Need help please MMM-dropbox error
@Stoffbeuteluwe that usually means the code did not handle an error return from the api it called.
@sdetweil that means it depends on the api?
@Stoffbeuteluwe which mmm-dropbox is this?
@sdetweil hey Sam can you help me with my current weather module …it is locked at every start off MM and I don’t know why:thinking_face:
@Stoffbeuteluwe said in Need help please MMM-dropbox error:
what does that mean?
@sdetweil I love this. Gone from MMM-dropbox to weather module…:grinning_face: :smiling_face_with_open_mouth: :smiling_face_with_open_mouth_smiling_eyes:
@sdetweil it is a lock on Remote Control it say a other module have locked the current weather module
i must open the lock then it works -
@Stoffbeuteluwe ok at first we can try to handle the Dropbox problem
no idea, never seen this
he has a bad design,
he starts a timer, with a 0 delay
initialLoadDelay int 0 How long to delay the initial load (in ms)and so it calls to get data BEFORE it initializes the node helper…
in your config.js config {} section for this module add
initialLoadDelay: 5000,and it says if the token is not specified, present and error message,
if (this.config.token === '') { this.errMsg = 'Please add your Dropbox token to the MagicMirror config.js file.';but it still calls the node helper to get data, which then crashes with the error u see
@sdetweil sometimes it works but not very often
@sdetweil I will try a new token…thanks Sam
