Unsolved After 2.8 I'm having tons of issues. What are the steps from square 1 to get this working?
Hi, thank you for your advise.
ls ~/MagicMirror/node_modules/node_helper/
shows me
ls: Zugriff auf ‘/home/pi/MagicMirror/node_modules/node_helper/’ nicht möglich: Datei oder Verzeichnis nicht gefunden
File or folder not foundgit checkout -- node_modules/node_helper/index.js
results in
error: pathspec ‘node_modules/node_helper/index.js’ did not match any file(s) known to git.
@maxheartrate ok. I am away from my system now for a couple days.
Try
git checkout -- node_helper/index.js
If that fails, try
git status
Then rename your MagicMirror folder to something else, clone it again, and copy the node_modules/node_helper folder to your previous installation, and rename the new one, then the old one back
Your two suggestions did not work. That is why I followed step 3: cloning MM again and copying node_helper to node_modules.
I ran npm install in node_modules and in the MagicMirror directory.
Now it looks like I got one error further … :flushed_face:
This is what I get now:
> sh run-start.sh Starting MagicMirror: v2.8.0 Loading config ... Loading module helpers ... WARNING! Could not load config file. Starting with default configuration. Error found: Error: Cannot find module '../../../js/class.js' Loading module helpers ... App threw an error during load Error: Cannot find module '../../../js/class.js' at Module._resolveFilename (internal/modules/cjs/loader.js:602:15) at Function.Module._resolveFilename (/home/pi/MagicMirror/node_modules/electron/dist/resources/electron.asar/common/reset-search-paths.js:35:12) at Function.Module._load (internal/modules/cjs/loader.js:528:25) at Module.require (internal/modules/cjs/loader.js:658:17) at require (internal/modules/cjs/helpers.js:20:18) at Object.<anonymous> (/home/pi/MagicMirror/node_modules/node_helper/index.js:8:13) at Object.<anonymous> (/home/pi/MagicMirror/node_modules/node_helper/index.js:127:3) at Module._compile (internal/modules/cjs/loader.js:711:30) at Object.Module._extensions..js (internal/modules/cjs/loader.js:722:10) at Module.load (internal/modules/cjs/loader.js:620:32) Whoops! There was an uncaught exception... { Error: Cannot find module '../../../js/class.js' at Module._resolveFilename (internal/modules/cjs/loader.js:602:15) at Function.Module._resolveFilename (/home/pi/MagicMirror/node_modules/electron/dist/resources/electron.asar/common/reset-search-paths.js:35:12) at Function.Module._load (internal/modules/cjs/loader.js:528:25) at Module.require (internal/modules/cjs/loader.js:658:17) at require (internal/modules/cjs/helpers.js:20:18) at Object.<anonymous> (/home/pi/MagicMirror/node_modules/node_helper/index.js:8:13) at Object.<anonymous> (/home/pi/MagicMirror/node_modules/node_helper/index.js:127:3) at Module._compile (internal/modules/cjs/loader.js:711:30) at Object.Module._extensions..js (internal/modules/cjs/loader.js:722:10) at Module.load (internal/modules/cjs/loader.js:620:32) code: 'MODULE_NOT_FOUND' } MagicMirror will not quit, but it might be a good idea to check why this happened. Maybe no internet connection? If you think this really is an issue, please open an issue on GitHub: https://github.com/MichMich/MagicMirror/issues Launching application.
@maxheartrate no. No npm install in the node_modules folder. That messes everything up.
Do
cd ~/MagicMirror rm -rf node_modules cp -R -p ???/node_modules ~/MagicMirror
Where ??? Is your recently cloned download.
Then in the MagicMirror folder do
npm install
IF u had other modules installed, beyond the initial set, then look thru their folders and see if there is a package.json file present. If so, in each such module folder do a
npm install
there
I made a new script to do all this upgrade stuff, but I don’t know what will happen if the git pull is already done.
See my upgrade topic in the troubleshooting section -
Hi @sdetweil, thanks for joining in and for your advise.
I followed your steps just as described. The node_helper was the only module in the newly cloned node_modules folder. I then ran npm install and an npm install in every modules folder with a package.json file.
After that I ran into the missing node_helper error again. Obviously the folder was deleted when I ran the npm install in the MagicMirror folder. Now I copied the node_helper folder from the newly cloned version again and I am back at the error I sent in my previous post. :dizzy_face:
No it won’t be deleted.
Let’s start from scratch. U have the extra downloaded copy. Make THAT NAME MagicMirror, and npm install in that folder.
Start mm and we should be running.
Then we will copy over your extra modules, and config file
And work from there -
Alright. Now I have something else but a black screen for the first time in days:
“Magic Mirror - please create a config file”
What do you suggest now?
That’s what I did. I have a fresh MagicMirror now. It is running but can’t find the config file (I haven’t copied config.js.sample to config.js yet). -
@maxheartrate you have to do that, copy the config
