    Worked for 5 minutes...
    5 Posts 3 Posters 1.4k Views 2 Watching
      Chritix
      After finally getting MM to boot with all the modules appearing on screen, one of the messages was to have the master bench updated, 2500 behind.
      Once I was able to get the update to go through, I rebooted and poof. Mama loads but it’s an entirely black screen with no modules.
      How do I bring them back?
      I know very little about the command lines so talk very slow and spell out the cmd lines for me please! thank you for any help.
      • bheplerB Offline
        bhepler Module Developer @Chritix
        @Chritix - Did you remember to run the install commands after you did the upgrade?
        npm install
        cd modules
        [ go into each module folder and enter:]
        npm install
        C S 2 Replies Last reply Reply Quote 0
          Chritix @bhepler
          @bhepler I didn’t. and that fixed it. tyvm.
            sdetweil @bhepler
            @bhepler we should start a new script for upgrades
            installers/upgrade
            #!/bin/bash
            # change to MagicMirror folder
            # get the latest upgrade
            if git pull; then
              # update any dependencies for base
              if npm install;
                # process updates for modules after base chnaged
                cd modules
                # get the list of modules with  package.json files
                find  -maxdepth 2 -name 'package.json'  | while IFS= read -r FILE; do
                  echo "processing for module " $(dirname $FILE)
                  # change to that directory
                  cd  $(dirname $FILE)
                    # process its dependencies
                    npm install
                  # return to modules folder
                  cd - >/dev/null
                done
                return to Magic Mirror folder
                cd - >/dev/null
              fi
            else
              echo git pull failed
              # return to original folder
              cd - >/dev/null
            fi
            S 1 Reply Last reply Reply Quote 3
              see dedicated topic and call for collaboration
              https://forum.magicmirror.builders/topic/10729/new-script-for-mirror-release-upgrades
