    MMM-AssistantMk2 / MMM-Hotword Issue
    28 Posts 3 Posters 14.7k Views 3 Watching
      sdetweil @JonoGee
      @JonoGee Google search. What is r u running raspian, ubuntu?
        JonoGee @sdetweil
        @sdetweil Hi good morning. I am running Raspian.
          JonoGee @JonoGee
          @JonoGee
          Error message I am getting now in console is as so…
          MMM-GoogleTasks received a module notification: HOTWORD_SLEEPING from sender: MMM-Hotword
          module.js:154 MMM-WatchDog received a module notification: HOTWORD_SLEEPING from sender: MMM-Hotword
          module.js:154 MMM-Cursor received a module notification: HOTWORD_SLEEPING from sender: MMM-Hotword
          null:1 GET http://0.0.0.0:8080/modules/MMM-Hotword/null 404 (Not Found)
          module.js:154 MMM-Tools received a module notification: CALENDAR_EVENTS from sender: calendar
          module.js:154 clock received a module notification: CALENDAR_EVENTS from sender: calendar
          I have managed to get AssistantMk2 talking to me now in mirror but Hotword/Mic is still not functioning
            sdetweil @JonoGee
            @JonoGee hm… used to be that you needed MMM-Hotword to hear the Alexa or OK Google (or whatever special ‘Hot’ word), that signaled MMM_AssistantMk2 to listen for search words or commands…
            each used the mic separately, Hotword first, then Assistant.
            I know Sean has released new versions, which I haven’t tested yet
              JonoGee @sdetweil
              @sdetweil As far as I am aware, I have used the latest released versions of each. I guess I’ll just have to wait and see if someone updates it or fixes problem or something. Thanks anyway for your time and help. I have made a bit of progress though. It just seems to be Snowboy now.
                BJ Duncan
                Have you test your microphone to see if it working in general?
                From home directory:
                arecord test.wav
                and talk for about 5 seconds into your microphone.
                Then cancel that by Ctrl+C
                Once you have cancelled the test check your directory to ensure that the ‘test.wav’ file is there:
                dir
                if your file shows up then you can test that file to ensure it recorded your voice from the microphone:
                aplay test.wav
                You should be able to hear back what you just recorded.
                If you can, that means it is a configuration setting that just needs to be tweaked. If not, then there is something wrong with either the microphone settings or audio settings within the pi itself.
                I will keep monitoring and let me know how you go.
                Regards,
                BJ Duncan
                  JonoGee
                  Just tested. Recording & playing back fine with arecord and aplay. No problems and no error messages. Thanks for taking the time for getting in touch anyway. I’d almost given up on this.
                    BJ Duncan
                    No dramas at all.
                    Now you need to double check that you are pointing to the correct device number for your audio with the Assistant module.
                    In a terminal at the root directory (pi@raspberrypi:~ ) Check the device list for audio input:
                    arecord -l
                    This should provide you a list of CAPTURE Hardware Devices. The numbers you want to write down is the Card number, and device number.
                    As an example on my device I have it as Card: 2 Device: 0
                    Now within the config.js of the MagicMirror ensure that the device number is the same. Here is what it looks like within my config.js:
                    		  module: "MMM-AssistantMk2",
                    		  position: "bottom_bar",
                    		    record: {
                    		      recordProgram : "arecord",
                    		      device        : "plughw:2",
                    		    notifications: {
                    		      ASSISTANT_ACTIVATED: "HOTWORD_PAUSE",
                    		      ASSISTANT_DEACTIVATED: "HOTWORD_RESUME",
                    		  module: "MMM-Hotword",
                    		    chimeOnFinish:null,
                    		    mic: {
                    		    models: [
                    		        hotwords    : "smart_mirror",
                    		        file        : "smart_mirror.umdl",
                    		        sensitivity : "0.5",
                    		    defaultCommand: {
                    		      notificationExec: {
                    		        notification: "ASSISTANT_ACTIVATE",
                    		        payload: (detected, afterRecord) => {
                    		          return {profile:"default"}
                    		      afterRecordLimit:0,
                    		      restart:false,
                    Notice within both my modules because my card number is ‘2’, that the
                    So make sure your number corresponds with your Card number.
                    Give that a test and we will go from there.
                    Regards,
                    BJ Duncan
                      JonoGee @BJ Duncan
                      @BJ-Duncan said in MMM-AssistantMk2 / MMM-Hotword Issue:
                      arecord -l
                      I get this…
                      pi@raspberrypi:~ $ arecord -l
                      **** List of CAPTURE Hardware Devices ****
                      card 0: sndrpigooglevoi [snd_rpi_googlevoicehat_soundcar], device 0: Google voiceHAT SoundCard HiFi voicehat-codec-0 []
                        Subdevices: 1/1
                        Subdevice #0: subdevice #0
                      pi@raspberrypi:~ $
                        JonoGee @JonoGee
                        @JonoGee I recognised both devices as 0 so I changed accordingly. Now i get this error message. Mirror opens but closes immediately…
                        [MMM-PushBulletNotifications][Info] 13:58:15.164 - PushBullet connected
                        [HOTWORD] begins.
                        [HOTWORD] Detector starts listening.
                        /home/pi/MagicMirror/node_modules/electron/dist/electron js/electron.js: symbol lookup error: /home/pi/MagicMirror/modules/MMM-Hotword/snowboy/lib/node/binding/Release/electron-v3.0-linux-arm/snowboy.node: undefined symbol: cblas_sdot
                        npm ERR! file sh
                        npm ERR! code ELIFECYCLE
                        npm ERR! errno ENOENT
                        npm ERR! syscall spawn
                        npm ERR! magicmirror@2.7.1 start: `sh run-start.sh`
                        npm ERR! spawn ENOENT
                        npm ERR!
                        npm ERR! Failed at the magicmirror@2.7.1 start script.
                        npm ERR!     /home/pi/.npm/_logs/2019-07-01T12_58_15_977Z-debug.log
                        pi@raspberrypi:~/MagicMirror $
                          JonoGee @JonoGee
                          @JonoGee If devices are set as…
                          hw:0,0
                          The mirror works, but Assistant/Hotword doesm’t. I just changed to …```
                          plughw:0
                          and it crashes
                            BJ Duncan
                            What type of microphone is it? Is it USB?
                            Also, what version of Raspbian are you using? And is it Raspberry Pi 3+ ?
                            Regards,
                            BJ Duncan
                              JonoGee @BJ Duncan
                              @BJ-Duncan
                              The Mic is a combined Speaker / Mic HAT as see here… https://www.raspiaudio.com/raspiaudio-aiy
                              I am running Raspberry Pi3+
                              Version…
                              pi@raspberrypi:~ $ lsb_release -a
                              No LSB modules are available.
                              Distributor ID:	Raspbian
                              Description:	Raspbian GNU/Linux 9.9 (stretch)
                              Release:	9.9
                              Codename:	stretch
                              pi@raspberrypi:~ $
                                BJ Duncan
                                Sorry @JonoGee mate, I may not be the best person to resolve as I have USB Mic so my settings will be different to yours.
                                I will attempt to do some research for you though and see if I can assist with a solution.
                                Regards,
                                BJ Duncan
                                  JonoGee @BJ Duncan
                                  @BJ-Duncan
                                  I realise both Speaker & Mic are on same Hat but does it make sense to you that the ID for aplay and arecord are exactly the same. Code included below…
                                  pi@raspberrypi:~ $ aplay -l
                                  **** List of PLAYBACK Hardware Devices ****
                                    Subdevices: 1/1
                                    Subdevices: 1/1
                                  pi@raspberrypi:~ $
                                    JonoGee @JonoGee
                                    @JonoGee I mean I supposedly I have to set both IDs in config file to hw:0,0.
                                      JonoGee @BJ Duncan
                                      @BJ-Duncan What Mic do you use mate? I might just buy same one.lol
                                        BJ Duncan
                                        Hey @JonoGee, mate I have been researching but to no avail. Sorry mate on that. I’m just not too familiar with your set up.
                                        The Mic and Speakers I got are just some cheap USB type models.
                                        Speakers | Mic
                                        If you do go by this type of setup then the previous code I placed up should work #fingersCrossed ;-)
                                        Regards,
                                        BJ Duncan
