    Magic Mirror won't load.
    12 Posts 2 Posters 5.8k Views 2 Watching
      aunrea @sdetweil
      @sdetweil I had done it before, I believed. I did it again and I still get the same error and the same message.
        sdetweil @aunrea
        @aunrea mmm-pir is missing completion
          aunrea @sdetweil
          @sdetweil I uninstalled MMM-PIR and reinstall. I have updated npm. I still get that same error message when I have MMM-PIR in my config.js file.
            sdetweil @aunrea
            @aunrea when u do
            cd ~/MagicMirror/modules/MMM-PIR
            npm install
            What happens?
              aunrea @sdetweil
              @sdetweil I get the message:
              audited 6 packages in 1.756s
              found 0 vulnerabilities
                sdetweil @aunrea
                @aunrea I think u need to do an electron-rebuild in that folder.
                I am not near my machine, but electron-rebuild was installed as part of MagicMirror.
                See https://forum.magicmirror.builders/topic/10206/mmm-pir-sensor-not-working-with-latest-release-display-does-not-turn-off/7
                  aunrea @sdetweil
                  @sdetweil I got the following error when I followed those instructions:
                  pi@raspberrypi:~/MagicMirror/modules/MMM-PIR $ npm install electron-rebuild
                  + electron-rebuild@1.8.6
                  updated 1 package and audited 245 packages in 20.05s
                  pi@raspberrypi:~/MagicMirror/modules/MMM-PIR $ node_modules/.bin/electron-rebuild
                  ✖ Rebuild Failed
                  An unhandled error occurred inside electron-rebuild
                  Could not locate node-gyp
                  Error: Could not locate node-gyp
                      at Rebuilder.<anonymous> (/home/pi/MagicMirror/modules/MMM-PIR/node_modules/electron-rebuild/lib/src/rebuild.js:172:23)
                      at Generator.next (<anonymous>)
                      at fulfilled (/home/pi/MagicMirror/modules/MMM-PIR/node_modules/electron-rebuild/lib/src/rebuild.js:4:58)
                    sdetweil @aunrea
                    @aunrea see the instructions w MMM-AssistantMk2.
                    Great step by step
                      aunrea @sdetweil
                      @sdetweil Thank you for the help. I got it to work.
                        sdetweil @aunrea
                        @aunrea awesome!! thanks for the feedback… can u mark your issue resolved?
