    MMM-AssistantMk2 / MMM-Hotword Issue
    28 Posts 3 Posters 14.5k Views 3 Watching
      JonoGee @sdetweil
      @sdetweil Is it the LAPACK I need to install then?
        sdetweil @JonoGee
        @JonoGee I don’t know… looking at the snowboy error itself and issues reported
        https://github.com/Kitt-AI/snowboy/issues/54
        the suggested fix is
        sudo apt-get install libatlas-base-dev libatlas3gf-base
          JonoGee @sdetweil
          @sdetweil I get this error message…
          pi@raspberrypi:~/MagicMirror $ sudo apt-get install libatlas-base-dev libatlas3gf-base
          Reading package lists... 0%
          Reading package lists... Done
          Building dependency tree
          E: Unable to locate package libatlas3gf-base
            sdetweil @JonoGee
            @JonoGee have u tried starting MM now?
              JonoGee @sdetweil
              @sdetweil Just. Still crashing with the same error message
              J S 2 Replies Last reply Reply Quote 0
                JonoGee @JonoGee
                @JonoGee There is discussion about this here…
                https://github.com/Kitt-AI/snowboy/issues/126
                But i don’t understand what commands I need to run. It doesn’t read very clear to my only being an absolute amateur and all. Does it make sense to you?
                  sdetweil @JonoGee
                  @JonoGee is this a pi zero?
                  didn’t install libatlas-base-dev.
                  may have to install openblas
                  I had to on my odroid
                    JonoGee @sdetweil
                    @sdetweil No. its a Pi3 B+
                    How do i install openblas then?
                      sdetweil @JonoGee
                      @JonoGee Google search. What is r u running raspian, ubuntu?
                        JonoGee @sdetweil
                        @sdetweil Hi good morning. I am running Raspian.
                          JonoGee @JonoGee
                          @JonoGee
                          Error message I am getting now in console is as so…
                          MMM-GoogleTasks received a module notification: HOTWORD_SLEEPING from sender: MMM-Hotword
                          module.js:154 MMM-WatchDog received a module notification: HOTWORD_SLEEPING from sender: MMM-Hotword
                          module.js:154 MMM-Cursor received a module notification: HOTWORD_SLEEPING from sender: MMM-Hotword
                          null:1 GET http://0.0.0.0:8080/modules/MMM-Hotword/null 404 (Not Found)
                          module.js:154 MMM-Tools received a module notification: CALENDAR_EVENTS from sender: calendar
                          module.js:154 clock received a module notification: CALENDAR_EVENTS from sender: calendar
                          I have managed to get AssistantMk2 talking to me now in mirror but Hotword/Mic is still not functioning
                            sdetweil @JonoGee
                            @JonoGee hm… used to be that you needed MMM-Hotword to hear the Alexa or OK Google (or whatever special ‘Hot’ word), that signaled MMM_AssistantMk2 to listen for search words or commands…
                            each used the mic separately, Hotword first, then Assistant.
                            I know Sean has released new versions, which I haven’t tested yet
                              JonoGee @sdetweil
                              @sdetweil As far as I am aware, I have used the latest released versions of each. I guess I’ll just have to wait and see if someone updates it or fixes problem or something. Thanks anyway for your time and help. I have made a bit of progress though. It just seems to be Snowboy now.
                                BJ Duncan
                                Have you test your microphone to see if it working in general?
                                From home directory:
                                arecord test.wav
                                and talk for about 5 seconds into your microphone.
                                Then cancel that by Ctrl+C
                                Once you have cancelled the test check your directory to ensure that the ‘test.wav’ file is there:
                                dir
                                if your file shows up then you can test that file to ensure it recorded your voice from the microphone:
                                aplay test.wav
                                You should be able to hear back what you just recorded.
                                If you can, that means it is a configuration setting that just needs to be tweaked. If not, then there is something wrong with either the microphone settings or audio settings within the pi itself.
                                I will keep monitoring and let me know how you go.
                                Regards,
                                BJ Duncan
                                  JonoGee
                                  Just tested. Recording & playing back fine with arecord and aplay. No problems and no error messages. Thanks for taking the time for getting in touch anyway. I’d almost given up on this.
                                    BJ Duncan
                                    No dramas at all.
                                    Now you need to double check that you are pointing to the correct device number for your audio with the Assistant module.
                                    In a terminal at the root directory (pi@raspberrypi:~ ) Check the device list for audio input:
                                    arecord -l
                                    This should provide you a list of CAPTURE Hardware Devices. The numbers you want to write down is the Card number, and device number.
                                    As an example on my device I have it as Card: 2 Device: 0
                                    Now within the config.js of the MagicMirror ensure that the device number is the same. Here is what it looks like within my config.js:
                                    		  module: "MMM-AssistantMk2",
                                    		  position: "bottom_bar",
                                    		    record: {
                                    		      recordProgram : "arecord",
                                    		      device        : "plughw:2",
                                    		    notifications: {
                                    		      ASSISTANT_ACTIVATED: "HOTWORD_PAUSE",
                                    		      ASSISTANT_DEACTIVATED: "HOTWORD_RESUME",
                                    		  module: "MMM-Hotword",
                                    		    chimeOnFinish:null,
                                    		    mic: {
                                    		    models: [
                                    		        hotwords    : "smart_mirror",
                                    		        file        : "smart_mirror.umdl",
                                    		        sensitivity : "0.5",
                                    		    defaultCommand: {
                                    		      notificationExec: {
                                    		        notification: "ASSISTANT_ACTIVATE",
                                    		        payload: (detected, afterRecord) => {
                                    		          return {profile:"default"}
                                    		      afterRecordLimit:0,
                                    		      restart:false,
                                    Notice within both my modules because my card number is ‘2’, that the
                                    So make sure your number corresponds with your Card number.
                                    Give that a test and we will go from there.
                                    Regards,
                                    BJ Duncan
                                      JonoGee @BJ Duncan
                                      @BJ-Duncan said in MMM-AssistantMk2 / MMM-Hotword Issue:
                                      arecord -l
                                      I get this…
                                      pi@raspberrypi:~ $ arecord -l
                                      **** List of CAPTURE Hardware Devices ****
                                      card 0: sndrpigooglevoi [snd_rpi_googlevoicehat_soundcar], device 0: Google voiceHAT SoundCard HiFi voicehat-codec-0 []
                                        Subdevices: 1/1
                                        Subdevice #0: subdevice #0
                                      pi@raspberrypi:~ $
                                        JonoGee @JonoGee
                                        @JonoGee I recognised both devices as 0 so I changed accordingly. Now i get this error message. Mirror opens but closes immediately…
                                        [MMM-PushBulletNotifications][Info] 13:58:15.164 - PushBullet connected
                                        [HOTWORD] begins.
                                        [HOTWORD] Detector starts listening.
                                        /home/pi/MagicMirror/node_modules/electron/dist/electron js/electron.js: symbol lookup error: /home/pi/MagicMirror/modules/MMM-Hotword/snowboy/lib/node/binding/Release/electron-v3.0-linux-arm/snowboy.node: undefined symbol: cblas_sdot
                                        npm ERR! file sh
                                        npm ERR! code ELIFECYCLE
                                        npm ERR! errno ENOENT
                                        npm ERR! syscall spawn
                                        npm ERR! magicmirror@2.7.1 start: `sh run-start.sh`
                                        npm ERR! spawn ENOENT
                                        npm ERR!
                                        npm ERR! Failed at the magicmirror@2.7.1 start script.
                                        npm ERR!     /home/pi/.npm/_logs/2019-07-01T12_58_15_977Z-debug.log
                                          JonoGee @JonoGee
                                          @JonoGee If devices are set as…
                                          hw:0,0
                                          The mirror works, but Assistant/Hotword doesm’t. I just changed to …```
                                          plughw:0
                                          and it crashes
                                            BJ Duncan
                                            What type of microphone is it? Is it USB?
                                            Also, what version of Raspbian are you using? And is it Raspberry Pi 3+ ?
                                            Regards,
                                            BJ Duncan
