    Issue with Google Map MMM-GoogleMapsTraffic module. Map not loading.
    12 Posts 4 Posters 5.2k Views 4 Watching
      Achilles @sdetweil
      @sdetweil Thanks, but that didnt work for me unfortunately…
      To make sure I did it correctly, I navigated to my MMM-GoogleMapsTraffic module, and then executed your git clone, correct?
      I am still getting the same error.
      What I am not understanding at the moment, is all the modules I use that use the Google API are not working now. This is where I am not seeing any solutions anywhere.
      I didnt quite understand your instructions for the first user…maybe that is my issue as well?
      Thanks…
      S 3 Replies Last reply Reply Quote 0
        sdetweil @Achilles
        @Achilles no… rename the old module folder out of the way
        cd ~/MagicMirror/modules
        mv MMM-GoogleMapsTraffic  MMM-GoogleMapsTraffic-save
        git clone https://github.com/sdetweil/MMM-GoogleMapsTraffic.git.
        no other changes are required
          sdetweil @Achilles
          @Achilles said in Issue with Google Map MMM-GoogleMapsTraffic module. Map not loading.:
          there is an error…
          i described how to locate the error yourself
          on the mirror screen , using a keyboard,
          press ctrl-shift-i (all together) to open the developers window
          then select the tab at the top of that window labeled ‘console’,
          then using a mouse or keyboard, scroll the console window up to see previous messages that have scrolled off the screen…
          errors are shown in red text
            sdetweil @Achilles
            maybe there is an account problem where the credit card used for payment is no longer valid?
            i don’t know… all my google api apps are working ok
            A 2 Replies Last reply Reply Quote 0
              Achilles @sdetweil
              @sdetweil Thank you for the timely responses!
              I am working on your replies right now. Thank you very much!
                Achilles @sdetweil
                @sdetweil Thanks, it was my API…the free trial had expired with Google Cloud. I fixed that, and everything is working again…
                Thanks a lot, man!
                  also, i made a mistake yesterday… i fixed the code, but forgot to push it up to my repo…
                  so, if u have my repo in use, just go to the MMM-GoogleMapsTraffic folder and git pull
                  sorry.
                    sdetweil @Achilles
                    @Achilles cool… glad its working
