    config.js help
    18 Posts 5 Posters 5.1k Views 5 Watching
      dazza120 @DaVinki
      @DaVinki change position to bottom_left And see if that works
        DaVinki @dazza120
        @dazza120 I was just having another look at it, and moved it to top_right, since there are no modules running in that area at the moment. No success.
        I changed all quotation marks from single to double, like ‘top_left’ to “top_right” in the module, position and header lines, no success.
        Running “npm run config:check” gives no errors. Running “rpm start dev” gives no errors. Double checked all { and [ with their corresponding } and ] in a text editor.
        Checked if perhaps the module has any dependencies, which is not the case.
        I have this issue with several modules, no errors, but they just don’t show in MM itself.
        Is there perhaps some sort of logging which I can check?
        I Have never done it before, so I think I can do it.
          dazza120 @DaVinki
          @DaVinki @sdetweil is the man for that he will be along at some point and he’ll have you up and running
            DaVinki @dazza120
            @dazza120 OK, I’ll wait and see what he can come up with. Thanks for your time and quick replies.
            S mumblebajM 2 Replies Last reply Reply Quote 0
              sdetweil @DaVinki
              @DaVinki hm… i installed the module and copied your config and it shows up just below my calendar on the left without any other changes
                DaVinki @sdetweil
                @sdetweil Hi Sam,
                So, I am not going nuts, there is no issue in the code, but somewhere else. Is there any logging I can check?
                • mumblebajM Offline
                  mumblebaj Module Developer @DaVinki
                  @DaVinki If you do a shift + ctrl + i it will open a panel on the right. Scroll up on the Consol and see for any red lines, which would indicate errors. It could also be that there are conflicts with other modules.
                    sdetweil @DaVinki
                    @DaVinki just for testting, can u move the module block to the top of the list in config.js?
                    the modules are placed in order of appearance in the config file…
                    mine is date/time, calendar, then MMM-MyDutchWeather
                    trying to get a pic uploaded…
                    With Weather
                      DaVinki
                      Just had a look at it, but I can’t find anything weird:
                        sdetweil @DaVinki
                        @DaVinki that is the elements tab, select the console tab please
