    MMM-Assistantmk2 and MMM-Hotword not picking up
    54 Posts 9 Posters 43.6k Views 9 Watching
    • A
      AdnanAhmed97
      The hotword module should be called outside the assistant module
      Add the brackets correctly and change and change device to plughw : 1;
      B 1 Reply Last reply
        bachoo786 @AdnanAhmed97
        @AdnanAhmed97 what do you mean?
          jmartin1009
          @sdetweil @ejay-ibm well i got a new mic and i tried it out, still no detection for MMM-Hotword. It works for GoogleAssistantMk2 when i click the button on the screen, but no hotword detection. I worried that it may be because of snowboy failing to install properly the first time for some reason, so i went into the module in the console and did npm install and got this:
          pi@raspberrypi:~/MagicMirror/modules/MMM-Hotword $ npm install
          npm WARN deprecated hoek@2.16.3: This version is no longer maintained. Please upgrade to the latest version.
          npm WARN deprecated boom@2.10.1: This version is no longer maintained. Please upgrade to the latest version.
          npm WARN deprecated cryptiles@2.0.5: This version is no longer maintained. Please upgrade to the latest version.
          npm ERR! path /home/pi/MagicMirror/modules/MMM-Hotword/node_modules/snowboy
          npm ERR! code EISGIT
          npm ERR! git /home/pi/MagicMirror/modules/MMM-Hotword/node_modules/snowboy: Appears to be a git repo or submodule.
          npm ERR! git Refusing to remove it. Update manually,
          npm ERR! git or move it out of the way first.
          npm ERR!     /home/pi/.npm/_logs/2019-03-18T22_16_00_319Z-debug.log
          any idea how i can fix this?
          J ? 2 Replies Last reply
            jmartin1009 @jmartin1009
            @jmartin1009 this is possible it’s saying this because it’s already there, but i wasn’t sure i figured i’d give it another go. Let me know if there’s anything i should change or try, but i know this mic does work, as it shows up in
            arecord -l
            and it comes up and i can select it in alsamixer and everything, just can’t get hotword to hear me.
              A Former User @jmartin1009
              @jmartin1009
              rm -rf /home/pi/MagicMirror/modules/MMM-Hotword/node_modules/snowboy/.git
              Then try again
                raedonlpa
                Hi, why?
                When I change the activation word, it doesn’t work for me?,
                I want to change it to another word, like alexa, jarvis, etc, and it doesn’t work for me.
                I have copied the parameters of @ejay-ibm and nothing.
                language: "es",
                timeFormat: 24,
                units: "metric",
                		module: "alert",
                		module: "updatenotification",
                		position: "top_bar"
                		module: "clock",
                		position: "top_left"
                		header: "Calendario",
                					symbol: "calendar-check",
                					url: "https://www.calendarlabs.com/ical-calendar/ics/70/Spain_Holidays.ics"
                					symbol: "MyCalendar",
                					url: "https://calendar.google.com/calendar/ical/............/public/basic.ics"
                		module: "compliments",
                		position: "lower_third"
                		module: "currentweather",
                			locationID: "",  //ID from http://bulk.openweathermap.org/sample/city.list.json.gz; unzip the gz file and find your city
                		module: "weatherforecast",
                		header: "Weather Forecast",
                			locationID: "2521570",  //ID from http://bulk.openweathermap.org/sample/city.list.json.gz; unzip the gz file and find your city
                			appid: "..........................."
                    		module: 'currentweather',
                    		position: 'top_right',
                		        locationID: '2521570', //ID from bulk.openweather.org/sample/
                		        appid:" .............................'',
                		        updateInterval: '3600000',
                		        onlyTemp: true
                		module: "newsfeed",
                		position: "bottom_bar",
                			feeds: [
                					title: "Canarias7",
                					url: "https://www.canarias7.es/rss/portada.xml"
                			showSourceTitle: true,
                			showPublishDate: true,
                			broadcastNewsFeeds: true,
                			broadcastNewsUpdates: true
                		module: "MMM-Hotword",
                			chimeOnFinish: null,
                			mic: {
                				recordProgram: "arecord",
                				device: "plughw:1"
                			models: [
                					hotwords    : "Smart_mirror",
                					file        : "smart_mirror.umdl",
                					sensitivity : "0.5",
                			commands: {
                				"smart_mirror": {
                					notificationExec: {
                						notification: "ASSISTANT_ACTIVATE",
                						payload: (detected, afterRecord) => {
                							return {profile:"default"}
                					restart:false,
                					afterRecordLimit:0
                		module: "MMM-AssistantMk2",
                			deviceLocation: {
                				coordinates: {
                					latitude: 28.969593, // -90.0 - +90.0
                					longitude: -13.556344, // -180.0 - +180.0
                			record: {
                				recordProgram : "arecord",
                				device        : "plughw:1",
                			notifications: {
                				ASSISTANT_ACTIVATED: "HOTWORD_PAUSE",
                				ASSISTANT_DEACTIVATED: "HOTWORD_RESUME",
                			useWelcomeMessage: "brief today",
                			profiles: {
                				"default" : {
                					lang: "es-ES"
                  sdetweil @raedonlpa
                  @raedonlpa can u edit your post, and put three back-tics (shifted, left of 1) before the 1st line, and after the last line.
                  Reply Quote -1
                    raedonlpa
                    @sdetweil Better this way, I’m sorry I use google traslator
                      sdetweil @raedonlpa
                      @raedonlpa yes, much better… thank you … you missed one close brace }; at the end, inside the backtics
                        raedonlpa
                        @sdetweil I know, don’t let me put it in the forum
                          sdetweil @raedonlpa
                          @raedonlpa it was only on the edit of the forum post…
                            raedonlpa
                            @sdetweil said in MMM-Assistantmk2 and MMM-Hotword not picking up:
                            Do you mean the end of everything?
                              sdetweil @raedonlpa
                              @raedonlpa
                              this
                              is hanging out after the closing backtics… in your edited post
                                raedonlpa
                                yes, I get spawn error
                                  sdetweil @raedonlpa
                                  @raedonlpa sorry, spawn error??
                                  I was just trying to clean up the forum messages so that others with knowledge about the two modules can help you…
                                  it was very hard to read the config.js info in the original posting.
                                  the changes I mentioned should NOT be put into the actual config.js file.
                                    raedonlpa
                                    S J 2 Replies Last reply
                                      sdetweil @raedonlpa
                                      @raedonlpa weird
                                        juantata @raedonlpa
                                        @raedonlpa Hi. Did you solve the activation word?
                                        S R 2 Replies Last reply
                                          sdetweil @juantata
                                          @juantata see the documentation on model usage
                                          using one of the predefined models.
                                          https://github.com/eouia/MMM-Hotword/blob/master/documents/models.md
                                          some spoken word dialects do not work with universal models. Most users from India will have to make their own model. see below
                                          training your own voice model
                                          https://github.com/eouia/MMM-Hotword/blob/master/documents/trainer.md
                                          J 1 Reply Last reply
                                            raedonlpa @juantata
                                            @juantata yes, my mistake was that the .wav file was very large.
                                            • 3 / 3
