    MMM-Assistantmk2 and MMM-Hotword not picking up
    54 Posts 9 Posters 43.0k Views 9 Watching
      jmartin1009 @jmartin1009
      @jmartin1009 this is possible it’s saying this because it’s already there, but i wasn’t sure i figured i’d give it another go. Let me know if there’s anything i should change or try, but i know this mic does work, as it shows up in
      arecord -l
      and it comes up and i can select it in alsamixer and everything, just can’t get hotword to hear me.
        A Former User @jmartin1009
        @jmartin1009
        rm -rf /home/pi/MagicMirror/modules/MMM-Hotword/node_modules/snowboy/.git
        Then try again
          raedonlpa
          Hi, why?
          When I change the activation word, it doesn’t work for me?,
          I want to change it to another word, like alexa, jarvis, etc, and it doesn’t work for me.
          I have copied the parameters of @ejay-ibm and nothing.
          language: "es",
          timeFormat: 24,
          units: "metric",
          		module: "alert",
          		module: "updatenotification",
          		position: "top_bar"
          		module: "clock",
          		position: "top_left"
          		header: "Calendario",
          					symbol: "calendar-check",
          					url: "https://www.calendarlabs.com/ical-calendar/ics/70/Spain_Holidays.ics"
          					symbol: "MyCalendar",
          					url: "https://calendar.google.com/calendar/ical/............/public/basic.ics"
          		module: "compliments",
          		position: "lower_third"
          		module: "currentweather",
          			locationID: "",  //ID from http://bulk.openweathermap.org/sample/city.list.json.gz; unzip the gz file and find your city
          		module: "weatherforecast",
          		header: "Weather Forecast",
          			locationID: "2521570",  //ID from http://bulk.openweathermap.org/sample/city.list.json.gz; unzip the gz file and find your city
          			appid: "..........................."
              		module: 'currentweather',
              		position: 'top_right',
          		        locationID: '2521570', //ID from bulk.openweather.org/sample/
          		        appid:" .............................'',
          		        updateInterval: '3600000',
          		        onlyTemp: true
          		module: "newsfeed",
          		position: "bottom_bar",
          			feeds: [
          					title: "Canarias7",
          					url: "https://www.canarias7.es/rss/portada.xml"
          			showSourceTitle: true,
          			showPublishDate: true,
          			broadcastNewsFeeds: true,
          			broadcastNewsUpdates: true
          		module: "MMM-Hotword",
          			chimeOnFinish: null,
          			mic: {
          				recordProgram: "arecord",
          				device: "plughw:1"
          			models: [
          					hotwords    : "Smart_mirror",
          					file        : "smart_mirror.umdl",
          					sensitivity : "0.5",
          			commands: {
          				"smart_mirror": {
          					notificationExec: {
          						notification: "ASSISTANT_ACTIVATE",
          						payload: (detected, afterRecord) => {
          							return {profile:"default"}
          					restart:false,
          					afterRecordLimit:0
          		module: "MMM-AssistantMk2",
          			deviceLocation: {
          				coordinates: {
          					latitude: 28.969593, // -90.0 - +90.0
          					longitude: -13.556344, // -180.0 - +180.0
          			record: {
          				recordProgram : "arecord",
          				device        : "plughw:1",
          			notifications: {
          				ASSISTANT_ACTIVATED: "HOTWORD_PAUSE",
          				ASSISTANT_DEACTIVATED: "HOTWORD_RESUME",
          			useWelcomeMessage: "brief today",
          			profiles: {
          				"default" : {
          					lang: "es-ES"
            sdetweil @raedonlpa
            @raedonlpa can u edit your post, and put three back-tics (shifted, left of 1) before the 1st line, and after the last line.
            Reply Quote -1
              raedonlpa
              @sdetweil Better this way, I’m sorry I use google traslator
                sdetweil @raedonlpa
                @raedonlpa yes, much better… thank you … you missed one close brace }; at the end, inside the backtics
                  raedonlpa
                  @sdetweil I know, don’t let me put it in the forum
                    sdetweil @raedonlpa
                    @raedonlpa it was only on the edit of the forum post…
                      raedonlpa
                      @sdetweil said in MMM-Assistantmk2 and MMM-Hotword not picking up:
                      Do you mean the end of everything?
                        sdetweil @raedonlpa
                        @raedonlpa
                        this
                        is hanging out after the closing backtics… in your edited post
                          raedonlpa
                          yes, I get spawn error
                            sdetweil @raedonlpa
                            @raedonlpa sorry, spawn error??
                            I was just trying to clean up the forum messages so that others with knowledge about the two modules can help you…
                            it was very hard to read the config.js info in the original posting.
                            the changes I mentioned should NOT be put into the actual config.js file.
                              raedonlpa
                              S J 2 Replies Last reply
                                sdetweil @raedonlpa
                                @raedonlpa weird
                                  juantata @raedonlpa
                                  @raedonlpa Hi. Did you solve the activation word?
                                  S R 2 Replies Last reply
                                    sdetweil @juantata
                                    @juantata see the documentation on model usage
                                    using one of the predefined models.
                                    https://github.com/eouia/MMM-Hotword/blob/master/documents/models.md
                                    some spoken word dialects do not work with universal models. Most users from India will have to make their own model. see below
                                    training your own voice model
                                    https://github.com/eouia/MMM-Hotword/blob/master/documents/trainer.md
                                    J 1 Reply Last reply
                                      raedonlpa @juantata
                                      @juantata yes, my mistake was that the .wav file was very large.
                                        juantata @raedonlpa
                                        @raedonlpa Sorry for the inconvenience. Could you tell me how you have done all the steps?
                                          juantata @sdetweil
                                          @sdetweil Thanks for the reply. Already solved
                                          • 3 / 3
