    Need help please MMM-dropbox error
    15 Posts 3 Posters 4.7k Views 3 Watching
      sdetweil @Stoffbeuteluwe
      @Stoffbeuteluwe said in Need help please MMM-dropbox error:
      it is locked at every start off MM
      what does that mean?
      mumblebajM StoffbeuteluweS 2 Replies Last reply Reply Quote 0
      • StoffbeuteluweS
        Stoffbeuteluwe Project Sponsor @sdetweil
        https://github.com/michael5r/mmm-dropbox
        • mumblebajM
          @sdetweil I love this. Gone from MMM-dropbox to weather module…:grinning_face: :smiling_face_with_open_mouth: :smiling_face_with_open_mouth_smiling_eyes:
          • StoffbeuteluweS
            @sdetweil it is a lock on Remote Control it say a other module have locked the current weather module
            i must open the lock then it works
            • StoffbeuteluweS
              Stoffbeuteluwe Project Sponsor @mumblebaj
              @mumblebaj 😀
              • StoffbeuteluweS
                Stoffbeuteluwe Project Sponsor @Stoffbeuteluwe
                @Stoffbeuteluwe ok at first we can try to handle the Dropbox problem
                  no idea, never seen this
                    he has a bad design,
                    he starts a timer, with a 0 delay
                    initialLoadDelay int 0 How long to delay the initial load (in ms)
                    and so it calls to get data BEFORE it initializes the node helper…
                    in your config.js config {} section for this module add
                      initialLoadDelay: 5000,
                    and it says if the token is not specified, present and error message,
                         if (this.config.token === '') {
                                    this.errMsg = 'Please add your Dropbox token to the MagicMirror config.js file.';
                    but it still calls the node helper to get data, which then crashes with the error u see
                    • StoffbeuteluweS
                      @sdetweil sometimes it works but not very often
                      • StoffbeuteluweS
                        @sdetweil I will try a new token…thanks Sam
