    Magic Mirror won't load.
    12 Posts 2 Posters 5.8k Views 2 Watching
      sdetweil @aunrea
      @aunrea mmm-pir is missing completion
        aunrea @sdetweil
        @sdetweil I uninstalled MMM-PIR and reinstall. I have updated npm. I still get that same error message when I have MMM-PIR in my config.js file.
          sdetweil @aunrea
          @aunrea when u do
          cd ~/MagicMirror/modules/MMM-PIR
          npm install
          What happens?
            aunrea @sdetweil
            @sdetweil I get the message:
            audited 6 packages in 1.756s
            found 0 vulnerabilities
              sdetweil @aunrea
              @aunrea I think u need to do an electron-rebuild in that folder.
              I am not near my machine, but electron-rebuild was installed as part of MagicMirror.
              See https://forum.magicmirror.builders/topic/10206/mmm-pir-sensor-not-working-with-latest-release-display-does-not-turn-off/7
                aunrea @sdetweil
                @sdetweil I got the following error when I followed those instructions:
                pi@raspberrypi:~/MagicMirror/modules/MMM-PIR $ npm install electron-rebuild
                + electron-rebuild@1.8.6
                updated 1 package and audited 245 packages in 20.05s
                pi@raspberrypi:~/MagicMirror/modules/MMM-PIR $ node_modules/.bin/electron-rebuild
                ✖ Rebuild Failed
                An unhandled error occurred inside electron-rebuild
                Could not locate node-gyp
                Error: Could not locate node-gyp
                    at Rebuilder.<anonymous> (/home/pi/MagicMirror/modules/MMM-PIR/node_modules/electron-rebuild/lib/src/rebuild.js:172:23)
                    at Generator.next (<anonymous>)
                    at fulfilled (/home/pi/MagicMirror/modules/MMM-PIR/node_modules/electron-rebuild/lib/src/rebuild.js:4:58)
                  sdetweil @aunrea
                  @aunrea see the instructions w MMM-AssistantMk2.
                  Great step by step
                    aunrea @sdetweil
                    @sdetweil Thank you for the help. I got it to work.
                      sdetweil @aunrea
                      @aunrea awesome!! thanks for the feedback… can u mark your issue resolved?
