    Need help please MMM-dropbox error
    15 Posts 3 Posters 4.5k Views 3 Watching
      sdetweil @Stoffbeuteluwe
      @Stoffbeuteluwe which mmm-dropbox is this?
      • StoffbeuteluweS Offline
        Stoffbeuteluwe Project Sponsor @sdetweil
        @sdetweil hey Sam can you help me with my current weather module …it is locked at every start off MM and I don’t know why:thinking_face:
          @Stoffbeuteluwe said in Need help please MMM-dropbox error:
          what does that mean?
          mumblebajM StoffbeuteluweS 2 Replies Last reply Reply Quote 0
            https://github.com/michael5r/mmm-dropbox
            • mumblebajM Offline
              @sdetweil I love this. Gone from MMM-dropbox to weather module…:grinning_face: :smiling_face_with_open_mouth: :smiling_face_with_open_mouth_smiling_eyes:
                @sdetweil it is a lock on Remote Control it say a other module have locked the current weather module
                i must open the lock then it works
                  Stoffbeuteluwe Project Sponsor @mumblebaj
                  @mumblebaj 😀
                    Stoffbeuteluwe Project Sponsor @Stoffbeuteluwe
                    @Stoffbeuteluwe ok at first we can try to handle the Dropbox problem
                      no idea, never seen this
                        he has a bad design,
                        he starts a timer, with a 0 delay
                        initialLoadDelay int 0 How long to delay the initial load (in ms)
                        and so it calls to get data BEFORE it initializes the node helper…
                        in your config.js config {} section for this module add
                          initialLoadDelay: 5000,
                        and it says if the token is not specified, present and error message,
                             if (this.config.token === '') {
                                        this.errMsg = 'Please add your Dropbox token to the MagicMirror config.js file.';
                        but it still calls the node helper to get data, which then crashes with the error u see
                          @sdetweil sometimes it works but not very often
                            @sdetweil I will try a new token…thanks Sam
