    MMM-Assistantmk2 and MMM-Hotword not picking up
    54 Posts 9 Posters 42.9k Views 9 Watching
    • ejay-ibmE
      ejay-ibm Project Sponsor Module Developer @bachoo786
      @bachoo786
      The notification allows to the hotword module to receive instruction from the assistant module by notification to pause or resume itself in the right time.
      When assistant 'talk it pause the hotword detection
      ASSISTANT_ACTIVATED: “HOTWORD_PAUSE”,
      When the assistant is done it restart the hotword detection .
      ASSISTANT_DEACTIVATED: “HOTWORD_RESUME”,
      Ejay
      • A
        AdnanAhmed97
        The hotword module should be called outside the assistant module
        Add the brackets correctly and change and change device to plughw : 1;
          bachoo786 @AdnanAhmed97
          @AdnanAhmed97 what do you mean?
            jmartin1009
            @sdetweil @ejay-ibm well i got a new mic and i tried it out, still no detection for MMM-Hotword. It works for GoogleAssistantMk2 when i click the button on the screen, but no hotword detection. I worried that it may be because of snowboy failing to install properly the first time for some reason, so i went into the module in the console and did npm install and got this:
            pi@raspberrypi:~/MagicMirror/modules/MMM-Hotword $ npm install
            npm WARN deprecated hoek@2.16.3: This version is no longer maintained. Please upgrade to the latest version.
            npm WARN deprecated boom@2.10.1: This version is no longer maintained. Please upgrade to the latest version.
            npm WARN deprecated cryptiles@2.0.5: This version is no longer maintained. Please upgrade to the latest version.
            npm ERR! path /home/pi/MagicMirror/modules/MMM-Hotword/node_modules/snowboy
            npm ERR! code EISGIT
            npm ERR! git /home/pi/MagicMirror/modules/MMM-Hotword/node_modules/snowboy: Appears to be a git repo or submodule.
            npm ERR! git Refusing to remove it. Update manually,
            npm ERR! git or move it out of the way first.
            npm ERR!     /home/pi/.npm/_logs/2019-03-18T22_16_00_319Z-debug.log
            any idea how i can fix this?
            J ? 2 Replies Last reply Reply Quote 0
              jmartin1009 @jmartin1009
              @jmartin1009 this is possible it’s saying this because it’s already there, but i wasn’t sure i figured i’d give it another go. Let me know if there’s anything i should change or try, but i know this mic does work, as it shows up in
              arecord -l
              and it comes up and i can select it in alsamixer and everything, just can’t get hotword to hear me.
                A Former User @jmartin1009
                @jmartin1009
                rm -rf /home/pi/MagicMirror/modules/MMM-Hotword/node_modules/snowboy/.git
                Then try again
                  raedonlpa
                  Hi, why?
                  When I change the activation word, it doesn’t work for me?,
                  I want to change it to another word, like alexa, jarvis, etc, and it doesn’t work for me.
                  I have copied the parameters of @ejay-ibm and nothing.
                  language: "es",
                  timeFormat: 24,
                  units: "metric",
                  		module: "alert",
                  		module: "updatenotification",
                  		position: "top_bar"
                  		module: "clock",
                  		position: "top_left"
                  		header: "Calendario",
                  					symbol: "calendar-check",
                  					url: "https://www.calendarlabs.com/ical-calendar/ics/70/Spain_Holidays.ics"
                  					symbol: "MyCalendar",
                  					url: "https://calendar.google.com/calendar/ical/............/public/basic.ics"
                  		module: "compliments",
                  		position: "lower_third"
                  		module: "currentweather",
                  			locationID: "",  //ID from http://bulk.openweathermap.org/sample/city.list.json.gz; unzip the gz file and find your city
                  		module: "weatherforecast",
                  		header: "Weather Forecast",
                  			locationID: "2521570",  //ID from http://bulk.openweathermap.org/sample/city.list.json.gz; unzip the gz file and find your city
                  			appid: "..........................."
                      		module: 'currentweather',
                      		position: 'top_right',
                  		        locationID: '2521570', //ID from bulk.openweather.org/sample/
                  		        appid:" .............................'',
                  		        updateInterval: '3600000',
                  		        onlyTemp: true
                  		module: "newsfeed",
                  		position: "bottom_bar",
                  			feeds: [
                  					title: "Canarias7",
                  					url: "https://www.canarias7.es/rss/portada.xml"
                  			showSourceTitle: true,
                  			showPublishDate: true,
                  			broadcastNewsFeeds: true,
                  			broadcastNewsUpdates: true
                  		module: "MMM-Hotword",
                  			chimeOnFinish: null,
                  			mic: {
                  				recordProgram: "arecord",
                  				device: "plughw:1"
                  			models: [
                  					hotwords    : "Smart_mirror",
                  					file        : "smart_mirror.umdl",
                  					sensitivity : "0.5",
                  			commands: {
                  				"smart_mirror": {
                  					notificationExec: {
                  						notification: "ASSISTANT_ACTIVATE",
                  						payload: (detected, afterRecord) => {
                  							return {profile:"default"}
                  					restart:false,
                  					afterRecordLimit:0
                  		module: "MMM-AssistantMk2",
                  			deviceLocation: {
                  				coordinates: {
                  					latitude: 28.969593, // -90.0 - +90.0
                  					longitude: -13.556344, // -180.0 - +180.0
                  			record: {
                  				recordProgram : "arecord",
                  				device        : "plughw:1",
                  			notifications: {
                  				ASSISTANT_ACTIVATED: "HOTWORD_PAUSE",
                  				ASSISTANT_DEACTIVATED: "HOTWORD_RESUME",
                  			useWelcomeMessage: "brief today",
                  			profiles: {
                  				"default" : {
                  					lang: "es-ES"
                    sdetweil @raedonlpa
                    @raedonlpa can u edit your post, and put three back-tics (shifted, left of 1) before the 1st line, and after the last line.
                    1 Reply Last reply Reply Quote -1
                      raedonlpa
                      @sdetweil Better this way, I’m sorry I use google traslator
                        sdetweil @raedonlpa
                        @raedonlpa yes, much better… thank you … you missed one close brace }; at the end, inside the backtics
                          raedonlpa
                          @sdetweil I know, don’t let me put it in the forum
                            sdetweil @raedonlpa
                            @raedonlpa it was only on the edit of the forum post…
                              raedonlpa
                              @sdetweil said in MMM-Assistantmk2 and MMM-Hotword not picking up:
                              Do you mean the end of everything?
                                sdetweil @raedonlpa
                                @raedonlpa
                                this
                                is hanging out after the closing backtics… in your edited post
                                  raedonlpa
                                  yes, I get spawn error
                                    sdetweil @raedonlpa
                                    @raedonlpa sorry, spawn error??
                                    I was just trying to clean up the forum messages so that others with knowledge about the two modules can help you…
                                    it was very hard to read the config.js info in the original posting.
                                    the changes I mentioned should NOT be put into the actual config.js file.
                                      raedonlpa
                                      S J 2 Replies Last reply Reply Quote 0
                                        sdetweil @raedonlpa
                                        @raedonlpa weird
                                          juantata @raedonlpa
                                          @raedonlpa Hi. Did you solve the activation word?
                                          S R 2 Replies Last reply Reply Quote 0
                                            sdetweil @juantata
                                            @juantata see the documentation on model usage
                                            using one of the predefined models.
                                            https://github.com/eouia/MMM-Hotword/blob/master/documents/models.md
                                            some spoken word dialects do not work with universal models. Most users from India will have to make their own model. see below
                                            training your own voice model
                                            https://github.com/eouia/MMM-Hotword/blob/master/documents/trainer.md
                                            • 3 / 3
