    Magic Mirror won't load.
    12 Posts 2 Posters 6.6k Views 2 Watching
      sdetweil @aunrea
      @aunrea looks like you might have done an update, but not completely.
      modules/MMM-PIR/
      in each module folder that has a package.json file, do
      npm install
      A 1 Reply Last reply
      • A
        aunrea @sdetweil
        @sdetweil I had done it before, I believed. I did it again and I still get the same error and the same message.
          sdetweil @aunrea
          @aunrea mmm-pir is missing completion
          • A
            aunrea @sdetweil
            @sdetweil I uninstalled MMM-PIR and reinstall. I have updated npm. I still get that same error message when I have MMM-PIR in my config.js file.
              sdetweil @aunrea
              @aunrea when u do
              cd ~/MagicMirror/modules/MMM-PIR
              npm install
              What happens?
              • A
                aunrea @sdetweil
                @sdetweil I get the message:
                audited 6 packages in 1.756s
                found 0 vulnerabilities
                  sdetweil @aunrea
                  @aunrea I think u need to do an electron-rebuild in that folder.
                  I am not near my machine, but electron-rebuild was installed as part of MagicMirror.
                  See https://forum.magicmirror.builders/topic/10206/mmm-pir-sensor-not-working-with-latest-release-display-does-not-turn-off/7
                  • A
                    aunrea @sdetweil
                    @sdetweil I got the following error when I followed those instructions:
                    pi@raspberrypi:~/MagicMirror/modules/MMM-PIR $ npm install electron-rebuild
                    + electron-rebuild@1.8.6
                    updated 1 package and audited 245 packages in 20.05s
                    pi@raspberrypi:~/MagicMirror/modules/MMM-PIR $ node_modules/.bin/electron-rebuild
                    ✖ Rebuild Failed
                    An unhandled error occurred inside electron-rebuild
                    Could not locate node-gyp
                    Error: Could not locate node-gyp
                        at Rebuilder.<anonymous> (/home/pi/MagicMirror/modules/MMM-PIR/node_modules/electron-rebuild/lib/src/rebuild.js:172:23)
                        at Generator.next (<anonymous>)
                        at fulfilled (/home/pi/MagicMirror/modules/MMM-PIR/node_modules/electron-rebuild/lib/src/rebuild.js:4:58)
                      sdetweil @aunrea
                      @aunrea see the instructions w MMM-AssistantMk2.
                      Great step by step
                      • A
                        aunrea @sdetweil
                        @sdetweil Thank you for the help. I got it to work.
                          sdetweil @aunrea
                          @aunrea awesome!! thanks for the feedback… can u mark your issue resolved?
