    Issue with Google Map MMM-GoogleMapsTraffic module. Map not loading.
    12 Posts 4 Posters 5.1k Views 4 Watching
      i don’t know how this ever worked… unless a newer version of javascript closed some bug…
      i have a quick fix
      git clone my repo
      git clone https://github.com/sdetweil/MMM-GoogleMapsTraffic.git
      also, at least for the 1st user, there is an invalidkeymap error
      (open developers window, ctrl-shift-i, select the console tab. scroll up for errors)
        Achilles @sdetweil
        @sdetweil Thanks, but that didnt work for me unfortunately…
        To make sure I did it correctly, I navigated to my MMM-GoogleMapsTraffic module, and then executed your git clone, correct?
        I am still getting the same error.
        What I am not understanding at the moment, is all the modules I use that use the Google API are not working now. This is where I am not seeing any solutions anywhere.
        I didnt quite understand your instructions for the first user…maybe that is my issue as well?
        Thanks…
        S 3 Replies Last reply Reply Quote 0
          sdetweil @Achilles
          @Achilles no… rename the old module folder out of the way
          cd ~/MagicMirror/modules
          mv MMM-GoogleMapsTraffic  MMM-GoogleMapsTraffic-save
          git clone https://github.com/sdetweil/MMM-GoogleMapsTraffic.git.
          no other changes are required
            sdetweil @Achilles
            @Achilles said in Issue with Google Map MMM-GoogleMapsTraffic module. Map not loading.:
            there is an error…
            i described how to locate the error yourself
            on the mirror screen , using a keyboard,
            press ctrl-shift-i (all together) to open the developers window
            then select the tab at the top of that window labeled ‘console’,
            then using a mouse or keyboard, scroll the console window up to see previous messages that have scrolled off the screen…
            errors are shown in red text
              sdetweil @Achilles
              maybe there is an account problem where the credit card used for payment is no longer valid?
              i don’t know… all my google api apps are working ok
              A 2 Replies Last reply Reply Quote 0
                Achilles @sdetweil
                @sdetweil Thank you for the timely responses!
                I am working on your replies right now. Thank you very much!
                  Achilles @sdetweil
                  @sdetweil Thanks, it was my API…the free trial had expired with Google Cloud. I fixed that, and everything is working again…
                  Thanks a lot, man!
                    also, i made a mistake yesterday… i fixed the code, but forgot to push it up to my repo…
                    so, if u have my repo in use, just go to the MMM-GoogleMapsTraffic folder and git pull
                    sorry.
                      sdetweil @Achilles
                      @Achilles cool… glad its working
