading package lists... Done
            Building dependency tree
            E: Unable to locate package libatlas3gf-base
              sdetweil @JonoGee
              @JonoGee have u tried starting MM now?
                JonoGee @sdetweil
                @sdetweil Just. Still crashing with the same error message
                J S 2 Replies Last reply Reply Quote 0
                  JonoGee @JonoGee
                  @JonoGee There is discussion about this here…
                  https://github.com/Kitt-AI/snowboy/issues/126
                  But i don’t understand what commands I need to run. It doesn’t read very clear to my only being an absolute amateur and all. Does it make sense to you?
                    sdetweil @JonoGee
                    @JonoGee is this a pi zero?
                    didn’t install libatlas-base-dev.
                    may have to install openblas
                    I had to on my odroid
                      JonoGee @sdetweil
                      @sdetweil No. its a Pi3 B+
                      How do i install openblas then?
                        sdetweil @JonoGee
                        @JonoGee Google search. What is r u running raspian, ubuntu?
