    MMM-Loxone
    loxonesmart home
    94 Posts 11 Posters 108.9k Views 14 Watching
    • idoodlerI Offline
      idoodler Module Developer @bobbythemoh
      @bobbythemoh I am currently unable to test it on a Raspberry Pi running Raspbian, because I am working on another project. Please try to execute /opt/vc/bin/tvservice -o, this will turn off the HTMI port, if this won’t work there may be an issue with the last update of Rasbian.
      I am currently anyway working on another method to toggle the HDMI port on different operating systems, so I may resolve this anyway.
        bobbythemoh
        @idoodler Hey, i tried the following things:
        in config.js I set presence “false”; restart but after the MM is loaded, screen is getting dark. The only was to get a monitor signal is to restart with light in the room switched on although presence is “false”.
        If the display was dark it does not come back any more:
        I tried tvservice -o: It switches off HDMI, i can see the monitor going to sleep (flashing Power LED)
        I tried tvservice -p: i can see the monitor coming alive but only with a black screen (constant Power LED).
        If HDMI is on (-p) by connecting to the MM via VNC i can press STRG+Q to close MM; i can see the deskop on VNC but no change on the real Monitor.
        So to summarize: if tvservice -o was set, the monitor signal does not come back any more (besides restart with light in the room)
        idoodlerI 1 Reply Last reply Reply Quote 0
        • idoodlerI Offline
          @bobbythemoh I just double checked the code, if you disable the presence property there is no way to toggle the display by the Loxone Module. Do you see the log message Got lightMood change to: All off(778) after you disable the presence property.
          The Monitor is directly toggled after the log command.
            bobbythemoh
            @idoodler Hey,
            In the config.js it says:
                                    module: "MMM-Loxone",
                                    position: "bottom_left",
                                            host: "IP",
                                            user: "User",
                                            pwd: "PW",
                                            presence: "false",
                                            roomUuid: "0ea3ebd1-00eb-04ef-ffff390cde3b9b45",
                                            showInfoNotifications: "true",
                                            showErrorNotifications: "true",
                                            showSystemNotifications: "true",
                                            observingUuids:[
                                                            "103d9aaf-0037-597e-ffff390cde3b9b45",//Bad Luftfeuchte
                                                            "104c401f-03a0-9afc-ffff390cde3b9b45",//WarmwasserTemp
            I switched on the monitor with light on, picture was there, i toggled the light to off, MM image is gone and does not come back. To your question, here is the log file, i can see the “got ligtmode”.
            /home/pi/.pm2/logs/MagicMirror-out-0.log last 15 lines:
            0|MagicMir | Create new news fetcher for url: http://derStandard.at/?page=rss&ressort=Seite1 - Interval: 300000
            0|MagicMir | Create new news fetcher for url: https://rss.orf.at/news.xml - Interval: 300000
            0|MagicMir | Opening Socket to your Miniserver
            0|MagicMir | MMM-Loxone Download LoxApp3.json
            0|MagicMir | MMM-Loxone Search room with uuid: 0ea3ebd1-00eb-04ef-ffff390cde3b9b45
            0|MagicMir | MMM-Loxone Found room: OG Bad
            0|MagicMir | MMM-Loxone Search IRC for room temperature
            0|MagicMir | MMM-Loxone Found IRC (Intelligente Raumregelung) in room OG Bad
            0|MagicMir | MMM-Loxone Search LightControls and LightV2Controls in room
            0|MagicMir | MMM-Loxone Found LightControl (Badezimmerlicht) in room OG Bad
            0|MagicMir | MMM-Loxone NotificationUuid: 0ea3ebd1-008d-029d-ffff390cde3b9b45
            0|MagicMir | MMM-Loxone Enabling statusupdates
            0|MagicMir | MMM-Loxone Successfully executed 'dev/sps/enablebinstatusupdate' with code 200 and value 1
            0|MagicMir | MMM-Loxone Got room temperature: 22.9
            0|MagicMir | MMM-Loxone Got lightMood change to: Custom mode(1)
            0|MagicMir | MMM-Loxone Got lightMood change to: All on(777)
            0|MagicMir | MMM-Loxone Got lightMood change to: All off(778)
            • idoodlerI Offline
              @bobbythemoh Oh, now everything makes sense. You have errors in your config.js.
              Boolean values must not be strings. Replace "true" and "false" with true and false. in Javascript "false" is equal to true, so you basically have presence enabled :winking_face:
                bobbythemoh
                Hey, uncommenting the Room UUID gives with presence “false”:
                0|MagicMir | MMM-Loxone Search room with uuid: null
                0|MagicMir | MMM-Loxone Couldn't find Room!
                Now i can do whatever i want with the light, the video is ok.
                • idoodlerI Offline
                  @bobbythemoh Yes, it looks like there is an issue with tvservice with one of the last Raspbian updates. I am looking into fixing this and also support more operating systems.
                    bobbythemoh @idoodler
                    @idoodler OMG. thats what happens when an mechanical engineer works with code… sorry… :D i guess that was the reason why it takes long to start the MM, at least now its faster.
                    OK the presence problem is fixed, but the Display problem remains…
                      @idoodler thanks for the help als always, looking forward for the module working again, my wife already complained that she is missing it now that it is not there (first she complained that it is there) :D
                      idoodlerI 2 Replies Last reply Reply Quote 1
                      • idoodlerI Offline
                        @bobbythemoh Thanks for informing me about that issue. I am currently working on something else, so I had to ditch my current installation.
                        Schönen Abend noch;)
                        • idoodlerI Offline
                          @bobbythemoh Hi, I have good news for you, I just pushed a fix. Please update MMM-Loxone for it to work again. I also made it a bit faster, I hope your wife will be happy again:smiling_face_with_open_mouth_smiling_eyes:
                          Btw. This issue semes to be related to one of the latest Raspbian updates, I assume its because the new Raspberry Pi has two HDMI outputs, so there may be some changes to the HDMI related code…
                            @idoodler Hey, i just updated. works perfectly again. Thanks a lot.
                              Phil__
                              how can I change the font size?
                              The Font size of the displayed observingUuids…
                                bobbythemoh
                                @idoodler I have to ask for help again:
                                Just updated my Magic Mirror with
                                cd MagicMirror
                                git pull
                                npm install
                                Its Version is 2.9.0.
                                Now i am not able to start the Module any more…
                                pm2 Log gives:
                                0|MagicMir | Connecting socket for: MMM-Loxone
                                0|MagicMir | Connecting socket for: calendar
                                0|MagicMir | Starting node helper for: calendar
                                0|MagicMir | Connecting socket for: MMM-RPI-LED
                                0|MagicMir | Starting module helper: MMM-RPI-LED
                                0|MagicMir | Connecting socket for: MMM-MoonPhase
                                0|MagicMir | Starting module helper: MMM-MoonPhase
                                0|MagicMir | Connecting socket for: newsfeed
                                0|MagicMir | Starting module: newsfeed
                                0|MagicMir | Sockets connected & modules started ...
                                0|MagicMir | Launching application.
                                0|MagicMir | ATTENTION: default value of option force_s3tc_enable overridden by environment.
                                0|MagicMir | Create new calendar fetcher for url: http://localhost:8080/modules/calendars/ - Interval: 300000
                                0|MagicMir | (node:1367) UnhandledPromiseRejectionWarning: RangeError [ERR_OUT_OF_RANGE]: The value of "value" is out of range. It must be >= 0 and <= 4294967295. Received -1344780921
                                0|MagicMir |     at checkInt (internal/buffer.js:35:11)
                                0|MagicMir |     at writeU_Int32BE (internal/buffer.js:625:3)
                                0|MagicMir |     at Buffer.writeUInt32BE (internal/buffer.js:638:10)
                                0|MagicMir |     at WebSocketFrame.toBuffer (/home/pi/MagicMirror/modules/MMM-Loxone/node_modules/websocket/lib/WebSocketFrame.js:257:24)
                                0|MagicMir |     at WebSocketConnection.sendFrame (/home/pi/MagicMirror/modules/MMM-Loxone/node_modules/websocket/lib/WebSocketConnection.js:857:43)
                                0|MagicMir |     at WebSocketConnection.fragmentAndSend (/home/pi/MagicMirror/modules/MMM-Loxone/node_modules/websocket/lib/WebSocketConnection.js:793:14)
                                0|MagicMir |     at WebSocketConnection.sendUTF (/home/pi/MagicMirror/modules/MMM-Loxone/node_modules/websocket/lib/WebSocketConnection.js:733:10)
                                0|MagicMir |     at W3CWebSocket.send (/home/pi/MagicMirror/modules/MMM-Loxone/node_modules/websocket/lib/W3CWebSocket.js:116:26)
                                0|MagicMir |     at LxWebSocket.self.onSend (/home/pi/MagicMirror/modules/MMM-Loxone/node_modules/lxcommunicator/vendor/WebSocketWrapper.js:192:21)
                                0|MagicMir |     at LxWebSocket.send (/home/pi/MagicMirror/modules/MMM-Loxone/node_modules/lxcommunicator/vendor/WebSocketWrapper.js:253:14)
                                0|MagicMir | (node:1367) UnhandledPromiseRejectionWarning: Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch(). (rejection id: 1)
                                0|MagicMir | (node:1367) [DEP0018] DeprecationWarning: Unhandled promise rejections are deprecated. In the future, promise rejections that are not handled will terminate the Node.js process with a non-zero exit code.
                                0|MagicMir | Error: Malformed UTF-8 data
                                0|MagicMir |     at Object.stringify (/home/pi/MagicMirror/modules/MMM-Loxone/node_modules/crypto-js/core.js:478:24)
                                0|MagicMir |     at WordArray.init.toString (/home/pi/MagicMirror/modules/MMM-Loxone/node_modules/crypto-js/core.js:215:38)
                                0|MagicMir |     at Object.aesDecrypt (/home/pi/MagicMirror/modules/MMM-Loxone/node_modules/lxcommunicator/vendor/CryptoAdapter.js:189:26)
                                0|MagicMir |     at WebSocket._decryptResponse (/home/pi/MagicMirror/modules/MMM-Loxone/node_modules/lxcommunicator/modules/WebSocket.js:879:38)
                                0|MagicMir |     at WebSocket._handleResponse (/home/pi/MagicMirror/modules/MMM-Loxone/node_modules/lxcommunicator/modules/WebSocket.js:807:25)
                                0|MagicMir |     at WebSocket._textMessageHandler (/home/pi/MagicMirror/modules/MMM-Loxone/node_modules/lxcommunicator/modules/WebSocket.js:753:18)
                                0|MagicMir |     at W3CWebSocket.onmessage (/home/pi/MagicMirror/modules/MMM-Loxone/node_modules/lxcommunicator/vendor/WebSocketWrapper.js:99:56)
                                0|MagicMir |     at W3CWebSocket._dispatchEvent [as dispatchEvent] (/home/pi/MagicMirror/modules/MMM-Loxone/node_modules/yaeti/lib/EventTarget.js:107:17)
                                0|MagicMir |     at W3CWebSocket.onMessage (/home/pi/MagicMirror/modules/MMM-Loxone/node_modules/websocket/lib/W3CWebSocket.js:234:14)
                                0|MagicMir |     at WebSocketConnection.<anonymous> (/home/pi/MagicMirror/modules/MMM-Loxone/node_modules/websocket/lib/W3CWebSocket.js:205:19)
                                0|MagicMir | WebSocket: ERROR while parsing string: 'undefined'
                                0|MagicMir | SyntaxError: Unexpected token u in JSON at position 0
                                0|MagicMir |     at JSON.parse (<anonymous>)
                                0|MagicMir |     at WebSocket._handleResponse (/home/pi/MagicMirror/modules/MMM-Loxone/node_modules/lxcommunicator/modules/WebSocket.js:810:29)
                                0|MagicMir |     at WebSocketConnection.emit (events.js:182:13)
                                0|MagicMir |     at WebSocketConnection.processFrame (/home/pi/MagicMirror/modules/MMM-Loxone/node_modules/websocket/lib/WebSocketConnection.js:552:26)
                                0|MagicMir |     at /home/pi/MagicMirror/modules/MMM-Loxone/node_modules/websocket/lib/WebSocketConnection.js:321:40
                                0|MagicMir | WebSocket:  socket failed! WS Close Code: 1006
                                0|MagicMir | { errorCode: 418 }
                                • idoodlerI Offline
                                  @bobbythemoh Hi, did you make any changes to your Loxone installation?
                                  If not please try to reinstall the MMM-Loxone project.
                                    bobbythemoh
                                    Hey if you mean to the Mini-Server Software, than no. It was working perfectly before the update. Ok, ill try reinstalling.
                                      bobbythemoh
                                      Here is what I did:
                                      cd MagicMirror/Modules
                                      rm -rf MMM-Loxone
                                      cd ~/MagicMirror/modules
                                      git clone https://github.com/idoodler/MMM-Loxone
                                      cd ~/MagicMirror/modules/MMM-Loxone
                                      npm install
                                      npm install gives:
                                      pi@MagicMirror:~/MagicMirror/modules/MMM-Loxone $ npm install
                                      npm WARN deprecated time-grunt@2.0.0: Deprecated because Grunt is practically unmaintained. Move on to something bett er. This package will continue to work with Grunt v1, but it will not receive any updates.
                                      > websocket@1.0.29 install /home/pi/MagicMirror/modules/MMM-Loxone/node_modules/websocket
                                      > (node-gyp rebuild 2> builderror.log) || (exit 0)
                                      make: Entering directory '/home/pi/MagicMirror/modules/MMM-Loxone/node_modules/websocket/build'
                                        CXX(target) Release/obj.target/bufferutil/src/bufferutil.o
                                        SOLINK_MODULE(target) Release/obj.target/bufferutil.node
                                        COPY Release/bufferutil.node
                                        CXX(target) Release/obj.target/validation/src/validation.o
                                        SOLINK_MODULE(target) Release/obj.target/validation.node
                                        COPY Release/validation.node
                                      make: Leaving directory '/home/pi/MagicMirror/modules/MMM-Loxone/node_modules/websocket/build'
                                      > lxcommunicator@1.0.1 postinstall /home/pi/MagicMirror/modules/MMM-Loxone/node_modules/lxcommunicator
                                      > node ./browserify.js
                                      Creating browserified module...
                                      Creating debug module
                                      Creating release module
                                      Saving debug module
                                      Saving release module
                                      LxCommunicator~Browser.js and LxCommunicator~Browser.min.js has been created!
                                      npm WARN grunt-stylelint@0.11.1 requires a peer of stylelint@^10.0.0 but none is installed. You must install peer dep endencies yourself.
                                      npm WARN stylelint-config-standard@19.0.0 requires a peer of stylelint@>=10.1.0 but none is installed. You must insta ll peer dependencies yourself.
                                      npm WARN stylelint-config-recommended@3.0.0 requires a peer of stylelint@>=10.1.0 but none is installed. You must ins tall peer dependencies yourself.
                                      npm WARN optional SKIPPING OPTIONAL DEPENDENCY: fsevents@1.2.9 (node_modules/fsevents):
                                      npm WARN notsup SKIPPING OPTIONAL DEPENDENCY: Unsupported platform for fsevents@1.2.9: wanted {"os":"darwin","arch":" any"} (current: {"os":"linux","arch":"arm"})
                                      added 650 packages from 453 contributors and audited 8175 packages in 323.529s
                                      found 1 moderate severity vulnerability
                                        run `npm audit fix` to fix them, or `npm audit` for details
                                      Then I did a reboot
                                        bobbythemoh
                                        Well there is some weird stuff going on… config file is there…
                                        Guess thats not related to MMM-Loxone… i think ill do a new installation… or do you have a better idea?
                                        0|MagicMir | No helper found for module: clock.
                                        0|MagicMir | WARNING! Could not load config file. Starting with default configuration. Error found: Error: Cannot find module 'node_helper'
                                        0|MagicMir | Loading module helpers ...
                                        0|MagicMir | No helper found for module: alert.
                                        0|MagicMir | App threw an error during load
                                        0|MagicMir | Error: Cannot find module 'node_helper'
                                        0|MagicMir |     at Module._resolveFilename (internal/modules/cjs/loader.js:602:15)
                                        0|MagicMir |     at Function.Module._resolveFilename (/home/pi/MagicMirror/node_modules/electron/dist/resources/electron.asar/common/reset-search-paths.js:35:12)
                                        0|MagicMir |     at Function.Module._load (internal/modules/cjs/loader.js:528:25)
                                        0|MagicMir |     at Module.require (internal/modules/cjs/loader.js:658:17)
                                        0|MagicMir |     at require (internal/modules/cjs/helpers.js:20:18)
                                        0|MagicMir |     at Object.<anonymous> (/home/pi/MagicMirror/modules/MMM-ImagesPhotos/node_helper.js:9:18)
                                        0|MagicMir |     at Object.<anonymous> (/home/pi/MagicMirror/modules/MMM-ImagesPhotos/node_helper.js:82:3)
                                        0|MagicMir |     at Module._compile (internal/modules/cjs/loader.js:711:30)
                                        0|MagicMir |     at Object.Module._extensions..js (internal/modules/cjs/loader.js:722:10)
                                        0|MagicMir |     at Module.load (internal/modules/cjs/loader.js:620:32)
                                        0|MagicMir | Whoops! There was an uncaught exception...
                                        0|MagicMir | { Error: Cannot find module 'node_helper'
                                        0|MagicMir |     at Module.load (internal/modules/cjs/loader.js:620:32) code: 'MODULE_NOT_FOUND' }
                                        idoodlerI S 2 Replies Last reply Reply Quote 0
                                        • idoodlerI Offline
                                          @bobbythemoh Yeah, looks like there are some files missing. I think a new installation is a good idea. You can first check if there are any problems with git status.
                                            sdetweil @bobbythemoh
                                            @bobbythemoh Do
                                            git checkout -- modules/node_modules/node_helper/index.js
                                            • 4 / 5
