    Need help
    6 Posts 3 Posters 1.5k Views 2 Watching
      Calrus
      `/* Magic Mirror Config Sample
      • MIT Licensed.
      • For more information how you can configurate this file
      • See https://github.com/MichMich/MagicMirror#configuration
      var config = {
      // - “”, “0.0.0.0”, “::” to listen on any interface
      // Default, when address config is left out, is “localhost”
      port: 8080,
      ipWhitelist: [“127.0.0.1”, “::ffff:127.0.0.1”, “::1”], // Set [] to allow all IP addresses
      // [“127.0.0.1”, “::ffff:127.0.0.1”, “::1”, “::ffff:192.168.1.5”],
      // [“127.0.0.1”, “::ffff:127.0.0.1”, “::1”, “::ffff:192.168.3.0/28”],
      language: "en",
      timeFormat: 24,
      units: "metric",
      		module: "alert",
      		module: "updatenotification",
      		position: "top_bar"
      		module: "clock",
      		position: "top_left"
      		header: "US Holidays",
      					symbol: "calendar-check",
      					url: "webcal://www.calendarlabs.com/ical-calendar/ics/76/US_Holidays.ics"
      		module: "compliments",
      		position: "lower_third",
      		module: "currentweather",
      			locationID: "5526145",  //ID from http://bulk.openweathermap.org/sample/city.list.json.gz; unzip the gz file and find your city
      			appid: "3007140bdfc742d642dfe84a75fe3032"
      		module: "weatherforecast",
      		header: "Weather Forecast",
      		module: "newsfeed",
      		position: "bottom_bar",
      			feeds: [
      					title: "New York Times",
      			showSourceTitle: true,
      			showPublishDate: true,
      			broadcastNewsFeeds: true,
      			broadcastNewsUpdates: true
      module: “MMM-NowPlayingOnSpotify”,
      position: “bottom_left”,
      showCoverArt: false,
      clientID: “a0f4d0df56b6446ca2be3f81ed7d544f”,
      clientSecret: “9fd7e975f6c64e74a24c8c1e37f53abb”,
      accessToken: “BQAyYFsDVd5q982SILK2l-xeytM49RKC-UrfHUAzt8hgRMhNI9s0WcZ2pVmxNLjODGP82rl1WcKoFZPHiSC9jzcgSbXmxRs9-efUCd8NWdzk_NQWopDe_8IjdSKFwL9hiLh6bWIGt4rdVgZJ6v1CnlifLE-ao3GC”,
      refreshToken: “AQDgYew540LhC4nKUwFcEUaisenwciMBbzagl0Ok-jXJfAlABx3UDgaQMQ4HHh5-FV46pbG-PpHQog4fdIoomzyCYOt220YphZws79yUQfIUdsD1TnKEAxJAC4QzRQA707xWoA”
      ` module: “MMM-AVStock”,
      position: “top_center”,
      apiKey : “LWQTCZMIKEGOSSXJ”,
      timeFormat: “YYYY-MM-DD HH:mm:ss”,
      symbols : [“TSLA”],
      alias: [“TESLA”],
      tickerDuration: 60,
      chartDays: 90,
      poolInterval : 1000*15,
      mode : “series”,
      decimals: 4,
      candleSticks : false,
      coloredCandles : false,
      premiumAccount: false,
      if (typeof module !== “undefined”) {module.exports = config;}
        sdetweil @Calrus
        @Calrus what help?
          Calrus @sdetweil
          @sdetweil The code isn’t running. It says syntax error
            sdetweil @Calrus
            @Calrus ok… from the MagicMirror folder do
            npm run config:check
            start fixing errors in config.js at the top
            rerun after each change…
            i see a quote in front of the module: “avstock” but it may be your cut/paste
              Calrus
              That fixed it! Thanks so much!
                bhepler Module Developer @Calrus
                @Calrus - I’m glad you got it working. In the future, please use the markdown features of the board when posting code.
