    MMM-Assistantmk2 and MMM-Hotword not picking up
    54 Posts 9 Posters 43.6k Views 9 Watching
    • ejay-ibmE
      ejay-ibm Project Sponsor Module Developer
      1- I would say first to check you CPU charge first , the delay might be due to the load.
      2- just say " Jarvis" … " Micheal jackson smooth criminal" it will play the youtube video clip
      3- if you want to say " ok google" you have to add your own umdl or umdp file.
      Info and new umd* file can be found and created here :
      https://snowboy.kitt.ai/
      hope this help .
      Ejay
      B 1 Reply Last reply
        bachoo786 @ejay-ibm
        @ejay-ibm thanks for the quick reply.
        you have notifications in your config, what is it for? can you please explain? thanks.
        ejay-ibmE 1 Reply Last reply
        • ejay-ibmE
          ejay-ibm Project Sponsor Module Developer @bachoo786
          @bachoo786
          The notification allows to the hotword module to receive instruction from the assistant module by notification to pause or resume itself in the right time.
          When assistant 'talk it pause the hotword detection
          ASSISTANT_ACTIVATED: “HOTWORD_PAUSE”,
          When the assistant is done it restart the hotword detection .
          ASSISTANT_DEACTIVATED: “HOTWORD_RESUME”,
          Ejay
          • A
            AdnanAhmed97
            The hotword module should be called outside the assistant module
            Add the brackets correctly and change and change device to plughw : 1;
              bachoo786 @AdnanAhmed97
              @AdnanAhmed97 what do you mean?
                jmartin1009
                @sdetweil @ejay-ibm well i got a new mic and i tried it out, still no detection for MMM-Hotword. It works for GoogleAssistantMk2 when i click the button on the screen, but no hotword detection. I worried that it may be because of snowboy failing to install properly the first time for some reason, so i went into the module in the console and did npm install and got this:
                pi@raspberrypi:~/MagicMirror/modules/MMM-Hotword $ npm install
                npm WARN deprecated hoek@2.16.3: This version is no longer maintained. Please upgrade to the latest version.
                npm WARN deprecated boom@2.10.1: This version is no longer maintained. Please upgrade to the latest version.
                npm WARN deprecated cryptiles@2.0.5: This version is no longer maintained. Please upgrade to the latest version.
                npm ERR! path /home/pi/MagicMirror/modules/MMM-Hotword/node_modules/snowboy
                npm ERR! code EISGIT
                npm ERR! git /home/pi/MagicMirror/modules/MMM-Hotword/node_modules/snowboy: Appears to be a git repo or submodule.
                npm ERR! git Refusing to remove it. Update manually,
                npm ERR! git or move it out of the way first.
                npm ERR!     /home/pi/.npm/_logs/2019-03-18T22_16_00_319Z-debug.log
                any idea how i can fix this?
                J ? 2 Replies Last reply
                  jmartin1009 @jmartin1009
                  @jmartin1009 this is possible it’s saying this because it’s already there, but i wasn’t sure i figured i’d give it another go. Let me know if there’s anything i should change or try, but i know this mic does work, as it shows up in
                  arecord -l
                  and it comes up and i can select it in alsamixer and everything, just can’t get hotword to hear me.
                    A Former User @jmartin1009
                    @jmartin1009
                    rm -rf /home/pi/MagicMirror/modules/MMM-Hotword/node_modules/snowboy/.git
                    Then try again
                      raedonlpa
                      Hi, why?
                      When I change the activation word, it doesn’t work for me?,
                      I want to change it to another word, like alexa, jarvis, etc, and it doesn’t work for me.
                      I have copied the parameters of @ejay-ibm and nothing.
                      language: "es",
                      timeFormat: 24,
                      units: "metric",
                      		module: "alert",
                      		module: "updatenotification",
                      		position: "top_bar"
                      		module: "clock",
                      		position: "top_left"
                      		header: "Calendario",
                      					symbol: "calendar-check",
                      					url: "https://www.calendarlabs.com/ical-calendar/ics/70/Spain_Holidays.ics"
                      					symbol: "MyCalendar",
                      					url: "https://calendar.google.com/calendar/ical/............/public/basic.ics"
                      		module: "compliments",
                      		position: "lower_third"
                      		module: "currentweather",
                      			locationID: "",  //ID from http://bulk.openweathermap.org/sample/city.list.json.gz; unzip the gz file and find your city
                      		module: "weatherforecast",
                      		header: "Weather Forecast",
                      			locationID: "2521570",  //ID from http://bulk.openweathermap.org/sample/city.list.json.gz; unzip the gz file and find your city
                      			appid: "..........................."
                          		module: 'currentweather',
                          		position: 'top_right',
                      		        locationID: '2521570', //ID from bulk.openweather.org/sample/
                      		        appid:" .............................'',
                      		        updateInterval: '3600000',
                      		        onlyTemp: true
                      		module: "newsfeed",
                      		position: "bottom_bar",
                      			feeds: [
                      					title: "Canarias7",
                      					url: "https://www.canarias7.es/rss/portada.xml"
                      			showSourceTitle: true,
                      			showPublishDate: true,
                      			broadcastNewsFeeds: true,
                      			broadcastNewsUpdates: true
                      		module: "MMM-Hotword",
                      			chimeOnFinish: null,
                      			mic: {
                      				recordProgram: "arecord",
                      				device: "plughw:1"
                      			models: [
                      					hotwords    : "Smart_mirror",
                      					file        : "smart_mirror.umdl",
                      					sensitivity : "0.5",
                      			commands: {
                      				"smart_mirror": {
                      					notificationExec: {
                      						notification: "ASSISTANT_ACTIVATE",
                      						payload: (detected, afterRecord) => {
                      							return {profile:"default"}
                      					restart:false,
                      					afterRecordLimit:0
                      		module: "MMM-AssistantMk2",
                      			deviceLocation: {
                      				coordinates: {
                      					latitude: 28.969593, // -90.0 - +90.0
                      					longitude: -13.556344, // -180.0 - +180.0
                      			record: {
                      				recordProgram : "arecord",
                      				device        : "plughw:1",
                      			notifications: {
                      				ASSISTANT_ACTIVATED: "HOTWORD_PAUSE",
                      				ASSISTANT_DEACTIVATED: "HOTWORD_RESUME",
                      			useWelcomeMessage: "brief today",
                      			profiles: {
                      				"default" : {
                      					lang: "es-ES"
                        sdetweil @raedonlpa
                        @raedonlpa can u edit your post, and put three back-tics (shifted, left of 1) before the 1st line, and after the last line.
                        Reply Quote -1
                          raedonlpa
                          @sdetweil Better this way, I’m sorry I use google traslator
                            sdetweil @raedonlpa
                            @raedonlpa yes, much better… thank you … you missed one close brace }; at the end, inside the backtics
                              raedonlpa
                              @sdetweil I know, don’t let me put it in the forum
                                sdetweil @raedonlpa
                                @raedonlpa it was only on the edit of the forum post…
                                  raedonlpa
                                  @sdetweil said in MMM-Assistantmk2 and MMM-Hotword not picking up:
                                  Do you mean the end of everything?
                                    sdetweil @raedonlpa
                                    @raedonlpa
                                    this
                                    is hanging out after the closing backtics… in your edited post
                                      raedonlpa
                                      yes, I get spawn error
                                        sdetweil @raedonlpa
                                        @raedonlpa sorry, spawn error??
                                        I was just trying to clean up the forum messages so that others with knowledge about the two modules can help you…
                                        it was very hard to read the config.js info in the original posting.
                                        the changes I mentioned should NOT be put into the actual config.js file.
                                          raedonlpa
                                          S J 2 Replies Last reply
                                            sdetweil @raedonlpa
                                            @raedonlpa weird
                                            • 2 / 3
