    Can't rotate touchinterface to portrait mode HELP!!!
    5 Posts 3 Posters 3.0k Views 2 Watching
      M1K3rSz
      Anyone know if its possible to get the screen (42") to run in portrait mode “with” touch (USB) functionality? The display and touch work great in landscape mode, but I cannot get it to work in portrait.
      Adding the following in the config.txt seem to have no effect on touch:
      display_rotate=3
      or
      lcd_rotate=3
      However, lcd_rotate=3 does rotate screen but no luck on touch interface
      I’m running the latest MM2 v2.3.1 config, on a Raspberry Pi 3.
      Please help!!
        M1K3rSz
        For Real??
        Nobody can help me?
          broberg Project Sponsor @M1K3rSz
          @M1K3rSz give xinput_calibrator a try : https://www.raspberrypi.org/forums/viewtopic.php?t=78805
          Other than that I can not help you.
          • G
            gverbist
            I want to re-up this case as in my opinion this was never solved. I am using the new GL driver and now facing the same issue as the initial poster.
            How do you rotate the touch interface. Its a iyama screen with build in touch
              broberg Project Sponsor @gverbist
              @gverbist Try rotating the content of the webpage instead of rotating the entire screen.
              https://forum.magicmirror.builders/topic/9707/save-performance-when-rotating-screen-e-g-on-raspberry-pi
