    The latest Install Guide (MM w/ Google Assistant)
    63 Posts 25 Posters 74.6k Views 28 Watching
      bachoo786 @leej00
      @leej00 hello mate
      how did you configure the last part i.e.
      STEP7. EDIT GOOGLE ASSISTANT MODULE CONFIG
      Open the Magic Mirror configuration file with TextEditor and modify it with the contents of github
      there is soo much information on github that needs to be added on to the config.js, which part of it did you add to your config.js? can you please share it?
      I get the google icon on my mm but when I say “Ok Google” nothing happens"
      Thanks.
      • N Offline
        numb3rs
        A few things you can do:
        Add your location inside the config.js under the module call. You can find this info inside the CONFIGURATION.md
        i.e.
        // — ESSENTIALS / modifying for your environment might be needed.
        Use: https://www.mapdevelopers.com/geocode_tool.php
        deviceLocation: {
          coordinates: { // set the latitude and longitude of the device to get localized information like weather or time. (ref. mygeoposition.com)
            latitude: 00.0, // -90.0 - +90.0
            longitude: -00.00, // -180.0 - +180.0
        With MMM-Hotword, using USB mic (plughw:1) you need to use the following:
        //Hotword Module
            module: "MMM-Hotword",
              record: {
                recordProgram : "arecord",
                device        : "plughw:1",
              autostart:true,
              onDetected: {
                notification: function (payload) {
                  return "ASSISTANT_ACTIVATE"
                payload: function (payload){
                  return {
                    profile: payload.hotword
        		module: "MMM-AssistantMk2",
        		position: "bottom_bar",
        		record: {
              notifications: {
                ASSISTANT_ACTIVATED: "HOTWORD_PAUSE",
                ASSISTANT_DEACTIVATED: "HOTWORD_RESUME",
        deviceLocation: {
                latitude: 00.00, // -90.0 - +90.0
        It works. Thank You! I am using the PS Eye as suggested in other forms. My audio out is still set to HDMI because im staging on my TV.
        LPT: Add the following to the MK2 module config so the screens dont toggle so fast:
        screenDuration: 5000, //this is milliseconds
        • N Offline
          numb3rs @leej00
          @leej00
          Testing this now to see if I get the same results.
          @makepluscode
          Can confirm all modules disappear besides the default weather module.
          I have a YouTube playlist playing, and I can still hear the module playing through the speakers, but visually it is no longer there.
          If I give it a keyword voice command it is listening for it will draw the modules again.
          Another observation is every time I give it a voice command it starts my playlist from the top.
          • N Offline
            numb3rs
            @bachoo786 say “smart mirror” or “snowboy”
            You can also read more on the .umdl and how to obtain a custom .umdl here:
            snowboy.kitt.ai
            More particularly:
            http://docs.kitt.ai/snowboy/#api-v1-train
              Jmh474
              • F Offline
                Fabian @makepluscode
                @makepluscode
                Hello first of all thanks for the great tutorial!
                Unfortunately I’m stuck with the last step (installation of the microphone)
                When I enter the command “vi ~/.asoundrc” I get the following message:
                I ask for help
                Greeting Fabian
                  Sahil @Fabian
                  @Fabian
                  Type sudo nano. asoundrc in command prompt
                  Then paste your code there.
                  To save that code press ctrl+X, then Y and then enter.
                  You are good to go
                  1 Reply Last reply Reply Quote -1
                    dxfan227
                    So In Your Opinion is MMM Hotword and MMM-assistankmk2 the best combo for google assistant?
                    I see a few other modules like MMM-GoogleAssistant out there too
                      siddhartha
                      pcm.!default {
                      type asym
                      capture.pcm “mic”
                      playback.pcm “speaker”
                      pcm.mic {
                      type plug
                      slave {
                      pcm “hw:1,0”
                      pcm.speaker {
                      type plug
                      slave {
                      pcm “hw:0,1”
                      This is my asoundrc conf but i want to change conf like this
                      defaults.pcm.!card
                      defaults.ctl.!card
                      screencast and google assistant both want diffrent asoundrc so any suggetions ??
                      Thank you.
                      i am noob at this so sorry in advance for dumb question…
                      Thank you for your reply 🙂
                      • O Offline
                        otto
                        • O Offline
                          otto @makepluscode
                          @makepluscode
                          https://pastebin.com/cBFMG7ak
                          i got this… what sholde i do?
                          • H Offline
                            harrycool25
                            An amazing guide! Thanks a lot. Got the mirror and the google assistant module up an running well, with a few issues that I will address here.
                            So, overall, everything is VERRY LAGGY- from audio, video, animation and update rate. I was told to downgrade MM from 2.9.0 down to 2.1.0, but have no idea how. Any help please. And the google assistant, when asked about some specific things like direction or information on the web, it just shows the URL for like a split second, then stop. Anyway I can display this on my phone, like idk connect the module to my phone in any way?
                            Please help. I’ve been struggling with this for 4 weeks already and it’s starting to br a major annoyance :(
                              Ayos53
                              Excuse me but i have a problem in your tutoriel : step 5 point 1.
                              when you ask to go :
                              cd ~/MagicMirror/modules/MMM-Hotword/node_modules/snowboy
                              I havent folder node module. When i “npm install” in MMM-hotword i have :
                              npm notice created a lockfile as package-lock.json. You should commit this file.
                              npm WARN MMM-Hotword@2.0.1 No repository field.
                                sdetweil @Ayos53
                                @Ayos53 said in The latest Install Guide (MM w/ Google Assistant):
                                its node_modules (note the trailing s)…
                                it will be there if you ran npm install in the MMM-Hotword folder as required by the install instructions (the install.sh script does this)
                                  Ayos53
                                  Sorry it’s me again.
                                  I have a problem when i launch magicmiror, he crashed.
                                  The log file :
                                  1 warn npm npm does not support Node.js v10.15.2
                                  2 warn npm You should probably upgrade to a newer version of node as we
                                  3 warn npm can't make any promises that npm will work with this version.
                                  4 warn npm Supported releases of Node.js are the latest release of 4, 6, 7, 8, 9.
                                  5 warn npm You can find the latest version at https://nodejs.org/
                                  6 verbose cli [ '/usr/bin/node', '/usr/bin/npm', 'start' ]
                                  7 info using npm@5.8.0
                                  8 info using node@v10.15.2
                                  9 verbose run-script [ 'prestart', 'start', 'poststart' ]
                                  10 info lifecycle magicmirror@2.9.0~prestart: magicmirror@2.9.0
                                  11 info lifecycle magicmirror@2.9.0~start: magicmirror@2.9.0
                                  12 verbose lifecycle magicmirror@2.9.0~start: unsafe-perm in lifecycle true
                                  13 verbose lifecycle magicmirror@2.9.0~start: PATH: /usr/share/npm/node_modules/npm-lifecycle/node-gyp-bin:/home/pi/MagicMirror/node_modules/.bin:/usr/local/sbin:/usr/local/bin:/usr/sbin:/usr/bin:/sbin:/bin:/usr/local/games:/usr/games
                                  14 verbose lifecycle magicmirror@2.9.0~start: CWD: /home/pi/MagicMirror
                                  15 silly lifecycle magicmirror@2.9.0~start: Args: [ '-c', 'sh run-start.sh' ]
                                  16 info lifecycle magicmirror@2.9.0~start: Failed to exec start script
                                  17 verbose stack Error: magicmirror@2.9.0 start: `sh run-start.sh`
                                  17 verbose stack spawn ENOENT
                                  17 verbose stack     at ChildProcess.<anonymous> (/usr/share/npm/node_modules/npm-lifecycle/lib/spawn.js:48:18)
                                  17 verbose stack     at ChildProcess.emit (events.js:189:13)
                                  17 verbose stack     at maybeClose (internal/child_process.js:970:16)
                                  17 verbose stack     at Process.ChildProcess._handle.onexit (internal/child_process.js:259:5)
                                  18 verbose pkgid magicmirror@2.9.0
                                  19 verbose cwd /home/pi/MagicMirror
                                  20 verbose Linux 4.19.75-v7l+
                                  21 verbose argv "/usr/bin/node" "/usr/bin/npm" "start"
                                  22 verbose node v10.15.2
                                  23 verbose npm  v5.8.0
                                  24 error file sh
                                  25 error code ELIFECYCLE
                                  26 error errno ENOENT
                                  27 error syscall spawn
                                  28 error magicmirror@2.9.0 start: `sh run-start.sh`
                                  28 error spawn ENOENT
                                  29 error Failed at the magicmirror@2.9.0 start script.
                                  29 error This is probably not a problem with npm. There is likely additional logging output above.
                                  30 verbose exit [ 1, true ]
                                  If someone have an idea ?
                                    sdetweil @Ayos53
                                    seems a file is missing, please do
                                    ls /home/pi/MagicMirror/run-start.sh
                                    you should see this result
                                    pi@raspberrypi:~ $ ls /home/pi/MagicMirror/run-start.sh
                                    it is part of the git clone distribution and never changed
                                      Ayos53 @sdetweil
                                      i do
                                      and yes i have this result
                                      but always crash after 1 seconde
                                      i see this :
                                      > magicmirror@2.9.0 start /home/pi/MagicMirror
                                      > sh run-start.sh
                                      Starting MagicMirror: v2.9.0
                                      Loading config ...
                                      Loading module helpers ...
                                      Module helper loaded: MMM-NetworkConnection
                                      Module helper loaded: MMM-Hotword
                                      Module helper loaded: MMM-AssistantMk2
                                      All module helpers loaded.
                                      Server started ...
                                      Starting module: newsfeed
                                      Connecting socket for: MMM-NetworkConnection
                                      MMM-NetworkConnection helper started ...
                                      Connecting socket for: MMM-Hotword
                                      [HOTWORD] MMM-Hotword starts
                                      Connecting socket for: MMM-AssistantMk2
                                      Launching application.
                                      Create new news fetcher for url: https://www.francetvinfo.fr/titres.rss - Interval: 300000
                                      [AMK2] Recipe is loaded: hide_and_show_all_modules.js
                                      [AMK2] Recipe is loaded: reboot.js
                                      [AMK2] Recipe is loaded: screen_onoff.js
                                      [AMK2] Recipe is loaded: shutdown.js
                                      [HOTWORD] No model to load
                                      [AMK2] Temporal storage directory is clearing.
                                      [AMK2] assistant ready
                                      /home/pi/MagicMirror/node_modules/electron/dist/electron js/electron.js: symbol lookup error: /home/pi/MagicMirror/modules/MMM-AssistantMk2/node_modules/grpc/src/node/extension_binary/electron-v3.0-linux-arm-glibc/grpc_node.node: undefined symbol: __atomic_store_8
                                      npm ERR! file sh
                                      npm ERR! code ELIFECYCLE
                                      npm ERR! errno ENOENT
                                      npm ERR! syscall spawn
                                      npm ERR! magicmirror@2.9.0 start: `sh run-start.sh`
                                      npm ERR! spawn ENOENT
                                      npm ERR!
                                      npm ERR! Failed at the magicmirror@2.9.0 start script.
                                      npm ERR!     /home/pi/.npm/_logs/2019-12-04T14_51_36_364Z-debug.log
                                        sdetweil @Ayos53
                                        that is the error
                                        this is a known problem, one of the services the module depends on has a bug,
                                        @Sean will need to give the answer, as I don’t see a specific set of steps to resolve it
                                        the ‘fix’ is to downgrade the grpc module to version 1.23 (from 1.24 u are on now)
                                          Ayos53 @sdetweil
                                          ok no problem but, i don’t know how do this
                                          S ? 2 Replies Last reply Reply Quote 0
                                            sdetweil @Ayos53
                                            @Ayos53 me either… there are a number of steps, but I don’t know them all
                                            thats why we need @Sean help
                                            • 1 / 4
