    Update Magic Mirror error
    8 Posts 3 Posters 3.9k Views 3 Watching
      MisterT
      I have a problem with my Magic Mirror. I just want to update my MM but i can’t because the result of “git pull && npm install” is: (in french)
      Mise à jour de57daa…a31546b
      error: Vos modifications locales aux fichiers suivants seraient écrasées par la fusion :
      config/config.js.sample
      package-lock.json
      vendor/package-lock.json
      Veuillez valider ou remiser vos modifications avant la fusion.
      Abandon
      and with google translate:
      Updated from57daa…a31546b
      error: Your local changes to the following files would be overwritten by the merge:
      config / config.js.sample
      Package-lock.json
      vendor / package-lock.json
      Please validate or postpone your changes before the merge.
      abandonment
      Can anobody tell me the command line to close this error in order to restart git pull?
      Thanks for next answers
      S mumblebajM 2 Replies Last reply Reply Quote 0
        sdetweil @MisterT
        @MisterT said in Update Magic Mirror error:
        Package-lock.json
        you can erase these two files, then will be created
        git thinks this file was changed, and it should not have been
        so, restore that file from the local repo
        git checkout -- config/config.js.sample
        then try again,
        I have been working on a new script to do upgrades, to help avoid these problems…
        i’d be interested in your experience if u could try it…
        see
        https://forum.magicmirror.builders/topic/10859/new-update-upgrade-script-ready-for-testing
        • mumblebajM Offline
          mumblebaj Module Developer @MisterT
          @MisterT You could also just do a git reset --hard and then git pull $$ npm install. I have had this issue every time I had to update my mirror.
            MisterT
            hi,
            sdetweil: i try your solution:
            git checkout – config/config.js.sample
            but i have the same problem. git pull said me the same thing. Have you a other idea?
            mumblebaj: if y use this command line, all my modules and config will be deleted? if i copy my modules folder and config folder and paste them in the new version of Magic mirror, everything will work fine?
            mumblebajM S 2 Replies Last reply Reply Quote 0
              @MisterT You will not lose your modules and configs.
                sdetweil @MisterT
                @MisterT notice my post had 2 - in front of filename. Yours appears only to have one
                  MisterT
                  thanks @mumblebaj you’re awesome !!!. Git reset --hard work fine
                  Update MM2.8 is ok.
                    @MisterT Great it worked for you. Please mark the post as Resolved if you are happy that it worked.
