    Issue with Google Map MMM-GoogleMapsTraffic module. Map not loading.
    12 Posts 4 Posters 5.8k Views 4 Watching
      Achilles
      I am having the same issue as well. Google Maps in general seems to be an issue here with the MagicMirror recently, and there have been no answers…
        i don’t know how this ever worked… unless a newer version of javascript closed some bug…
        i have a quick fix
        git clone my repo
        git clone https://github.com/sdetweil/MMM-GoogleMapsTraffic.git
        also, at least for the 1st user, there is an invalidkeymap error
        (open developers window, ctrl-shift-i, select the console tab. scroll up for errors)
          Achilles @sdetweil
          @sdetweil Thanks, but that didnt work for me unfortunately…
          To make sure I did it correctly, I navigated to my MMM-GoogleMapsTraffic module, and then executed your git clone, correct?
          I am still getting the same error.
          What I am not understanding at the moment, is all the modules I use that use the Google API are not working now. This is where I am not seeing any solutions anywhere.
          I didnt quite understand your instructions for the first user…maybe that is my issue as well?
          Thanks…
          S 3 Replies Last reply Reply Quote 0
            sdetweil @Achilles
            @Achilles no… rename the old module folder out of the way
            cd ~/MagicMirror/modules
            mv MMM-GoogleMapsTraffic  MMM-GoogleMapsTraffic-save
            git clone https://github.com/sdetweil/MMM-GoogleMapsTraffic.git.
            no other changes are required
              sdetweil @Achilles
              @Achilles said in Issue with Google Map MMM-GoogleMapsTraffic module. Map not loading.:
              there is an error…
              i described how to locate the error yourself
              on the mirror screen , using a keyboard,
              press ctrl-shift-i (all together) to open the developers window
              then select the tab at the top of that window labeled ‘console’,
              then using a mouse or keyboard, scroll the console window up to see previous messages that have scrolled off the screen…
              errors are shown in red text
                sdetweil @Achilles
                maybe there is an account problem where the credit card used for payment is no longer valid?
                i don’t know… all my google api apps are working ok
                A 2 Replies Last reply Reply Quote 0
                  Achilles @sdetweil
                  @sdetweil Thank you for the timely responses!
                  I am working on your replies right now. Thank you very much!
                    Achilles @sdetweil
                    @sdetweil Thanks, it was my API…the free trial had expired with Google Cloud. I fixed that, and everything is working again…
                    Thanks a lot, man!
                      also, i made a mistake yesterday… i fixed the code, but forgot to push it up to my repo…
                      so, if u have my repo in use, just go to the MMM-GoogleMapsTraffic folder and git pull
                      sorry.
                        sdetweil @Achilles
                        @Achilles cool… glad its working
