    Issue with Google Map MMM-GoogleMapsTraffic module. Map not loading.
    12 Posts 4 Posters 4.7k Views 4 Watching
      ramyasadagopan
      I am using the module MMM-GoogleMapsTraffic to show a general traffic in my area (not origin - destination traffic).
      I have 2 issues -
      1. On load the map with traffic shows for a exactly 2 seconds and immediately shows an error ‘Ops something went wrong’
      2. I have a CTA module which works fine on its own. But when the map has an issue, the CTA module also fails for some reason. But this is not a consistent behavior. It also shows just fine even when the map doesn’t load.
      NEED HELP with the map issue first though.
      here is my config (switched 2 letters to protect my API key). I have created 2 different API keys and tried with both.
      		            module: "MMM-GoogleMapsTraffic",
      		            position: "bottom_right",
                                       key:"AIzaSyCeqG6JjCx3zIByDq81hJB9mrzhvK_GgOE",
      					lat: 41.8816281,
      			                lng: -87.6608605,
      			                height: "300px",
      			                width: "300px",
      					mapTypeId: "roadmap",
      			                styledMapType: "transparent",
      			                disableDefaultUI: "true",
      					updateInterval: "60000",
      			                backgroundColor: "hsla(0, 0%, 0%, 0)",
      			                markers: [
      			                        lat: 41.8816281,
      			               		lng: -87.6608605,
      			                        fillColor: "#9966ff"
      Any thoughts?
      Z 1 Reply Last reply Reply Quote 0
      • Z Offline
        Zorganon @ramyasadagopan
        I am having this same issue - did you ever find a resolution to this?
          Achilles
          I am having the same issue as well. Google Maps in general seems to be an issue here with the MagicMirror recently, and there have been no answers…
            i don’t know how this ever worked… unless a newer version of javascript closed some bug…
            i have a quick fix
            git clone my repo
            git clone https://github.com/sdetweil/MMM-GoogleMapsTraffic.git
            also, at least for the 1st user, there is an invalidkeymap error
            (open developers window, ctrl-shift-i, select the console tab. scroll up for errors)
              Achilles @sdetweil
              @sdetweil Thanks, but that didnt work for me unfortunately…
              To make sure I did it correctly, I navigated to my MMM-GoogleMapsTraffic module, and then executed your git clone, correct?
              I am still getting the same error.
              What I am not understanding at the moment, is all the modules I use that use the Google API are not working now. This is where I am not seeing any solutions anywhere.
              I didnt quite understand your instructions for the first user…maybe that is my issue as well?
              Thanks…
              S 3 Replies Last reply Reply Quote 0
                sdetweil @Achilles
                @Achilles no… rename the old module folder out of the way
                cd ~/MagicMirror/modules
                mv MMM-GoogleMapsTraffic  MMM-GoogleMapsTraffic-save
                git clone https://github.com/sdetweil/MMM-GoogleMapsTraffic.git.
                no other changes are required
                  sdetweil @Achilles
                  @Achilles said in Issue with Google Map MMM-GoogleMapsTraffic module. Map not loading.:
                  there is an error…
                  i described how to locate the error yourself
                  on the mirror screen , using a keyboard,
                  press ctrl-shift-i (all together) to open the developers window
                  then select the tab at the top of that window labeled ‘console’,
                  then using a mouse or keyboard, scroll the console window up to see previous messages that have scrolled off the screen…
                  errors are shown in red text
                    sdetweil @Achilles
                    maybe there is an account problem where the credit card used for payment is no longer valid?
                    i don’t know… all my google api apps are working ok
                    A 2 Replies Last reply Reply Quote 0
                      Achilles @sdetweil
                      @sdetweil Thank you for the timely responses!
                      I am working on your replies right now. Thank you very much!
                        Achilles @sdetweil
                        @sdetweil Thanks, it was my API…the free trial had expired with Google Cloud. I fixed that, and everything is working again…
                        Thanks a lot, man!
