Show date below time and date info on several lines
Hi!
Just thought I would share how I put the date below the time for the default Clock module using only CSS - no need to modify or create your own clock module!
custom.css
/* CLOCK */ #module_2_clock > div > div { display: flex; flex-direction: column; } /* Date */ #module_2_clock > div > div > div.date { order: 2; } /* Time */ #module_2_clock > div > div > div.time { order: 1; font-family: Roboto, sans-serif; font-weight: 300; font-size: 80px; line-height: 75px; letter-spacing: -3px; color: #fff; }Also, to show the week on a separate line and make it a little bit smaller, use HTML tags within brackets when setting the date format, like this:
config.js
{ module: "clock", position: "top_right", config: { displaySeconds: false, dateFormat: "dddd D MMMM[< br/ >< small >vecka] W[< /small >]", } },NOTE: Since the forum is sanitising HTML, remove all the spaces from the tags above in
< small >,< /small >and< br/ >to make it work.Hope this can inspire and help someone! :)
